Old 05-02-2009, 09:17 AM   #1
05Scooby
Member#: 153216
2005 WRX stage 3
CGM
Default Help with ignition wire on my wideband..
Got all my other wires run and so on and so forth.
But I need to tap into my ignition system...
this is for my LC-1 Innovate wideband system I got from Tactrix.
any help and or pics are welcome.
Thanks...
05Scooby is offline   Reply With Quote
Old 05-02-2009, 09:31 AM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
do NOT tap ANY igniton wires!!!!!!
there are plenty of switched power wires that you can use.....and people that blindly want to start ****ing with the ignition are
just dont...find a switched circuit that wont short the ignition and ruin your day if you **** something up
there are plenty
Old 05-02-2009, 10:22 AM   #3
05Scooby
Member#: 153216
2005 WRX stage 3
CGM
I really didn't want to mess with the ignition but I was just asking due to what the instructions say.
Old 05-02-2009, 01:39 PM   #4
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
I think the best way to install a power connection for a new accessory is to use a fuse tap. That leaves things original and makes an connection easy to add a new power circuit. Tap a fuse position in the dash panel that has power applied to it when the ignition switch is turned on. Install the fuse tap and the correct fuse for the device you are installing.
Old 05-02-2009, 06:37 PM   #5
05Scooby
Member#: 153216
2005 WRX stage 3
CGM
That sounds like a good idea, now, whats a fuse tap look like...
I probly would know what it is if I see it... lol
never heard that name before
Need somne handy members to help with some work on my car AWDrifter21 Tri-State Area Forum 14 05-18-2009 01:43 PM
Ignition Wires On A Ej207 jkjersey Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 02-24-2007 12:37 AM
need some serious help with some wiring issues on a rex swap into an rs legacy2003 Subaru Conversions 14 07-20-2005 05:57 PM
Who wants to help me do wiring on my JDM swap today? Need4Boost Tri-State Area Forum 3 02-01-2004 12:18 PM
('93-'01) Help with PocketLogger [Q] on MY 99 RS (OBDII) Peaty Impreza Forum 5 01-25-2002 08:52 AM
