Old 05-05-2009, 01:55 PM   #1
AMR
NASIOC Manufacturer
Member#: 171509
News 2008 Subaru STi - STOCK TURBO - AMR 272in/272ex v1 Camshafts!!!
Dyno: Dyno Dynamics (1.0 Correction)
Tuner: AMR
Wheel HP: 342whp (stock 201whp)
Wheel TQ: 420wtq (stock 220wtq)
Vehicle Location: USA
Car Info
Year: 2008
Engine Management: COBB APv2 w/ AMR Reflash
Turbo: STOCK
Intercooler: AMR Top Mount Intercooler (TMIC)
Meth Kit: None
Injectors: AMR 750cc Injectors
Intake/Inlet: AMR BMI Cold Air System / AMR Turbo Inlet Hard Pipe
Headers: AMR Race Headers
Uppipe: AMR Up-Pipe
Downpipe: AMR Catless Downpipe
CBE: AMR Stealth-Back Exhaust
Other Power Mods:
- AMR 272in / 272ex v1 Camshafts
- AMR Electronic Boost Control Solenoid (EBCS)
- Walbro 255 Fuel Pump
Dyno Sheet:
Notes:
We have got alot of request and questions regarding what the stock turbo can do with a set of camshafts. Nothing was changed on the vehicle other than the camshafts and tuning. So here is the results.
We installed out AMR 272in / 272exh v1 Camshafts on a STOCK TURBO 2008 STi. We were very impressed with the results. The turbocharger is pretty much done with the camshafts. Boost hits 21psi and tapers hard to 14psi. The original tune boost tapered from 21psi to 16psi. The turbocharger does is not large enough to produce the air needed upstairs.
As you can see from the dyno sheet. Across the entire RPM band we picked up HP and TQ. Peak torque jumped from 390wtq to 420wtq. Peak horsepower increase by 20hp at 5200rpm but continued to gain and showed a 40hp increase at 5700rpm. No doubt with a larger turbocharger the gains will continue to grow and shine.
AFR: 10.8afr
Octane: Pump Gas (93 octane)
On a side note we will be installing our v1 272/272 camshafts on a 2008 STi equipped with our T60R to show you guys the gains with a larger turbo.
We have two 2008 STi's equipped with our rotated turbo kits that are getting our AMR 278in / 278ex v2 Camshafts as well. I will post that when they are complete.
-Rob
AMR is offline   Reply With Quote
Old 05-05-2009, 02:13 PM   #2
CatfaceType-R
Member#: 81102
very impressive stuff from AMR once again. This is going to change the game up on the chase for the stock turbo STi record
kudos to rob+amr for this interesting data
Let's get some vids up of how it sound, for the w1n, prease..
CatfaceType-R is offline   Reply With Quote
Old 05-05-2009, 02:24 PM   #3
4ST-AIR
Member#: 148681
TBD Looking for STI
Back in the Game!
WOW that is just insane.
Nice work guys.
4ST-AIR is offline   Reply With Quote
Old 05-05-2009, 02:31 PM   #4
Kastley85891
Member#: 127704
2015 Boosted Stang
MAP tuned
Nice man, impressive, how did you AVCS maps change? massivley I assume??
Kastley85891 is offline   Reply With Quote
Old 05-05-2009, 02:38 PM   #5
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
How did the weather conditions compare between pulls?
Equilibrium Tuning is offline   Reply With Quote
Old 05-05-2009, 02:47 PM   #6
Illusive
Member#: 90436
2005 STI
Obsidian black pearl
interesting, i would of figured cams on the stock snail to be a hinderance rather than helping.
Illusive is offline   Reply With Quote
Old 05-05-2009, 02:51 PM   #7
AMR
NASIOC Manufacturer
Member#: 171509
Cool
You are correct. They changed drastically. Settings that I had in there from the previous tune were way off. 3/4 of the tuning session was AVCS mapping. Well worth it though.
We have central air and heat in our facility. The facility stays at a consistent temperature due to our machinery and electronics. But to answer your question there is only a 1-3 degree difference.
-Rob
Old 05-05-2009, 02:59 PM   #8
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
I'm surprised to see the increase in power EVERYWHERE, I would have thought it would have bumped the powerband to the right a bit. Impressive....
Audiosavvy is offline   Reply With Quote
Old 05-05-2009, 03:09 PM   #9
WRX Loki
Member#: 208332
06 Hawkeye Wagon
Red
WoW
WRX Loki is offline   Reply With Quote
Old 05-05-2009, 05:18 PM   #10
C J
Member#: 132587
2006 JrTuned STi
[email protected]
So I have never really thought about doing cams in the the STi before but have done them in Honda's, SBC's, etc.
Does the motor have to come out to do them? I cannot see how you could do it otherwise.
C J is offline   Reply With Quote
Old 05-05-2009, 05:35 PM   #11
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
Is this really on 1.0 CF? I only make like 300whp on 1.0 cf and thats good for low 12's. I would really like to see what this car can do at the track or on the street. It would also be interesting to see what race gas could do for this set-up, obviously with just timing adjustments because the turbo itself is already out of breath.
STi Mikey is offline   Reply With Quote
Old 05-05-2009, 05:38 PM   #12
4ST-AIR
Member#: 148681
TBD Looking for STI
Back in the Game!
I have heard of several techs brag about being able to take the heads off with the engine in, but I know tons of DIY's that can pull the engine out and get the heads off before you can do it with the engine in.
Old 05-05-2009, 05:40 PM   #13
ownnij
Member#: 70459
2002 AW Bugeye ej257
6spd, GT3076R, Alky & EWG
how come not many subarus run 280 cams? is it really not a streetable cam?
ownnij is offline   Reply With Quote
Old 05-05-2009, 05:41 PM   #14
C J
Member#: 132587
2006 JrTuned STi
[email protected]
I see, I guess that makes sense.
Old 05-05-2009, 05:44 PM   #15
unclemat
Member#: 114530
2005 LGT 6MT wagon
AMR, with their miracle dyno delivers another "proven" power increase!
From 201 whp stock to 342 whp... on stock turbo without meth. Yeah, right.
(the gains from cams might be real, no argument here)
unclemat is offline   Reply With Quote
Old 05-05-2009, 05:45 PM   #16
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
Agreed.
Steve.804 is offline   Reply With Quote
Old 05-05-2009, 08:02 PM   #17
az03wrx
Member#: 106220
oops.
az03wrx is offline   Reply With Quote
Old 05-05-2009, 08:28 PM   #18
LatentWagen
Member#: 50315
0806 LGTspecB & Saab
9-2xAero5MT DGM & MBP
so you drastically change the cam profiles, and the dyno graph looks like you turned up the boost 4psi? spool is better? huh?
LatentWagen is offline   Reply With Quote
Old 05-05-2009, 08:43 PM   #19
cpturbo
Member#: 49175
2004 STI
Please send these to another independent, non-biased shop for confirmation of these results. We are waiting. Seems too good to be true.
cpturbo is offline   Reply With Quote
Old 05-05-2009, 09:50 PM   #20
Deuce Cam
Member#: 130444
'85 AE86 GTS
Chapter 3 > Poncams http://www.tomei-p.co.jp/news/Report-EJ25-V1.html#C3.3 . Granted testing was only done on the EJ255 (not EJ257). Basically, they found that usdm heads suck bad enough that they won't allow peak hp past 6k rpm (even with a larger cam) because they simply cannot flow enough air. Headwork or jdm sti cylinder heads would be ideal for any cam upgrade.
Deuce Cam is offline   Reply With Quote
Old 05-06-2009, 10:19 AM   #21
AMR
NASIOC Manufacturer
Member#: 171509
Spool was increased. Boost level stayed the same.
You are forgetting that the 2008 Subaru STi has DUAL AVCS. Anyone who has tuned a 2008 STi knows how much gain is found with the tuning of BOTH AVCS. The 2008 STi also has a slightly different turbocharger than the older models.
-Rob
Old 05-06-2009, 10:52 AM   #22
All4bSpinnin
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
awesome... iirc, cams can be installed without pulling the motor, its just a pita... correct?
keep up the good work rob!
All4bSpinnin is offline   Reply With Quote
Old 05-06-2009, 11:54 AM   #23
vik_wrx
Member#: 194804
2004 VF43 WRX - sold
wild!
vik_wrx is offline   Reply With Quote
Old 05-06-2009, 11:57 AM   #24
Tuner1
Member#: 86751
Very nice. Around what I would expect from good, mild cams. Are these regrinds or new billets?
Tuner1 is offline   Reply With Quote
Old 05-06-2009, 12:59 PM   #25
scramjett
Member#: 192526
2008 WRX FMIC/VF48
Red/Steel Grey
Damned good numbers on a VF48! You know, since joining the Subie crowd last year I have often wondered why no one ever talks about swapping cams. You look at other car forums (NA cars) and its always intake, exhaust, and cams... But not so with the Subie people; its intake, exhaust, and turbo...
I like that it looks like it holds 300whp all the way to redline... Gives me faith about my build that I'm trying wrap up this week. Granted I don't have dual AVCS but they do make cams for the single AVCS and it's something I am considering if I ever get rid of the stock internals.
scramjett is offline   Reply With Quote
2008 Subaru STi - AMR S1 (STAGE 1) with AMR BMI Cold Air System AMR Proven Power Bragging 37 03-19-2009 01:11 AM
2008 Subaru STi - AMR TMIC / AMR Dual Turbo Back / AMR BMI / AMR 3-Port Meth Kit AMR Proven Power Bragging 45 01-17-2009 08:24 PM
2008 Subaru STi - AMR T-60R / AMR TMIC / AMR Dual Turbo Back Exhaust (Pics Inside) AMR Proven Power Bragging 34 12-29-2008 12:32 AM
2008 Subaru STi - AMR Race FMIC / AMR T60R / AMR Direct Port Meth / 25psi @ 3800rpm AMR Proven Power Bragging 16 11-11-2008 09:35 PM
