Old 05-02-2009, 12:20 AM   #1
atreimer
Member#: 210264
Default 2.5 DOHC to SOHC swap
I crashed my forester approximately 6 months ago. I stripped all of the parts from it and they are all laying in the garage. It has a SOHC 2.5 in it and I was wondering what the process is to swap a DOHC to SOHC. I have the wiring harness and everything, I'm just curious to see if I use the wiring harness if it is plug and play or what the process if to achieve this is.
atreimer is offline   Reply With Quote
Old 05-02-2009, 01:27 PM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
You're going to have to be a bit more clear with what's going on here if you want us to help you. For starters, what car are you trying to install your old SOHC Forester Ej25 into?
knock sensor - 97/98 2.5 DOHC to 00 SOHC 2.5RS moogoob Service & Maintenance 3 02-20-2008 11:59 AM
2.5 dohc to JDM 2.5 dohc... Need Help! suby53 Normally Aspirated Powertrain 20 02-19-2008 07:00 PM
2.5 dohc and sohc Dirty2.5RS Normally Aspirated Powertrain 7 12-22-2006 01:45 AM
97 DOHC to SOHC Swap spruitt Subaru Conversions 7 03-26-2004 06:30 PM
DOHC to SOHC swap? Impreza25RS Normally Aspirated Powertrain 6 01-24-2002 01:18 PM
Message Board Statistics All times are GMT -4. The time now is 08:22 AM.
