Old 05-01-2009, 04:05 PM   #1
amyasin
Member#: 206668
Default swapping in a 02 forester motor in a 00 RS
Installing a 02 forester motor in a 2000 impreza RS
I am looking to replace a blown motor with another drop in stock replacement. From what I have read I have EJ251 in the impreza and the 02 forester is the EJ251 as well. IF that is the case then will it just drop right in wire sensors and everything? Sorry for the Noob question I have searched but haven’t found anything and according to Wikipedia as long as I use a 02 forester motor I should be fine.
Thanks in Advance
amyasin is offline   Reply With Quote
Old 05-01-2009, 04:35 PM   #2
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
wow... your post is written in Times New Roman!!
The useless part of my reply being over, yes the 02 forester anf the 02 impreza NA motors are the same, right down to the wires, pipes, and bolts. Lego cars
Old 05-01-2009, 08:25 PM   #3
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Yes, it will work just fine.
Old 05-02-2009, 12:26 AM   #4
amyasin
Member#: 206668
I figured since the EJ251 was used in the 2000 impreza and the 02 forester (got it off of wikipedia) it would just drop in. I posted the same questions on RS25 and they were telling me to swap the cam gears and intake manifold. Intake manifold would be changed out of I was switching from a 251 to a 252 or 253 correct? Not sure about the cam gears though
thanks again
02 wrx springs on a 00 rs w/ stock struts? k3lh3 Newbies & FAQs 6 02-10-2010 07:23 PM
04 2.5 Forester motor in a 99 2.5 RS? R.B. WRX Wagon Subaru Conversions 3 08-24-2007 05:21 PM
FT or FS: 00-02 Forester wheels for 98-01 RS wheels clsmooth Forester Forum 5 08-21-2006 04:11 AM
FT or FS: 00-02 Forester wheels for 98-01 RS wheels clsmooth VIC Private Classifieds 8 08-21-2006 04:11 AM
02 WRX pads on a 00 RS? JeffrWRX Brakes, Steering & Suspension 5 11-16-2005 11:08 PM
Message Board Statistics All times are GMT -4. The time now is 09:35 PM.
