Old 05-03-2009, 08:02 AM   #1
INFMIS
Member#: 174494
Default project RA - 10seccond build, with pics
so.. purchased a gc8 sti RA bone stock, pulled her off the road and the project began..
18months later I am nearing completion..
check out the pics, and drop me a comment!
INFMIS is offline   Reply With Quote
Old 05-03-2009, 08:34 AM   #2
Clarque
Member#: 94195
poop in pants.
sexy.
more poop in pants.
more pics please.
-Ryan
Clarque is offline   Reply With Quote
Old 05-03-2009, 10:50 AM   #3
MartinSTi05
Member#: 145145
2006 wrx STi
Looks great. My only question is what are you going to do about headlights since the boost tubes seem to be running through the openings?
MartinSTi05 is offline   Reply With Quote
Old 05-03-2009, 11:44 AM   #4
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
looks just like a staight strip car, there for who needs lights
seanathanq83 is offline   Reply With Quote
Old 05-03-2009, 05:27 PM   #5
godforbid67
Member#: 137168
06 Built SGM WRX
35r, PPG, 280's, PSS9.
Ummm when you say ten seconds you really mean 9 right??
Is that a 35r??? ATP?
godforbid67 is offline   Reply With Quote
Old 05-03-2009, 07:23 PM   #6
CKxx
Member#: 33458
Your BOV sounds lame
93 RX7+09 Forester
Looks like the GT3076R sitting next to me. Although, that is a beast fuel system for a 30r. I dig it.
ETA: I can't stop staring at this car. It's awesome.
EXTRA EDIT: If you plan to run w/o an intake filter, you may want to relocate the (in your case) driver side head breather. I'm no expert, but I've witnessed those things on a dyno, even with the little filter, blowing out all sorts of foul junk. You wouldn't want it getting sucked right back in when that is exactly what you are trying to avoid.
CKxx is offline   Reply With Quote
Old 05-03-2009, 07:57 PM   #7
INFMIS
Member#: 174494
thanks for the comments..
turbo is a Garrett gt3076r - reason behind this is that i want to be able to drive on the track, strip and street.
and if you look closely you can see that i have cut out a piece of metal below the headlights so that they still fit up perfectly, same with the bumper, grille etc. etc.
the car has a cert, warrant of fitness, registration etc. so it is fully street legal.
Old 05-03-2009, 10:13 PM   #8
jnprn2003
Member#: 142015
2007 STI/Speed3
OBP/SSM
Nice...very Gobbstopper esque.
jnprn2003 is offline   Reply With Quote
Old 05-04-2009, 08:20 AM   #9
INFMIS
Member#: 174494
my inspiration..
Old 05-04-2009, 09:20 AM   #10
Thomas Ruble
Member#: 12694
02 WRX/JDM EJ207RA
Unabomber Eeee-thug
I love the combination of having an all around performer.. Very clean work INFMIS. I realy like the aluminum radiator expansion tank. Did you have this fabricated just for you? What inlet manifold is that?, WRC or shaved GC8? The plenum looks like a WRC inlet.. I fabbed up my own external fuel pump/surge tank too. What brand pump is that, Bosch?
Great job!
Tom
Thomas Ruble is offline   Reply With Quote
Old 05-04-2009, 12:12 PM   #11
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
very beautiful man.
D Money is offline   Reply With Quote
Old 05-04-2009, 08:02 PM   #12
INFMIS
Member#: 174494
Tom
Thanks for the comment.
The radiator expansion tank i had fabricated myself, i drew the plans and then my friend made it up for me.
The intake manifold is a 1995 wrx sti RA manifold. I cut off the ISC valve housing, the 5th injector housing, and all the brackets, then shaved it down to a smooth finish, and painted it gloss red. The inside of the manifold was then port matched to my heads. it was a time consuming job but i am pretty happy with the outcome.
Here is a pick of the same manifold being worked on.
The fuel pump is a Bosch 040 (motorsport).
Overall the car weighs 1,097kg's and has 350kw ATW
Old 05-04-2009, 08:19 PM   #13
hustleshark206
Member#: 182227
2000 MPS Built RS
1991 Leggy Turbo EJ22t
Originally Posted by INFMIS View Post
my inspiration..
Now THATS a turbo
Awesome build man. Good luck breaking into the 10's
GC FTW!
hustleshark206 is offline   Reply With Quote
Old 05-05-2009, 08:07 AM   #14
JDMFLCL
Member#: 180513
Baby Baby C'mon!
Looka Bomba! 99 JDM GM8
very nice buid
the EJ20g intake manifolds are some of hte highest flowing subaru plenums EVER and are very similar to the WRC unit.
JDMFLCL is offline   Reply With Quote
Old 05-06-2009, 04:13 PM   #15
RSTIdude
Member#: 208910
00 RSTI
white
Originally Posted by JDMFLCL View Post
very nice buid
funny i have heard the same thing i guess its true !!!
btw nice work man keep us posted
RSTIdude is offline   Reply With Quote
Old 05-14-2009, 06:56 PM   #16
CKxx
Member#: 33458
93 RX7+09 Forester
What TB did you use for that intake manifold?
If you used the one that came with the 20G intake manifold, what was involved in the TPS sensor attachment, or other bits?
Also, what heads are you using? I was looking at buying an EJ20G manifold, but it looks like the footprint is different than an EJ205 head.
Old 05-19-2009, 08:55 AM   #17
INFMIS
Member#: 174494
Throttle body used is the stock item that came on the 1995 STI manifold, same with the TPS sensor, so fitting the throttle body was easy!
I am using Version 3 STI heads (ej20), the footprint was much the same however the bolt holes didnt line up so i drilled the bolt holes waay bigger so that it fit.
Old 05-20-2009, 10:39 AM   #18
chrisarella
Member#: 35584
1965 FFR Roadster
Coyote + TR-6060
Really nice. The header tank looks trick. Any concerns about response being effected the sharp turn of the IC pipe at the turbo? And I know that oil cooler location is pretty standard but I'd be worried about flow to the radiator... especially with that GIGNORMOUS intercooler. Maybe you should consider moving it down to one of the Fog light locations and keep the cover off. Or if you're keeping the factory hood you can relocate the oil cooler to firewall with a fan in front of it. And yet another option would be to get a Fluidyne Enduro All-Season Fluid Coolers. They have an 11-inch electric fan mounted directly to them, enclosed in shrouding to maximize airflow through the cooler core, and because they're self-contained they don't have to be situated in direct airflow. So you can mount them in just about any remote location.
My $0.02.
chrisarella is offline   Reply With Quote
Old 05-20-2009, 03:39 PM   #19
Jim2752
Member#: 147610
2007 Stage 2 STi
Can someone translate this?
Jim2752 is offline   Reply With Quote
Old 05-20-2009, 03:42 PM   #20
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
2,418lbs, 470whp
alcoolaid is offline   Reply With Quote
Old 05-21-2009, 03:26 AM   #21
subyswamper
Member#: 91049
2008 wrx wgn
charcoal grey
Pure sex. I love that car!
subyswamper is offline   Reply With Quote
Totaled 2006 WRX repair project ''DIY style'' Journal with pics scoobydoo666 Member's Car Gallery 97 06-07-2010 12:54 PM
My build with pics... reddevil Built Motor Discussion 43 10-08-2007 11:25 AM
World One Project GTR Build Up Pics.. WorldOne Member's Car Gallery 140 11-25-2004 08:51 PM
Subaru building with STI RA Gears bline Transmission (AT/MT) & Driveline 0 04-03-2004 11:04 PM
99 STI Type RA for sale (Japan) With pics Greg555 Mid West Subaru Owners Club Forum -- MWSOC 23 12-11-2000 08:31 AM
