Old 05-01-2009, 12:57 PM   #1
cstyker1111
Member#: 69521
2004 WRX
JBP
Default 2004 WRX Headlight upgrade
Hey!
I was gonna buy a cheapy HID kit for my 04 WRX but realized that wouldn't be the best option. So what are my options? I'm thinking about buying the H1 55w Osram Nightbreakers... are these decent? Do I need a new harness for these?
cstyker1111 is offline   Reply With Quote
Old 05-01-2009, 02:34 PM   #2
JavaBot
Member#: 156723
05 crp foresterX
rip 2.0i/2.5rs
Lightwerkz H1 ddm 5000K kit... shhhhh...
JavaBot is offline   Reply With Quote
Old 05-01-2009, 02:40 PM   #3
andyboi677
Member#: 179049
2005 Imperza Wrx
That is not the right way to go. You should do a retrofit instead. I tried it and there is too much glare. plus many people probably going to tell you that it is wrong. I just don't want it to shine everywhere especially to on coming traffic. adjusti.ng it down won't help much. plus I didn't want to get pulled over
andyboi677 is offline   Reply With Quote
Old 05-01-2009, 11:56 PM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Originally Posted by cstyker1111 View Post
Hey!
a decent pair of aux lights would be great
Old 05-02-2009, 12:55 AM   #5
Spore
Member#: 100117
2009 Impreza 2.5i
Satin White Pearl
Not that I'm against supporting NASIOC vendors, but I can't seem to find a reason to justify the heftier price tag. Lightwerkz HID kit seems like a regular HID conversion kit placed in a fancy metal case with an overpriced tag. I remember the time when Lightwerkz used Apexcone as their HID supplier, his price is about 2 times as much as other Apexcone providers (they don't get the metal case). However, when things do go bad, he will be there to answer your call.
That said, another option for increase night time visibility is +80 bulbs and a good wiring harness. Remember, for best results, replace light bulbs every year as they do dim as time progresses (especially for those with the DRL on).
Spore is offline   Reply With Quote
Old 05-02-2009, 01:57 PM   #6
steverx05
Member#: 128269
'13 VW Golf R
Putting an HID kit into any halogen headlight is just the wrong thing to do no matter what...ESPECIALLY in the 04-05 headlights. The reflectors have a bad enough time focusing the stock halogen light correctly, let alone 3 times the amount of light from a cheap kit.
Retrofit is definitely the way to go.
steverx05 is offline   Reply With Quote
Old 05-03-2009, 05:28 PM   #7
dauss
Member#: 108369
2005 CGM WRX Wagon
68HTA
Or if you can find some headlights from an STi. That's what I have done.
dauss is offline   Reply With Quote
Old 05-04-2009, 10:07 AM   #8
dave_mtu
Member#: 179830
2004 WRX Wagon
upgrade your high beam bulbs with an HIR 9011.
dave_mtu is offline   Reply With Quote
Old 05-04-2009, 10:16 AM   #9
cstyker1111
Member#: 69521
2004 WRX
JBP
So I've purchased the following:
Low bulbs and fogs: Osram Nightbreakers
High bulbs: HIR 9011
I think it'll be a good upgrade over stock.
Old 05-04-2009, 12:34 PM   #10
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
good deal. thank you for going about an upgrade the right way!
you can also upgrade your wiring by building a relay harness.
jdubya301 is offline   Reply With Quote
Old 05-05-2009, 08:25 AM   #11
Spenk
Member#: 7164
2000 Miata LS
Evo Orange Mica (1/644)
You'll really dig those HIR highbeams...
Spenk is offline   Reply With Quote
Old 05-05-2009, 09:31 AM   #12
cstyker1111
Member#: 69521
2004 WRX
JBP
What is the benefit of that? Can anyone point me in the right direction to read up on this?
Old 05-05-2009, 10:00 AM   #13
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
search for "bugeye wiring bliss"
since subaru uses ground switched circuits for headlights, there is a significant drop in power that makes it to the headlights.
building a relay harness that is direct from the battery will get higher voltages to the headlights. some have seen a 1.2v drop through the stock wiring.
another added benefit is that you can use larger gauge wire, which makes it nice when you want to upgrade the wattage of your headlights.
Old 05-05-2009, 03:09 PM   #14
cstyker1111
Member#: 69521
2004 WRX
JBP
Thanks! Sorry for being a noob but is this recommended for the bulbs I got?
Old 05-05-2009, 10:51 PM   #15
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
it doesnt matter what kind of bulbs.
2004 WRX brake upgrade, STi brembros? Drav Brakes, Steering & Suspension 15 12-29-2014 03:17 AM
2004 WRX Suspension Upgrade Advice van_dutch Brakes, Steering & Suspension 5 01-25-2009 08:00 PM
2004 WRX Headlight upgrade gbwest Electrical & Lighting 1 08-31-2005 11:39 PM
MY 2004 WRX STi Upgrade plan - comments? RChampion New England Impreza Club Forum -- NESIC 69 05-12-2004 10:36 AM
2004 wrx UTEC Upgrade Available STI When?? hrtpumper Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 107 04-17-2004 01:15 PM
