Old 05-04-2009, 10:09 AM   #1
Max Umbarger
Member#: 1112
2006 FXT
RBP
Default Blowing wiper fuse when launching...
After some searches I couldn't really relate my problem to others. When taking off hard, my radio will shut off momentarily and turn back on and continue to play. It also resets my radar detector which is hard wired into the radio power harness. The main issue tho is my wiper fuse will blow. I can't use the wiper or washer at all, but the radio, radar detector work. When I replace the fuse i get my wipers back.
I know its a short, but I just want to see if I'm overlooking anything before I drive 80 miles to take it in to get checked. If it's blowing fuses when I launch it must be a wire moving right? Also note that I just had the motor pulled - head gaskets done a month ago, so could it be in the engine bay?
I spent 2 hours last night pulling the dash apart and checking for loose connections. I had the whole radio console out as well. while I was there I dressed any loose wires, taped a few things to be more secure and I still have the problem.
Knowing this, the radio and the wipers are on a different circuit but they must be connecting right? or something with the same grounding/power source...
Any help would be great, really would like to see if it's something I can handle before I try and take it in for service.
Max Umbarger is offline   Reply With Quote
Old 05-04-2009, 12:00 PM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
I assume this trouble started happening after the service work. I would check for the trouble under the hood. Look for wires touching the exhaust system or pinched wires near the fire wall.
Cougar4 is online now   Reply With Quote
Old 05-04-2009, 01:48 PM   #3
Max Umbarger
Member#: 1112
2006 FXT
RBP
I certainly will be looking under the hood. I have focused a lot inside. Thanks
Old 05-06-2009, 12:36 AM   #4
DeathSStar
Member#: 202982
Did you tap that circuit for anything?
DeathSStar is offline   Reply With Quote
Old 05-06-2009, 01:14 PM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
check the battery terminals
check all the grounds....especially the one that goes from the trans to the pitch stop mount on the firewall
Old 05-11-2009, 04:23 PM   #6
Max Umbarger
Member#: 1112
2006 FXT
RBP
Checked them all except for the pitch stop to firewall. This one makes the most sense because of the 'only upon acceleration' issue. Should get to it tomorrow. Any more suggestions feel free. I'll let you know...
wiper fuses blow everytime i turn my car on LookAsubie Electrical & Lighting 6 02-11-2010 12:29 PM
Can i use the rear wiper fuse as a source to tap +12 Switched for my gauges? 03WRXMA Electrical & Lighting 8 01-14-2010 11:03 AM
Rear Wiper Fuse in 02 WRX Sedan, what does it do? ogboot Electrical & Lighting 7 01-14-2010 09:39 AM
Windshield wiper fuse blown.. crp Baja Forum 1 05-24-2005 04:51 PM
Help..Keep blowing fogs fuse AdsWRX Electrical & Lighting 3 06-16-2003 11:41 PM
