Old 05-01-2009, 11:01 AM   #1
GriffithBuilt
Member#: 141927
Default EJ25 Intake Interchangability
Hello,
I bought an EJ253 (99 2.5RS) long block and I need to now find an intake manifold for it. I found one (on ebay) off of a 1998 Forester w/ 2.5 engine, it looks very similar to the older ej22 intakes, with the iac on the side of the plenum near the throttle, etc.
Is there a potential that this has the same bolt pattern as my EJ253? If not, which intakes will fit the EJ253?
Jason
GriffithBuilt is offline   Reply With Quote
Old 05-01-2009, 11:27 AM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Won't work. There are 3 bolt patterns. Early Ej22 has one. DOHC EJ25 is another. SOHC Ej25 is the third one. You need a manifold from a 99-03 2.5RS.
Old 05-01-2009, 11:56 AM   #3
GriffithBuilt
Member#: 141927
Ok so I guess I'm most curious if the EJ251, 252 and 253 SOHC's all have the same intake bolt pattern.
Also curious what the variations in actual iac location are in those intakes - all built into the throttle body, or are some direct to the intake?
Jason
Old 05-02-2009, 11:25 PM   #4
subienewb29
Member#: 182003
99 impreza
silver surfer
I have what you need.
subienewb29 is offline   Reply With Quote
EJ25 cam interchangeability? TaurusMcRae007 Built Motor Discussion 3 07-01-2009 05:45 AM
EJ intake interchange... any list? B-Kerr Subaru Conversions 2 03-17-2009 09:27 AM
EJ25 Crankshafts interchangeable? boost junkie Built Motor Discussion 5 02-04-2009 09:37 AM
Will EJ22 and EJ25 Intake Manifolds Interchange??? JT99 Subaru Conversions 6 07-04-2008 01:33 PM
Intakes... Interchangable for 02 RS/WRX? Uncle Ben General Community 8 11-15-2002 06:14 AM
