Old 05-02-2009, 10:25 AM   #1
VuickB6
Member#: 193568
Default Struggled at the track again!
Went to Houston Raceway last night hoping to get some better times, but came back disappointed
My car has the following mods:
Grimmspeed Bellmouth Downpipe
Grimmspeed Uppipe with 38mm EWG
CSS TMIC
K&N Panel Filter
Tuned by AWDTuning, estimated whp was ~235whp
Track conditions were mildly warm and felt pretty humid as well. All 3 runs were within 15 minutes of each other and all 3 felt really strong.
#1
60' - 2.148
330 - 6.130
1/8 - 9.412
MPH - 74.72
1000 - 12.242
1/4 - 14.625
MPH - 93.88
Launching from ~4500rpm, shifting was at 7000 and trapped at the top of 3rd.
#2
60' - 2.262
330 - 6.213
1/8 - 9.495
MPH - 75.13
1000 - 12.308
1/4 - 14.678
MPH - 94.37
Shifting was same as #1
#3
60' - 2.069
330 - 6.309
1/8 - 9.697
MPH - 73.29
1000 - 12.570
1/4 - 14.957
MPH - 93.70
Same as the rest but launched at almost 5000rpm, clutch was getting hot and had a little problem getting into second.
I know the 60' times aren't that great, but that's about as hard as I'm willing to launch it. I don't really feel like breaking the trans But even then I thought they were pretty good launches, I blew all 3 people away out of the hole badly.
And maybe I'm wrong about this, but I figured riding out 3rd and saving a shift would be quicker than short shifting right before finishing. That's why I took it out to almost 7500rpms.
Questions, comments, concerns, criticisms, critiques, flames?
VuickB6 is offline   Reply With Quote
Old 05-02-2009, 10:26 AM   #2
VuickB6
Member#: 193568
Also, the car weighed 3190 on the scales, add in another 210 for me.
Old 05-02-2009, 11:24 AM   #3
69subaru360
Member#: 159682
1995 WRX
2015 F150
Add launch control, then you can leave on boost and get your 60 foot time down to the 1.7-1.8 that it should be. Launch control is actually easier on the trans. Hold it to the floor, build boost, let the clutch out. This alone will drop a half second off your et. Every tenth you lose in the 60 foot is worth 2 tenth in the et.
Don't run the car back to back like that for good times, you are heating up the TMIC.
Shift much lower around 6500 and shift to 4th gear. You aren't making any power at 7500 rpm with a stock turbo stock cam 2.0 Your mph is low and hopefully it's because you aren't getting into 4th gear. If not something else is wrong with the car, you should trap higher.
I hate to say it, but at your power level all the ewg is doing is making noise.
Old 05-02-2009, 12:56 PM   #4
wrxtremeWGN
Member#: 12281
08 FSXT
Tiger's Blood
why do you have an ewg setup on a td04? and i dont see any EM listed, what are you tuned w/?
wrxtremeWGN is offline   Reply With Quote
Old 05-02-2009, 01:49 PM   #5
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
No offense, but there is a lot of improvment just with better driving. You're trap speed is about that of a stock WRX, which isnt terrible considering the driving. It's obvious you are bogging on the launch which is probably costing you at least .5 sec. I think a really clean pass will result in a high 13 at close to 100mph.
Also is your exhaust stock from the cat back?? If so it's acting like a cork in the system and probably limiting the top end (exactly what you need in drag racing).
I'd work on the launch and experiment with different shift RPMs. You will have to finish the 1/4 in 4th if you want to trap over 100mph as your car should be.
Also for poops and giggles try taking the stock cat-back off and see what happends.
If you do have a free-flowing cat-back then your car might need some attention. Fresh plugs, fuel filter, air filter, etc. Probably wont hurt to do a compression check as well just to make sure the motor is still good.
Steve.804 is online now   Reply With Quote
Old 05-02-2009, 09:48 PM   #6
VuickB6
Member#: 193568
I didn't even think to have launch control added, I figured it was hard on the trans and didn't feel like breaking it till I got an STI trans.
And I ran it back to back like that because I got there late, and waited about 30 minutes for the first run(which I didn't get a slip for) and it cleared out afterward. So I didn't have much time to let it cool between runs before they closed, I was one of the last ones to make a pass.
I'll definitely try that, I'm making another trip next Friday and we'll see if that makes the difference. And the mph is definitely low, stock I trapped 91mph, but what is weird is that I gained half a second compared to stock which the modifications I have now, but at the same 60' times.
And I don't plan on sticking with the stock TD04 very long, but to go Stage 2 for only $1000 total(parts,labor,tuning) I couldn't pass it up.
Old 05-02-2009, 09:49 PM   #7
VuickB6
Member#: 193568
See above post about the EWG.
And Keith @ AWDTuning road tuned it after installing the Downpipe/Uppipe.
Old 05-03-2009, 12:42 AM   #8
VuickB6
Member#: 193568
I didn't bog but the very first pass(which like I mentioned, I didn't get a slip for) but the others were clean launches. I held them at whatever RPM, and let the clutch out till I felt it juuuuuust start to move, then on green I let it out aggressively and floored it at the same time.
I'm stage 2 with a Perrin cat-back
Plugs are only 1 month old, K&N is only 3 months old and was cleaned/re-oiled before I put it in. Fuel filter I have no idea about, but the car pulls very strong and judging by the cars I'm beating on the street, the slow times are most likely because of me being scared to break the trans and shifting too late.
We shall see next week
Old 05-03-2009, 03:33 PM   #9
CKxx
Member#: 33458
Your BOV sounds lame
93 RX7+09 Forester
...oh how I miss that.
I have a 2004 STi trans and thin tires on my bugeye. It is like drag racing in a rowboat. I'm in 5th for 500 or so RPM.
CKxx is offline   Reply With Quote
Old 05-03-2009, 03:37 PM   #10
saab-on-the-cobb
Member#: 116330
2005 Saabaru 9-2x
desert sand metallic
You can launch from 3000 RPM and get better 60' times.
You are bogging at the line, aren't you?
sotc
saab-on-the-cobb is offline   Reply With Quote
Old 05-03-2009, 03:58 PM   #11
benw
Member#: 103320
1998 swapped
Forester L
traps should be around 96, at least they are here at 1200 ft elevation on 91 octane, for a car like yours.
practice your launch like others have said!!
benw is offline   Reply With Quote
Old 05-03-2009, 04:06 PM   #12
V6TurboTA
Member#: 9090
09 Forester Gump
02WRX->04STi->09Gump
It shifts into 4th or it gets the hose again.
V6TurboTA is offline   Reply With Quote
Old 05-03-2009, 08:15 PM   #13
VuickB6
Member#: 193568
sotc
See below!
Old 05-03-2009, 08:16 PM   #14
VuickB6
Member#: 193568
Will do!
Old 05-03-2009, 08:17 PM   #15
VuickB6
Member#: 193568
Can't wait to get mine, but I'm looking to get an 07 trans!
Old 05-09-2009, 10:46 PM   #16
VuickB6
Member#: 193568
Went back to the track last night to see if I could improve on my times. I tried to be more aggressive with the launch, shifting was done at 6500rpm and started finishing in 4th gear instead of wringing out 3rd. Neither of these proved to help out my times at all.
#1
R/T - .350
60' - 2.380
330 - 6.317
1/8 - 9.567
MPH - 76.87
1000 - 12.347
1/4 - 14.722
MPH - 94.33
Launched at ~4500rpm and bogged Shifting was clean. This was done right after I got to the track, went through tech, and sat in line for 30 minutes. Car was pretty warm I imagine.
#2
R/T - .376
60' - 2.184
330 - 6.065
1/8 - 9.336
MPH - 76.11
1000 - 12.136
1/4 - 14.540
MPH - 93.02
Same as #1 minus the bog. This was against a BMW 645 vert that challenged me while we were waiting. I got him badly off the launch and he was playing catch up the whole time. Only beat him by a tenth though! It was pretty fun
#3
R/T - .296
60' - 2.112
330 - 5.913
1/8 - 9.118
MPH - 77.64
1000 - 11.883
1/4 - 14.253
MPH - 94.38
This was done after letting my car cool down for an hour and letting it sit with ice on the intercooler up until it was my turn to pull up to the waterbox. The intercooler was sweating badly and was COLD to the touch, I was also pushing the car the whole way.
Everything showed improvement except for the 60' and MPH
So having a really cold intercooler seems to be the only thing that helped get quicker times, but even then, with the power I'm making I should be trapping a lot higher right? Finishing in 4th showed ZERO improvement over wringing out 3rd gear
With these times, I shouldn't be beating half of the cars I am on the street. Anyone have an ideas about what could be causing such slow times?
Old 05-09-2009, 11:01 PM   #17
Trevor723
Member#: 57989
2013 Golf TDI
united gray
In 6 runs you've dropped nearly 1/2 a second without any real improvement in 60' times. I'd say keep on practicing is going to be the best, most honest advice you are going to get.
Trevor723 is offline   Reply With Quote
Old 05-09-2009, 11:44 PM   #18
69subaru360
Member#: 159682
1995 WRX
2015 F150
More practice or L/C to get the 60' down to 1.7-1.8 where it should be.
MPH is still low, datalog the car going down the track to see if it is pulling timing due to false knock on the shifts, it's very common.
When it's all right you should go mid 13's at close to 100
Old 05-10-2009, 01:59 AM   #19
AntiochCali
Member#: 30185
2003 320 whp
on a heatbreaker dyno
You're times are in line with your 60 foot...your trap speeds look a bit low, but not terrible either...really for stock turbo on that car without at least a 1.8 60'...that's about as good as you'll get...a 1.8 60' will put you in high 13's...you need to shift at the end, I know it bites, but I have to too.
AntiochCali is offline   Reply With Quote
Old 05-10-2009, 02:26 AM   #20
VuickB6
Member#: 193568
I'm going to see about getting L/C here shortly, sounds like it's the way to go for better times.
And I'll get what I need to start logging, I'm interested in your false knock theory. I've already started reading threads that talk about the issue.
If that's the best I can do for know I guess I'll just have to be happy with it.
Any idea why I didn't see an increase in MPH after finishing in 4th gear rather than 3rd? That's what really has me confused
Old 05-10-2009, 04:18 PM   #21
AntiochCali
Member#: 30185
2003 320 whp
I'm guessing here, but my guess is that you need to shift better/faster..I know I did about 3 mph better by shifting, and of course the car is still accel at the end - whereas if I don't shift, the car has no pull that diff, when I shift well, is around a 3 mph trap.
Note: getting a 1.8 or better 60' gives me a better 1/4 but a slightly worse trap.
Old 05-10-2009, 10:26 PM   #22
VuickB6
Member#: 193568
Not sure how much better/faster I can get with the shifts. I can't even remember the last time I missed a shift, and I'm shifting as fast as I possibly can!
Old 05-10-2009, 11:16 PM   #23
V6TurboTA
Member#: 9090
09 Forester Gump
Maybe try to find a local guy that really knows how to launch a near stock 02-04 wrx and have him show you what he does to get good 60' times?
I showed a kid how to launch his 02 WRX ( 2 or 3 launches in his car in the back of the lot at the track) and he picked up a half a second over the course of that day.
You might be underestimating yourself and or your car
1.8's in a stockish 03 wrx is very possible.
Old 05-11-2009, 01:10 AM   #24
Prevent
Member#: 149114
R/T - .296
60' - 2.112
330 - 5.913
1/8 - 9.118
MPH - 77.64
1000 - 11.883
1/4 - 14.253
MPH - 94.38
Drop the 60' to a 1.7 and thats easily a mid 13 run
I was running 1.9 60's and doing 13.4-13.6', friend hops in the car cuts a 1.7 and runs 12.9. Dont beat yourself over it man.
Prevent is offline   Reply With Quote
Old 05-11-2009, 01:36 AM   #25
V6TurboTA
Member#: 9090
09 Forester Gump
this post got me thinking back... waaaaay back.
http://forums.nasioc.com/forums/show...6&postcount=36
BTW I recall when I had just the boost controller and air filter on my 02 WRX I was shifting into 4th gear at around the 1000' mark.
Friday at the Track at Summit Point Raceway cmgolfr212 Member's Car Gallery 16 01-31-2008 07:01 PM
PA/VA: 1 day at the track!!: Friday at the Track (FATT) for sale ybnormal07 Private 'For Sale' Classifieds 1 06-13-2005 06:39 AM
UPDATE: 2nd time at the track Cobb Stage 2. 1st time was 14.0 at 96mph elhalisf Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 11-15-2004 09:10 PM
I suck at driving ;) first time at the track overdose Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 08-21-2004 02:31 AM
Another day at the track for the RS. JayP Motorsports 5 04-24-2001 07:25 PM
