Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 05-01-2009, 07:51 PM   #1
apkarian100
Member#: 207053
2013 XV Crosstrek
Default Rough Idle For Baja?
Hi,
I have noticed, driving my Mom's Baja that the idle is not as smooth as i think it should be. When I sitting still, and the car is on, it feels like the car starts to jerk rapidly to one side or the other. Could it be bad fuel injectors?
What do you guys think?
apkarian100 is offline   Reply With Quote
Old 05-02-2009, 07:46 AM   #2
BajaGuy68
Member#: 127720
2015 WRX
Lightning Red
It may be many things; dirty/bad fuel injectors, bad gas-water in the gas, bad wires-plugs, sensors, etc... I would try putting in some gas treatment/fuel injector cleaner in first. Then go to a friend or an auto parts store(Autozone,Pep Boys) and have them use a code scanner on the Subie and see if there are any codes showing up.---Its a start in the right direction. I hope it helps.
BajaGuy68 is offline   Reply With Quote
Old 05-07-2009, 08:55 PM   #3
machinegreen
Member#: 100818
2005 Baja Sport
Dark Blue Pearl
I used fuel injector cleaner and a good oil change with anti sludge in the new oil. Runs smoother now.
machinegreen is offline   Reply With Quote
Rough idle, intermitent and rough cold starts... carter_wrx Pre-2002 Factory Turbo Powertrain 26 10-28-2009 02:03 PM
How Rough is a Rough Idle Go350zGo Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 10-23-2009 12:28 AM
rough idle, misfire, CEL funky high idle carter_wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-04-2009 03:44 PM
very rough idle lean afr's at idle TDagen Open Source Reflashes 8 07-07-2008 05:28 PM
High Idle, Rough Idle? Brettweiser Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 04-10-2007 12:10 AM
