Old 05-02-2009, 01:50 AM   #1
habitatxskate
Member#: 197537
06 WRX
matte black
Default 5 amp fuse okay?
i wired up two lights like the ones you'd find connected to an aftermarket gauge that i ran through a little led switch i had laying around and i was wondering if a 5 amp fuse would be the proper one to use. i haven't decided where these lights will be placed, maybe in the center console and by the cupholder. could i run another light or two?
also any input on where you'd put some lights would be cool too
habitatxskate is offline   Reply With Quote
Old 05-02-2009, 03:00 PM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
Small lamps usually require less than 250 milliamps apiece and really more like 100 milliamps of current draw so really a 2 amp fuse would be alright to run the lights. The proper size wiring gauge should also be selected for the circuit. If you are using a 18 gauge wire that would be fine for what you are doing.
Cougar4 is online now   Reply With Quote
amp fuses.... scoobyless Car Audio, Video & Security 14 11-22-2003 03:17 PM
two amp fuse question Will98RS Car Audio, Video & Security 7 05-31-2003 12:07 AM
Amp fuses? plurbe Car Audio, Video & Security 8 10-19-2001 05:15 PM
To wire amp w/ 100 amp fuse... ninrex Car Audio, Video & Security 9 09-16-2001 12:09 PM
Question/Problem with amp fuses. Please read. Andrew Car Audio, Video & Security 0 05-25-2001 09:55 PM
