#1 |
Member#: 52863
RMIC
Vehicle:2007 B7 A4 Silver |
05 sti
tranny was dropped and reinstalled reverse lights workin every gear, but they go off in neutral.
#2 |
Member#: 191495
NESIC
Vehicle:'05 WRB GTX3071R JDM V8 EJ207 USDM 6MT |
open the trunk and move/swap around the reverse and brake bulbs...you should have enough play without having to cut or adjust the harnesses
#3 |
Trust no one
Moderator Member#: 11170
Vehicle:02 WRX 05 GTO/11 Sonata(!) |
The wiring for the neutral and reverse switches on the trans may have been swapped when it was reinstalled. I'm not even certain this is possible with the connectors and switch locations but the symptoms point to it.
#4 |
Member#: 202982
Vehicle:. ...it's like going into Wisconsin |
Either that, or you have a bad reverse light switch. Check into both and I bet one will be your problem. |
#5 |
Member#: 203438
Vehicle:2002 WRX PSM |
any word on this?
I'm having the same problem after I had some synchros replaced...I checked all the connectors on top of the tranny, all of them are connected, and you can't connect them to the wrong ones. Is it possible the switches were installed incorrectly on the tranny? |
#6 |
Member#: 52863
RMIC
I think that it is possible I think thats what was up with ours. I could be wrong. I mean yeah the connectors go white to white and black to black
#7 |
Member#: 107232
Vehicle:2005 sti,05 sti sti obp ,sti wrb |
there is 2 connectors that go into the tranny one white one black. switch them around they were put into the wrong holes.
#8 |
Member#: 203438
awesome! thanks for the confirmation guys.
now, I should have room to do this without having to drop the tranny again, right? ![]() it'll be good to get this back to normal, I think it was keeping my UTEC's launch control/flat shift limiter from working like it should! |
#9 |
Member#: 52863
RMIC
Yeah u shouldnt have to drop the tranny.
#10 |
Member#: 203438
| Thread Tools | |
| Display Modes | |
| Any ideas on this? my reverse light is on when in gear. | impressions | Electrical & Lighting | 7 | 06-27-2009 10:40 AM |
| Reverse lights on in all gears... | Doomsayer | Electrical & Lighting | 7 | 02-17-2009 07:50 PM |
| whining in every gear in my 06 sti | meat_WRX | Transmission (AT/MT) & Driveline | 5 | 07-05-2007 01:23 PM |
| In Dash Brake Light Stays On | lowbudget614 | Brakes, Steering & Suspension | 8 | 12-13-2005 10:14 AM |
| Reverse lights stay on...? | dalemcc | Electrical & Lighting | 8 | 11-28-2004 06:13 PM |
