Welcome to the North American Subaru Impreza Owners Club Friday May 22, 2015
Old 04-20-2002, 12:04 AM   #1
Impreza Rider
Member#: 756
2003 Legacy L wagon
2009 Kawasaki C14
Default KnockLink and stock knock sensor
Has anyone hooked up a KnockLink to the stock knock sensor on our cars? If so, where did you tap in the wires. I've got mine tapped in on the wires at the ECU, but the display doesn't change...just shows one green LED.
Thanks.
Impreza Rider is offline   Reply With Quote
Old 04-20-2002, 08:00 AM   #2
STiTuner
Member#: 5778
09 135i
Jet Black
did you turn the sensativity up?
Brad
STiTuner is offline   Reply With Quote
Old 04-20-2002, 04:14 PM   #3
Impreza Rider
Member#: 756
2003 Legacy L wagon
2009 Kawasaki C14
Yes...I have the sensitviy on maximum, per the directions for installing the KnockLink
Old 04-21-2002, 10:06 PM   #4
Impreza Rider
Member#: 756
2003 Legacy L wagon
2009 Kawasaki C14
No one?
Old 04-22-2002, 12:02 PM   #5
proecm
Member#: 12081
Yep, tried that too (on an XT6). Didn't work at all. The Knocklink does not have an amplifier per say, it only has an attenuator. So at maximium gain you only get whatever the knocksensor can give. The sensitivity of the sensor is dependent on how it is designed. So with other words, the stock sensor does not give enough of a signal to work with the knocklink. Not only that, but my ECU started throwing CEL immidiately after connecting it.
/David
proecm is offline   Reply With Quote
Old 04-22-2002, 12:29 PM   #6
Impreza Rider
Member#: 756
2003 Legacy L wagon
2009 Kawasaki C14
Thanks
Getting Knock Lite...stock knock sensor good enough? Airboy Western Canada 10 11-14-2006 09:31 PM
can the stock knock sensor be used for knocklink? blackie Engine Management & Tuning 3 08-24-2004 02:22 PM
FS: Knocklink with Bosch knock sensor modvp Private 'For Sale' Classifieds 3 05-14-2004 12:11 PM
Essay on the stock knock sensor, DeltaDash, and engine management ... wayoutwest Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-24-2003 12:40 PM
Has anyone removed the stock Knock sensor?? TMR Impreza Technical Forum Archive 7 05-19-2000 06:52 PM
