Old 05-03-2009, 06:02 PM   #1
Barnacules
Member#: 170018
2005 WRX STi
Default Low Boost on 05 Cobb STI Stage 2
I have not been paying attention to my boost guage for some time now however the car has felt a little sluggish lately so I was watching the boost guage to red line a few times and I'm only hitting 0.07mpa (~10psi). This is with a Stage 2 map installed. It also seems like its slow getting form 0.05 to 0.07. I suspect I might have a boost leak somewhere or maybe an exhaust leak or something. Anyone have any input on what I should do to diagnose the problem? I would like my car to get its boost back. I've also got the Cobb Stage 2 access port map on it so as I understand it I should be pushing around 17psi so I'm suffering a pretty huge boost loss right now. Should I try the Cobb map for cars that are experiencing underboost? I have not tried this yet.
Barnacules is offline   Reply With Quote
Old 05-06-2009, 08:49 PM   #2
Barnacules
Member#: 170018
2005 WRX STi
I hooked up the Access Port and datalogged on my drive home today and wt WOT redline I'm only getting 12.0psi of boost, The map I'm running says it hsould get ~17. I think I'm leaking boost somewhere but I'm not sure where? Does anyone have any ideas where I should start checking other then that obvious. Also does anyone have a leak tester in the Duvall, WA area I could borrow to try and track this down. 10 PSI is less then a stock STI and its killing me having to drive the car this way
Old 05-31-2009, 10:36 PM   #3
northshore
Member#: 211256
2005 Blue WRX
COBB Stage 2
I would suggest trying what COBB recommends:
Adjusting the facotory boost control
http://www.cobbforums.com/forums/showthread.php?t=32552
and
Verify your car is properly maintained. Oil change, spark plugs, fuel filter, etc.
northshore is offline   Reply With Quote
Old 05-31-2009, 10:48 PM   #4
yamahaSHO
Member#: 73932
2005 STi BROtuned
2004 S2000
You said at redline you're getting 12 PSI? Isn't it supposed to taper off by then?
yamahaSHO is offline   Reply With Quote
Low boost on 05 Sti chaingangsoldier Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 06-03-2007 10:26 AM
COBB STi Stage 2 SirWilliam Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 07-18-2005 11:11 PM
Cobb STi stage 2 results jlp7t Proven Power Bragging 7 04-04-2005 03:23 PM
FS: 2/3's of a Cobb STi Stage 2 kit Mach5WRX Private 'For Sale' Classifieds 15 09-16-2004 04:15 PM
Anyone have the low down on the Cobb Access STG 2 boost spikes? waitandbleed92 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 05-09-2003 11:58 AM
