Welcome to the North American Subaru Impreza Owners Club Tuesday October 25, 2016
Old 05-05-2009, 10:24 PM   #1
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Default Super Easy rear wheel spacer / extended lug nut install
I figured this out today so I thought I'd share. Last couple times I did this I had to disassamble the parking brake, this time, everything stayed in tact and it took about an hour for the whole install.
First take off the abs ring, abs sensor, and these two spear looking things that are held on by springs and washers:
Go to autozone and pick up a spare lugnut. Thread it as far as possible, then back of a bit:
Get a heavy hammer and hammer the sucker out. Make sure you move the abs ring out of the way as the nut is comming out. If you bend it, you're screwed:
Now you can pull the pads forward and get the stud out. You can only get it out from the side closest to the front of the car. If you can't get it out, you can rotate the hub
Now you can insert the longer stud the same way. It's a little tight, but you can rotate the hub again and it'll go in.
Next, get a couple of big washer and make sure to put grease between them. It'll make getting the stud in much easier
Next, you can hold the hub with one wrench while pulling the stud in with the other:
Al done:
Then when you have to put those spear things back in, they're a PITA. but if you take a pair of pliers and tape two small washers in as shown so they can't close all the way, getting everything back in is nice and easy.
That's it
Bad Noodle is offline   Reply With Quote
Old 05-06-2009, 02:07 AM   #2
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
awesome post. Vote for sticky!!
aboothman is offline   Reply With Quote
WI/IL: Subaru wheel locks, Muteki lug nuts, and lug nuts to replace wheel locks JWA Wheels/Tires 7 03-22-2010 04:52 PM
FS: Rays extended lug nuts & Work lug nuts supaflyTS VIC Private Classifieds 4 04-02-2009 10:14 PM
Volk Lugs Aluminum Extended Lug Nuts, Volk Locking Lug Nuts, Genuine Suby Wheel Locks timeless Wheels/Tires 10 08-21-2008 01:06 AM
Rays Extended Lug Nuts WRX427 Interior & Exterior Modification 11 06-08-2006 04:46 PM
pics of RAYS extended lug nuts ScoobySnackZ Member's Car Gallery 0 05-27-2005 05:42 AM
