Welcome to the North American Subaru Impreza Owners Club Saturday August 29, 2015
Old 04-19-2002, 08:47 PM   #1
Hojai
Member#: 2190
Default What should i use?
The fuel pressure of my car is higher than normal, so what should i use to set the fuel pressure?
What do you guys use?
Hojai is offline   Reply With Quote
Old 04-19-2002, 10:17 PM   #2
STiTuner
Member#: 5778
09 135i
Jet Black
Vortech S-fmu
if you have 300 bucks to spend.
some people use the cartech and preset FMU from Vortec or other companies. personally I like the S-fmu. I have one sitting in my garage yet ot be installed but my friend had one on his Turbo EX it was fun to play with to say the least. setable on vacum and boost.
Brad
STiTuner is offline   Reply With Quote
Old 04-20-2002, 02:20 AM   #3
Hojai
Member#: 2190
what is the cheapest way to be able to just adjust the fuel pressure? and also is a fuel pressure gauge really necessary?
Old 04-20-2002, 02:49 AM   #4
Hojai
Member#: 2190
does all vortech FMU fit our car?
Old 04-20-2002, 02:02 PM   #5
JeffY
Member#: 15260
Assume u have an RRFPR, u can use a SVX FPR instead of the factory FPR.
JeffY is offline   Reply With Quote
Old 04-20-2002, 03:54 PM   #6
Hojai
Member#: 2190
b/c i can get a used vortech 10-1 ratio Rising Rate Fuel pressure regulator, just want to know if that is fit?
Old 04-20-2002, 05:00 PM   #7
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
10-1 is WAY too high.... 6-1 and 4-1 are the ones that people use.... I had the 6-1 plate in mine, prior to the most recent build up and it worked very well....
kastle is offline   Reply With Quote
Old 04-20-2002, 08:41 PM   #8
STiTuner
Member#: 5778
09 135i
Jet Black
All vortechs fit. I think most of them use simple AN fittings too.
Brad
Old 04-20-2002, 11:08 PM   #9
Hojai
Member#: 2190
actually people say i should just use SX fuel pressure regulator or Paxton fuel pressure regulator (adjustable fuel pressure regulator), instead of using Vortech Rising Rate Fuel Pressure Regulator b/c i have got a Tec II on my car.
Does all SX or Paxton fit our car?
Old 04-20-2002, 11:28 PM   #10
Hojai
Member#: 2190
should i buy the -AN 10 inlet one or -AN 6 inlet one?
Old 04-21-2002, 12:34 AM   #11
Hojai
Member#: 2190
what is EFI stands for?
b/c i always see EFI regulator and fuel regulator and i don't know which one should i buy
Old 04-21-2002, 08:34 AM   #12
bill harvey
Member#: 10
2005 Legacy Gt wagon
Garnet red pearl
Electronic Fuel Injection
bill harvey is offline   Reply With Quote
Old 04-22-2002, 12:03 AM   #13
STiTuner
Member#: 5778
09 135i
Jet Black
it doesn't matter.. you can get/make adapters either way
Brad
Old 04-22-2002, 01:31 AM   #14
Hojai
Member#: 2190
thanks...
i think i am going to get the Paxton Fuel Pressure Regulator, Adj. 35-90 psi w/ boost/vacuum reference EFI Billet Generic
have you used this for STI seats? or what should i use? Speedster329 Car Care & Detailing 3 05-15-2010 11:26 AM
Oil what should I use? judgegavel Service & Maintenance 4 06-18-2002 04:24 PM
I`m changing my Diff fluid what should i use Wheels Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-11-2001 07:45 AM
What should I use for a RS-T Tranny fluid Jimmy Normally Aspirated with bolt-on Forced Induction Powertrain 16 07-20-2001 03:39 PM
Boost Control!!! What should I use Jimmy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 06-14-2001 11:40 AM
