Old 05-05-2009, 01:57 AM   #1
ncarn8
Member#: 71419
Default pointers for wiring harness swap
Hi guys
I have a JDM N/A legacy, ej20. I also have a V3 STI engine, gearbox. I purchased the Wiring loom (from the same body shape but turbo version) to go in. (All plugs the same apparently, like heater, etc)
Im a bit sketchy on jow difficult it will be to swap the entire loom, ie rip one out and put the other in. Is it that simple, or are there some big areas to watch out for? I have the diagrams, the loom and the car.
Just asking for any advice or tips from those that have fully dismembered their cars for a similar thing.
Thanks
ncarn8 is offline   Reply With Quote
Old 05-08-2009, 02:33 PM   #2
DHRDAN
Member#: 204358
01 2.5RS W/ EJ257
I would try over on www.rs25.com forums for this question. There are a few people over there who have done a leggy swap.
As long as you have the entire wiring diagrams from both cars, it's mainly a matter of using the new ECU and adding in any accessories that you will need that DO NOT have the same plug/pinout.
ie. If the new ECU has a plug for the speedo, and its not the same as the plug on your old harness, you need to cut the new harness and wire in the old plug, or get a new cluster.
DHRDAN is offline   Reply With Quote
Old 05-08-2009, 06:19 PM   #3
Scoobyslack1
Member#: 2780
junk yards rule!
Project FrankenSTien
Exclamation
Is the new harness for the new motor? Will it replace the whole front harness?
Stretch out the harness on the floor & label everything you can find.
Go through and find everything you will need to splice.
Write out what wires go together. It will help keep it straight instead of trying to read the diagrams while splicing.
Also, if the is anything you don't need (AC, ABS, etc.), find those wires and remove them. That will help keep it cleaner.
Scoobyslack1 is offline   Reply With Quote
Old 05-10-2009, 07:27 AM   #4
ncarn8
Member#: 71419
I have started with the labelling. It shouldnt be too hard. Good idea about removing the excess, there will be alot no doubt.
The loom is from the factory turbo version of the legacy body shell, so it should line up. The engine is later model but i have modded older sensors to it, so it should just work. (saying should alot)
I guess if i label identify every plug, and play it slow and methodical it will be time consuming but not brain straining. I just hate wiring, its so easy to get confused.
Cheers
Old 05-10-2009, 11:19 AM   #5
Scoobyslack1
Member#: 2780
junk yards rule!
Cheers
That's why I wrote down all the splicing I had to do.
Most of the sensors should be the same, cam & such.
looking for wiring harness 98 rs 2.5 JDMspecC Private 'Wanted' Classifieds 0 09-24-2006 10:43 AM
source for wiring harness components? cak Electrical & Lighting 0 11-26-2005 10:27 PM
Anyone know where to get some protective wraps for wire harness (against heat)? kgb Vancouver Impreza Club Forum -- VIC 6 09-14-2005 05:11 PM
sti wiring harness swap question White 2.5rs Subaru Conversions 0 08-03-2003 02:50 PM
looking for wiring harness rnyce1 Car Audio, Video & Security 1 07-11-2002 10:22 PM
Message Board Statistics All times are GMT -4. The time now is 05:43 AM.
