Old 05-02-2009, 06:18 PM   #1
jdmSpecC760
Member#: 151598
04 Flared STi
IG: @dallas_dunn
Default JDM projectors Hids and high beams!
i just got the jdm hid projectors and could not find oem ballast so i ran with a aftermarket kit 4300k and wired them in and wired in my 9005 high beems but when i use my highs my Hids turn off is there a way that i can run both togeather ????
let me know if theres a way to do this
thanks...
jdmSpecC760 is offline   Reply With Quote
Old 05-02-2009, 08:19 PM   #2
Spore
Member#: 100117
2009 Impreza 2.5i
Satin White Pearl
http://forums.nasioc.com/forums/show...65&postcount=6
Build a wiring harness like this one and it will solve your problems.
Spore is offline   Reply With Quote
Old 05-02-2009, 08:35 PM   #3
FourOnTheFloor65
Member#: 106225
02 WRX STied PSM
03 L, 05 GT Legacy Wagons
That harness will let your HIDs stay on when your high beams are on but if your lights are off and you pull back on the selector switch to flash your high beams on and off like to pass someone, the HIDs and highs will both flash. This is terrible for the HID components. It won't hurt newer OEM ballasts but cheap kit ballasts will probably hate this. OEM or aftermarket bulbs both will be killed quickly doing this.
To fix this route a wire from the 85 ground terminal on the top relay (the one used for the low beams), to the inside of the steering column and wire it into the headlight switch directly. Do not ground it like the diagram shows. You will need two small diodes to do this. Here is a thread about what to do with some pics.
http://www.scoobymods.com/forums/wir...eam-t2404.html
FourOnTheFloor65 is offline   Reply With Quote
Old 05-08-2009, 03:07 PM   #4
jdmSpecC760
Member#: 151598
04 Flared STi
IG: @dallas_dunn
any other optoins?
Using low and high beams JDM projectors Ryan314 Electrical & Lighting 6 10-21-2009 11:30 PM
hid morette, fog and high beam problem chadt02 Electrical & Lighting 2 12-22-2007 10:15 PM
STI HID Bulb, High Beam Bulb, Blinker Bulbs and Harness PIGGY Private 'For Sale' Classifieds 39 07-09-2006 08:39 AM
Help A.S.A.P blew left 06 sti hid and high beam stevos758 Electrical & Lighting 3 06-23-2006 11:51 AM
NEED HID looking fog and high beam bulbs to match IA Performance Interior & Exterior Modification 8 11-07-2002 05:14 PM
