Old 04-28-2012, 09:19 AM   #3326
waynoSTI
Member#: 162151
2.6L BLUE THUNDER
LOW&WIDE&SHAVED
Thx do the pics mate! That's exactly how I pictured it, I also brought the vibrant stack to go into my headlight! I guess I won't be the first to do that now. Lol
Car looks great, do you have a pic of the ducting from the headlight to the turbo please. I have 4" 45 and a 4" straight not sure if that's all I need?
Cheers
waynoSTI is offline   Reply With Quote
Old 04-28-2012, 12:18 PM   #3327
biknman
Member#: 47915
2003 GG HC TT
GG-RC 08STI 16OB 96GC2dr
Cheers
Below is pic of how it looked. I'm changing it up quite a bit since I'm in the process tubed the front of the car from the strut tower forwarded and changed the orientation of my radiator in my v-mount set up. FYI to get the intake and high pressure side of the turbo to line up so that there was minimum bends and the shortest tubes possible along with keeping the turbo as low as possible was an interesting journey :-). A v-band on the up pipe and down pipe connection made it all very easy to clock the turbo just right. Note I used some 3" flexible brake duct cooling tubing / hose for making the flexible piece of the intake to the turbo inlet as it was to difficult to get a silicone hose in and out easily. Well running 24psi I sucked in some of the damn brake cooling hose after it slip out from under the t-bolt clamp because I had clamp it to tight and crushed the aluminum tube that it attached to running though the headlight housing to the velocity stack. My new design I'm going to try and replace the whole headlight area with one big intake funnel down to 4" or 5" then in too an plenum / housing made from either thin sheet aluminum or high density plastic which will house a proper K/N filter (the below set up only has some SS screen in the VS for a filter) that fits over the outer edge of velocity stack (around 6" OD) with a 4" ID which will in-turn smoothly transition down to 3" at the turbo inlet giving the air velocity effect as much as possible into the turbo, much like WRC does it (without the resistor) along with doing the same similar effect from the FMIC into the throttle body. :-)
The old way I was moving air though:
The new way I'll be flowing the air using thin aluminum sheeting (for use as home HVAC ducting it can be cut with regular craft scissor and tape it together with aluminum tape) to form the ducting into the rad and IC from the bumper openings then out the hood. Air is lazy it's got to be forced though stuff :-) Will keep air from the underneath the car also for better aero effects.
biknman is offline   Reply With Quote
Old 05-01-2012, 11:10 AM   #3328
tino
Top Scoob 019
Member#: 43630
2004 GT40R-built 2.5
604 whp @1.8 BAR on VP109
I thought it was the other way around that the hood scoop caused the high pressure and effected the cooling of thus rad?
I'm going to cut ducts in the headlights I brought maybe that will push the air out of the kstech ?
Wayno u can still run the hoodscoop just blank it off from the bonnet. This us what the WRC carshave done..however if u run a shroud to thvent like what I've done it shouldn't really be too much of am issue
tino is offline   Reply With Quote
Old 05-02-2012, 12:24 PM   #3329
waynoSTI
Member#: 162151
2.6L BLUE THUNDER
LOW&WIDE&SHAVED
Pics look great, thx guys. I think i'll be fine with the way i'm going to route mine.
Old 05-02-2012, 01:03 PM   #3330
biknman
Member#: 47915
2003 GG HC TT
Let see some pics when you do it. I always like looking at pics of race car fab work. :-). I don't know what I enjoy more working on them or racing them guess it’s the combination of both .
Old 05-03-2012, 12:33 AM   #3331
waynoSTI
Member#: 162151
2.6L BLUE THUNDER
LOW&WIDE&SHAVED
Originally Posted by biknman View Post
Let see some pics when you do it. I always like looking at pics of race car fab work. :-). I don't know what I enjoy more working on them or racing them guess itís the combination of both .
For sure, i always post pics of my progress. I actually love working on my car, it's a hobby not work for me. I can relax when i'm in my garage and take some time for myself Until my kids come out to help then they jump on there bikes and there goes quite time with the car
Old 05-05-2012, 11:25 AM   #3332
DZKSTI
Member#: 116670
02 wrx/sti
black
Im in total agrement with ya on the relaxing time when working on your own car. And than the kids come. My daughter always wants to help. So than im always making sure she is ok.
DZKSTI is offline   Reply With Quote
Old 05-12-2012, 11:33 AM   #3333
waynoSTI
Member#: 162151
2.6L BLUE THUNDER
LOW&WIDE&SHAVED
Just incase anyone is interested in the sickest door pannels ever made.
http://forums.nasioc.com/forums/show...1#post37122251
Old 05-16-2012, 09:26 PM   #3334
waynoSTI
Member#: 162151
2.6L BLUE THUNDER
LOW&WIDE&SHAVED
My car just got a lot cooler today. huge thanks to my man D$ for a sick deal on his old Setrab oil cooler core, earls -10an fittings/line wrapped in earls heat proof wrap, & Mocal oil sandwich plate w/built in thermostat, & custom JM Fab bracket (chrome dipped)
Old 05-16-2012, 10:00 PM   #3335
25rsti
Member#: 166324
Hooking up bros all across the the world!
Old 05-16-2012, 10:48 PM   #3336
Serkan
Member#: 180514
2004 Sti
Hey Wayne,
Is that the Kakumei hood vent for 02-03 ?
I will be going with V-mount setup and I always wondered if that fir 04-05 hood.
Serkan is offline   Reply With Quote
Old 05-17-2012, 09:07 AM   #3337
waynoSTI
Member#: 162151
2.6L BLUE THUNDER
LOW&WIDE&SHAVED
Yep lol!
Originally Posted by Serkan View Post
Hey Wayne,
Ya it's for the 02-03! Should look good once I moldit in, I'm going to try and duct it with the duct attached to the hood so when I pop the hood it still looks clean!
Old 05-25-2012, 11:47 PM   #3338
waynoSTI
Member#: 162151
2.6L BLUE THUNDER
LOW&WIDE&SHAVED
Installed my oil cooler today. it went well after a phone call to D lol. I love buying stuff off him, he thinks of everything and always has all the bases covered.
He made a this nice little bracket so the lines don't drag on the floor and it keeps them all nice and tidy
Old 06-05-2012, 10:58 PM   #3339
waynoSTI
Member#: 162151
2.6L BLUE THUNDER
LOW&WIDE&SHAVED
Got my WRC carbon door panels today, but since all the bigdawgs are holding out on pics i guess imma gonna do the same
Old 06-05-2012, 11:00 PM   #3340
brcewane
Member#: 63990
Flat Grey
Tease
brcewane is offline   Reply With Quote
Old 06-06-2012, 09:02 PM   #3341
waynoSTI
Member#: 162151
2.6L BLUE THUNDER
LOW&WIDE&SHAVED
^^^It was to late for pics Tim haha
i
Old 06-06-2012, 09:11 PM   #3342
waynoSTI
Member#: 162151
2.6L BLUE THUNDER
LOW&WIDE&SHAVED
So i got the new door panels mounted today, had to cut a fair bit out for the 05 switches to work. All in all turned out really good, now the interior matches the rear seat delete and i can run a cage down the road as these door cards clear all cages.
Old 06-06-2012, 09:14 PM   #3343
StealthWRX
Member#: 50175
2 Bugeyes
'11LGT '16FXT
^haha the hold out on pics didn't last long! Looking good man, I love my set, they've held up extremely well over the past few years. And I had the same issue with needing to trim out for master switch.
StealthWRX is offline   Reply With Quote
Old 06-06-2012, 09:25 PM   #3344
waynoSTI
Member#: 162151
2.6L BLUE THUNDER
LOW&WIDE&SHAVED
LOL i just didn't have time to work on the car last night so i thought i'd tease y'all
what did you mount yours with? self tappers?
Old 06-07-2012, 12:09 AM   #3345
StealthWRX
Member#: 50175
2 Bugeyes
'11LGT '16FXT
^yep exactly
Old 06-07-2012, 03:38 AM   #3346
domestic_abuser
Member#: 126696
2002 Fatbody bugeye
03 R1 09 Raptor 700R
I liked the old panels better!
domestic_abuser is offline   Reply With Quote
Old 06-07-2012, 10:29 AM   #3347
waynoSTI
Member#: 162151
2.6L BLUE THUNDER
LOW&WIDE&SHAVED
^yep exactly
Cool thx
ya me to bro, but they didn't clear the cage I want to get so I had to unload them for these!
So what's going on bro, it's been a while man! You still working on the bug?
Old 06-07-2012, 10:31 PM   #3348
tino
Top Scoob 019
Member#: 43630
looking good wayno..
i actually like these ones better than the old ones.. You should have cut a smaller opeing for the switches and cut down that switch panel to only have the switches and not all that other ****.. would make it cleaner i rekon..
Old 06-07-2012, 10:43 PM   #3349
russgt
Member#: 256322
Agreed. The pocket is crap.
Cards look nice though
russgt is offline   Reply With Quote
Old 06-08-2012, 01:01 PM   #3350
ScoobyJD
Member#: 185910
2007 FSXT
looking good bro! Thank you for all your help these last past two weeks! Now it is time to get my butt down to the ocawdmeet so I can get these parts and take this dj equipment down there for them to use! Every one is wishing you could have come down here!
ScoobyJD is offline   Reply With Quote
What do an M3, S2k, MX-5, and WRX have in common? rogue Mid Atlantic Impreza Club -- MAIC 10 11-10-2004 07:05 PM
What do Carrie Bradshaw, Immelda Marcos, and Janq have in common? Janq Off-Topic 117 09-17-2004 01:49 AM
What do Carrie Bradshaw, Awdity, and Janq have in common? Janq Off-Topic 40 08-30-2004 12:47 AM
What do David Letterman and I have in common? Mr.Freeze Mid West Subaru Owners Club Forum -- MWSOC 17 05-02-2003 11:08 AM
What do the MRT cat and Chernobyl have in common? Julian Normally Aspirated Powertrain 2 09-23-2002 07:09 PM
