Old 05-02-2009, 08:03 PM   #1
blernin41
Member#: 200321
2009 Forester 2.5XP
Armpit Green
Default Fifth Gear Grind
Didn't get any bites in the driveline forum, so here I am. About once every ten times I try to shift into 5th above 80mph, the gear grinds and I have to force it in. Thinking maybe either my shifter is loose (kartboy + F/R bushings) or the 5th gear sync is damaged.
Any thoughts?
blernin41 is offline   Reply With Quote
Old 05-03-2009, 12:13 AM   #2
watchunglava
Member#: 168862
2007 ej253n/a 5speed
Red Sox Nation Lifer
arent you under warentee?
anyway try changing your gear oil and see where u stand
watchunglava is offline   Reply With Quote
Old 05-03-2009, 12:56 AM   #3
blernin41
Member#: 200321
2009 Forester 2.5XP
Armpit Green
definitely under warranty. prolly gonna take it to the dealer as long as it's free. otherwise, Ill try to fix it myself.
Old 05-03-2009, 01:01 AM   #4
piker28
Member#: 22664
Considering you have the shifter in bushings, those would both affect your warranty. So tread carefully. First I would double check what you did, make sure its all tight, than if that does not work remove all the stuff and see if it happens stock... than take it in
piker28 is offline   Reply With Quote
Old 05-03-2009, 09:46 AM   #5
blernin41
Member#: 200321
2009 Forester 2.5XP
Armpit Green
well stock bushings are toast. pretty much had to cut them out. I'll get under my car next week and see in anything is catching. maybe I'll swap in the stocker.
Old 05-04-2009, 02:50 AM   #6
God
Member#: 148482
2085 CRYSMORE
LE BARON
half the time when i drop into 4th gear, even with a rev match it just locks me out and i cant get into 4th unless i put it back into neutral and then go in again. its really annoying.
God is offline   Reply With Quote
Old 05-04-2009, 02:57 AM   #7
watchunglava
Member#: 168862
Definatly change your tranny oil. I use amsoil severe gear 75-90 you'll need 3.7 qts for the tranny and .8 qt for the rear differential.
You'll need a torx 70 socket for the tranny . The rear diff opens using a 1/4 socket wrench.
Fifth Gear Grind blernin41 Transmission (AT/MT) & Driveline 1 05-02-2009 02:40 PM
Was watching top gear/fifth gear videos and wonder if this shift is correct. XyKo Newbies & FAQs 5 05-19-2006 11:10 PM
Fifth Gear / Top Gear Lever2ooo Off-Topic 2 10-18-2004 06:49 PM
Top Gear vs. Fifth Gear dr_wheel Off-Topic 31 09-23-2004 06:31 PM
Top Gear (not Fifth Gear like I last posted) Vid of EVO 8 vs STi Impreza01 STi Forum Archive 37 06-22-2003 01:46 AM
