Old 05-04-2009, 03:56 PM   #1
luka
Member#: 194742
1993 Impreza WRX JDM
Default Blown Rear Wheel Bearing / Hub
hey guys,
I'm drivin' a '93 WRX. Been searching for a while and it it looks this repair job is going to cost me a pretty penny... But since I'm more broke than the bearing itself I need some cheap alternatives...
Does anyone know if there is anything USDM (Leggies, '02 WRX, etc) that have the same knuckle assembly? from the looks of it it might be a cheaper alternative to grab the entire assembly from a junker than getting the bearing fixed/hub replaced.
Remember, I'm completely broke. I don't care if it's not *best* solution. I just need something.
Thanks,
luka is offline   Reply With Quote
Old 05-04-2009, 05:46 PM   #2
elislider
Member#: 133923
03 Legacy GT wagon
I love goooollllllllddddd
pre-00 legacy or any impreza (non sti) should have compatible hubs. note i say compatible. theres a lot of differences in splines on the hubs between years. i dont know whats on your wrx as far as rear diff, axles, or hubs, but my guess would be 90-96 year range of impreza or legacy with AWD and rear discs would swap over. check for ABS or nonABS as well
elislider is offline   Reply With Quote
Old 05-04-2009, 05:57 PM   #3
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
do you have 2 pot rear brakes
if not
legacy 89-99
impreza 93-07
forester 98-07
Old 05-04-2009, 08:41 PM   #4
elislider
Member#: 133923
03 Legacy GT wagon
jaxx is correct for bolt-up compatibility, however to keep your existing axles youll need to be more specific to your year range to get the # of splines right. they range from 22 to 26 depending on years
EDIT: neeeevermind i was thinking of the splines on the diff side. the hubs are all about the same, they did change in 00 on the legacy which is why for legacies it just goes to 99
Old 05-05-2009, 06:49 PM   #5
luka
Member#: 194742
Thanks for the info guys,
turns out not even a 25ton press will get the axle out of the hub
anyone know which axles will work? I'm guessing early LSD leggies?
Old 05-05-2009, 06:59 PM   #6
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
eeeek
thats not so common .. use heat you need that axle the early jdm axles are unique
Old 05-05-2009, 07:21 PM   #7
luka
Member#: 194742
Originally Posted by Jaxx View Post
eeeek
... Unique as in... one of a kind? :/
Old 05-05-2009, 07:49 PM   #8
luka
Member#: 194742
can I use the hub side of a leggy and then my diff side/core or does that not work?
Old 05-06-2009, 07:32 AM   #9
johnkaldar
Member#: 51047
1999 gc8 RS/sti-ra
a bearing and seals are less than $100 and you should be able to find a shop that can press them out and in. They are easy to do.
johnkaldar is offline   Reply With Quote
Old 05-06-2009, 03:17 PM   #10
elislider
Member#: 133923
03 Legacy GT wagon
unique as in if you have a mechanical LSD then the axles are different Left vs Right and one side has an extra splined nub on the diff side. hardly any were ever like that so its really hard to find a replacement axle
Old 05-07-2009, 09:32 AM   #11
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
probably
Old 05-07-2009, 12:33 PM   #12
elislider
Member#: 133923
03 Legacy GT wagon
should work as long as the legacy is pre 99 model year
Wheel bearing/hub problem.. Luizwrx Brakes, Steering & Suspension 6 06-04-2009 02:03 AM
02 wrx wheel bearings/ hub ASAP temallica1 Private 'Wanted' Classifieds 1 12-01-2008 04:36 PM
rear wheel bearing/hub help need'd. please GripGC8 Mid West Subaru Owners Club Forum -- MWSOC 17 01-13-2007 12:10 AM
Wheel bearing/hub replacement cost? lotusTT Service & Maintenance 9 05-11-2005 03:17 AM
So what exactly happens when your wheel bearings/hubs fail? root Brakes, Steering & Suspension 10 12-04-2004 03:22 PM
