Old 05-04-2009, 05:47 PM   #1
MyOtherRideIsUrMom
Member#: 159636
2007 WRX WRB-18G EWG
2014 Outback LTD ISM
Default Where To Find Replacement Electrical Connector (IAC)?
I was doing work on my car this weekend and noticed that the electrical connector on the wiring harness for the Idle air control valve was completely broken. The three pins inside the plastic connector are still connected, but very little plastic is left. Does anyone know where I can buy a replacement plug?
Thanks
MyOtherRideIsUrMom is offline   Reply With Quote
Old 05-05-2009, 05:20 AM   #2
thunder_lizard_1976
Member#: 145642
2007 WRX Ltd
Cuz Chicks Dig The Wagon
The dealer may make a harness repair kit for that connector; you just have to make sure of a good solder job on the connections.. If not, you're likely looking at a yard piece... and just about everyone, save the u-pull-it places, usually frown upon cutting up an engine harness
thunder_lizard_1976 is offline   Reply With Quote
Old 05-05-2009, 12:01 PM   #3
MyOtherRideIsUrMom
Member#: 159636
crap. not really what i wanted to hear, but kind of expected. Can anyone check their IAC harness connector and see if it has some kind of code or part number molded in? Also, anyone know any U-Pull it junkies with subarus in the tri-state?
Thanks
where to find MAP sensor connector? berdugo Other Engine Management 6 08-06-2009 10:09 AM
Where to purchase replacement init connector for 04 WRX? jaybert AccessPort 5 10-02-2006 01:55 AM
Where to find replacement bush. for KBoy rear droplinks frederik Brakes, Steering & Suspension 1 09-09-2005 09:03 PM
Where to buy replacement harness connectors? bryan_johnson Subaru Conversions 4 04-06-2005 12:03 PM
where to find wire harness connectors? erice1984 Electrical & Lighting 0 02-10-2005 11:29 PM
