Welcome to the North American Subaru Impreza Owners Club Sunday October 23, 2016
Old 05-04-2009, 02:11 PM   #1
Member#: 209833
Default EJ22 Turbo Engine Rebuild help EJ22T
Hi all,
Im not sure if I remember enough to put this engine back together. My first complete rebuild and between this and all the other bazillion things I have going on. Im just not sure. I'm gonna give it a try. Below is a pic of everything back from the shop or cleaned up by yours truely. I am open to all help and direction as I go through this process. A couple initial questions if anyone can help.
1. Some, not all, of the case bolts had rubber/metal washers. I soaked these bolts/washers in carb cleaner and it ate away at the rubber. I thought washers would be included in my full rebuild kit. Maybe they are and I am missing something. Why are there washers on some of the bolts and not others? Are these washers only on bolts that come in contact with wather passages?
2. Can case bolts be reused? Im actually not sure of the original positions of them all.
hotdogpimp is offline   Reply With Quote
Old 05-04-2009, 10:55 PM   #2
Meat Supply
Member#: 137902
---- among the
lost we all shall survive
nice intercooler! what car is yore motor out of?
Meat Supply is offline   Reply With Quote
Old 05-05-2009, 09:45 AM   #3
Member#: 209833
The motor is from a 93 legacy but I bought the intercooler Seperately.
Old 05-05-2009, 11:20 AM   #4
Member#: 4800
1990 Legacy & 97 OBS
You can reuse the case bolts. You need the metal/rubber washers. They do come with the OEM gasket kit. If not, you should be able to get them from the dealer.
Here are pictures from my ej22t rebuild
This group has pictures from gasket kit.
Legacy777 is offline   Reply With Quote
boosting on an ej22 shortblock not a ej22t sime Normally Aspirated with bolt-on Forced Induction Powertrain 10 09-11-2014 06:05 PM
Turbo Rebuild Help!!! wrxwagon1992 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 01-07-2010 09:40 PM
fpgreen turbo rebuild. wanted turbo rebuilders Hayaboosted Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 02-22-2008 10:41 AM
Ej22 engine rebuild runninstrong Legacy Forum 2 01-05-2007 01:59 AM
EJ22 non-turbo same as EJ22T block? SJwrx Normally Aspirated Powertrain 1 04-16-2004 02:36 PM
