Old 05-06-2009, 02:22 AM   #1
banannersz
Member#: 193403
2002 Impreza WRX
Default whats a good Short Throw Shifter for N/A?
Hey i want to get a short shifter for my 06 2.5i impreza. and i was wondering if anyone has any good sugestions on a short throw shifter.
i was thinking kartboy cuz thats the only one i know. help met out =]
banannersz is offline   Reply With Quote
Old 05-06-2009, 02:35 AM   #2
SleeperWgn
Member#: 176293
2007 Impreza 2.5 Wgn
Newport Blue Pearl
www.importimageonline.com
here's it (yes, a wrx sts will fit a 2.5i): http://www.importimageracing.com/mm5...egory_Code=500
When you install it the new shorter bar will touch the metal when going into first. There's two ways to remedy this (One: Remove said metal, rotate 180 degrees, reinstall. Two: use a metal file to file away the couple of millimeters where it touches). This is the cheapest set out there, and it works great. No complaints with 15k miles since install. You will notice a little more NVH with the stiffer bushings, so save your old ones in case it bothers you.
Good luck!
SleeperWgn is offline   Reply With Quote
Old 05-06-2009, 03:16 AM   #3
Flat4TW
Member#: 200456
0295 WRX
get the cobb adjustable ss. i love mine!
Flat4TW is offline   Reply With Quote
Old 05-06-2009, 03:21 AM   #4
evan_impreza
Member#: 115276
04 PSM WRX -sold:(
98 RS- WRX swap complete!
i had a kartboy in my 06 2.5i. when i traded it for my wrx i took it with me. i love my kartboy!
evan_impreza is offline   Reply With Quote
Old 05-06-2009, 03:27 AM   #5
Jamnation862
Member#: 188928
2004 WRX ej257 + E85
ive got the twm performance short throw and ive got no complaints. pretty cheap, also i would recommend purchasing the poly bushings with the shifter, they make such a nice difference for only 20 bucks
Jamnation862 is offline   Reply With Quote
Old 05-06-2009, 10:05 AM   #6
sa4baru
Member#: 195354
www.ixizconcept.com - period.
better than any other - adjustable & has a optional 120g weight - price is right!
sa4baru is offline   Reply With Quote
Old 05-06-2009, 10:10 AM   #7
rougeben83
Member#: 115154
2005 Outback XT
White on grey
^^^ my only complaint with the ixiz is you need to put locktite on the threads and really secure the lock nut is really bolted up tight or it'll loosen up in a couple of months.
Any of the short shifters for the WRX will work on the 02+ Imprezas as well so I don't see how this is specific to the n/a's.
rougeben83 is offline   Reply With Quote
Old 05-06-2009, 10:19 AM   #8
blernin41
Member#: 200321
2009 Forester 2.5XP
Armpit Green
kartboy FTW!!! sweet and simple!
blernin41 is offline   Reply With Quote
Old 05-06-2009, 12:20 PM   #9
aclver1
Member#: 114177
2004 Impreza 2.5rs
70 Datsun Fairlady
Go fast bits. fully adjustable and shorter than anything out there. You don't have to cut or trim anything to make sure it doesn't hit the metal shroud like most others do. but is is a bit expensive.
aclver1 is offline   Reply With Quote
Old 05-06-2009, 12:46 PM   #10
mdungelman
Member#: 97251
'13 Impreza 2.0i
Kartboy. Get bushings while you're at it.
IBwrongforum
mdungelman is offline   Reply With Quote
Old 05-06-2009, 03:36 PM   #11
sa4baru
Member#: 195354
Thumbs down
i've had an ixizshift for about 2 years, never used locktite, never had any nuts come undone..
also, F cobb products, unless you want to buy from arrogant a$$holes with terrible customer service.
i still say ixizshift for the sole reason that you can add weight to the shaft.
Old 05-06-2009, 03:48 PM   #12
funky monk
Member#: 143094
08 LGT
DBM
Kartboy with bushings. There isn't really an NA specific one, just get the combo.
funky monk is offline   Reply With Quote
Old 05-06-2009, 03:50 PM   #13
bsikora
Member#: 125573
2006 2.5i
ProTune by Sean S.
+1 i have kartboy on mine car and i love it!
Blake
bsikora is offline   Reply With Quote
Old 05-06-2009, 07:31 PM   #14
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
+2 for kartboy
Old 05-06-2009, 08:02 PM   #15
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
drivetrain (transmission) forum! The COBB adjustable is outstanding. it lets you adjust the leverage ratio and the lever height independantly so you can get that crisp solid low effort shift feel without having to compromise with a taller lever height for more leverage. And it's pretty, but you cant see it unless you remove/modify your boot. The kartboy gets great reviews from just about everyone who has one, and it's fairly cheap.
Do yourself a favor and get a solid shift knob and bushings while ur doing the lever.
GrundleJuice is online now   Reply With Quote
Old 05-06-2009, 08:45 PM   #16
Nitrous
Member#: 136929
+1 For RaceFaceXC
Honestly, if you're doing bits at a time like I did, I would say that the single best improvement in shifter feel are the bushings.
Knob is whatever, people prefer different grips and weights. I personally like to pull/push from a side grip so piston knobs are for me. Kartboy makes that super heavy steel piston, I enjoy it.
As for the shorter throw, meh. For me I don't think it does too much...
Nitrous is offline   Reply With Quote
Old 05-07-2009, 12:22 AM   #17
banannersz
Member#: 193403
2002 Impreza WRX
is it plug and play for the kartboys? because thats what im leaning towards. i dont have to cut any metal or shave anything off?
Old 05-07-2009, 12:34 AM   #18
sa4baru
Member#: 195354
i think you'll have to grind the forward left corner of the trim with any shortshifter.
Old 05-07-2009, 12:41 AM   #19
SleeperWgn
Member#: 176293
Newport Blue Pearl
^^^ this is correct, except for the adjustable i think.
In that regards, my first post (second on thread) should be cheapest and = to karboy.
I had the kit installed and enough metal filed away within 20-30 minutes total. Don't forget to have a mallet/hammer available (getting shifter out will require you to turn it 180* in the socket, then hit it with a mallet towards the rear of the car, popping it out).
Old 05-07-2009, 01:09 AM   #20
banannersz
Member#: 193403
2002 Impreza WRX
Thanks a lot guys. very helpful.
Old 05-07-2009, 05:03 PM   #21
doubledribble
Member#: 42912
2003 Outback Sport
bird **** & door dings
or rotate it 180...
kartboy all the way, pick up the front & rear shifter bushings too...the TiC pivot bushings as well...best mod yet.
doubledribble is offline   Reply With Quote
Old 05-07-2009, 05:11 PM   #22
Carter
Member#: 156708
2004 Mini Cooper S
Invader 125 Shifter Kart
+1 for Kartboy and all the bushings. It's a huge improvement, and Tom is a great guy.
Carter is offline   Reply With Quote
Old 05-07-2009, 07:11 PM   #23
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
With the COBB adj. you can set it up high enough to not interfere with the metal surround piece but you will leave alot of the reduced shifter throw on the table that way. The metal surround comes out with 4 screws and a file will get that corner shaved away in a couple mins.
Old 05-08-2009, 01:45 PM   #24
HeyChris
Member#: 2234
2013 F-XT
Obsidian Black Pearl
Kartboy, there is no substitute.
HeyChris is offline   Reply With Quote
Old 05-08-2009, 04:01 PM   #25
treksofar
Member#: 208070
2006 Impreza 2.5i
Regal Pearl Blue
kartboy all the way. moreover i had no issue at all hitting the plate in first.
treksofar is offline   Reply With Quote
WTT 2006 OEM short throw shifter for you stock shifter 06hwrx TXIC Private Classifieds 9 06-26-2006 04:22 AM
good short throw shifter for WRX nhmtns Newbies & FAQs 28 08-27-2005 11:57 PM
Short-throw shifter for Outback ('03 LTD) PiroChu Outback Forum 3 02-16-2005 04:52 PM
Sti Short Throw Shifter For WRX 5MT MisterX Private 'For Sale' Classifieds 0 07-01-2004 03:16 PM
('93-'01) Short Throw Shifter for 93-95 Imprezas Tkacik Impreza Forum 5 07-31-2002 11:04 AM
