Old 05-05-2009, 10:05 PM   #1
ExecNav
Member#: 30554
08 LGT Spec.B
01 Impreza RS-T
Default Koyo Radiator: Autozone Fan Direction of Airflow
Surprisingly little information on 25rs and Nabisco about this. I purchased the Koyo Radiator, understood my stock fans and this radiator will not fit. So per recommendation from fellow members, I went out and got these Autozone slim fans (that clamp onto the radiator) and a sticker on the fans indicate the direction of airflow goes forward back into the radiator...
So I guess the few people that have Koyo radiators just wire the fans backwards so they flow in the proper direction?
-Brett (No intentions on trying to source JDM mad tyte fanz)
ExecNav is offline   Reply With Quote
Old 05-05-2009, 10:14 PM   #2
ExecNav
Member#: 30554
08 LGT Spec.B
01 Impreza RS-T
Nevermind, I'm a f(beep)cking f(beep)cktard.
Are.
Tee.
Eff.
Imm.
</thread>
Old 05-05-2009, 10:58 PM   #3
ExecNav
Member#: 30554
08 LGT Spec.B
01 Impreza RS-T
Actually, no. Rather, I went ahead and took some shots of this disaster. The fans are obviously inadequate and it's a good thing this car will never have to sit in traffic. The 12" fans were $60 each at Autozone and are a few inches smaller in diameter than stock. They require flipping of the blades and wiring polarity in reverse. They are 2 3/4" thick at the center. The mounting hardware is included (zip clamp fastener doohickeys).
Old 05-06-2009, 01:11 AM   #4
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
Sorry, no answers, but another question..
are you sure those fans would be large enough?
jigga is offline   Reply With Quote
Old 05-06-2009, 01:19 AM   #5
ExecNav
Member#: 30554
08 LGT Spec.B
01 Impreza RS-T
No, in fact I am almost 100% certain that continued use of these fans in the southeast heat with associated bumper to bumper traffic will almost certainly grenade my motor into the next century.
Old 05-06-2009, 11:32 AM   #6
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
what other options are there ??
IllNastyImpreza is offline   Reply With Quote
Old 05-06-2009, 01:25 PM   #7
Odyknuck
Member#: 192866
2006 Impreza
Adding a shrould to the radiator and fans will make a difference. What CFM are the fans? The shrould would also get the fans off the face of the radiator. I have never been fond of that mounting arrangement.
Odyknuck is offline   Reply With Quote
Old 05-06-2009, 02:14 PM   #8
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
I found this shroud for the WRX application. i am also considering it since I kinda need to move to a slim fan application, but I do not want to compromise the ability of the car to stay cool.
Mishimoto WRX shroud
Not too sure how well it works though... Bolts up to the stock radiator, which leads me to believe that it will work with the Koyo WRX unit also. Perhaps it can be modified to work for your application?
Old 05-06-2009, 02:41 PM   #9
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
theyll work, i didnt read anyones responses but youll prob have to flip the blades as well (i had to with my hayden fans i installed)
Koyo Radiator with fans texas05sti TXIC Private Classifieds 10 02-05-2010 11:49 AM
Koyo w/stock fans? JSA Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 05-23-2009 01:41 AM
STi Koyo Radiator, what fans? Doctor Murdock2 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 05-19-2008 12:49 PM
Cricket fans! Sports fans! One of the greatest sports upsets of all time HoRo1 Off-Topic 58 04-25-2007 10:57 AM
directions of slots on rotors? mav1c Brakes, Steering & Suspension 3 02-27-2001 02:06 PM
