Old 05-06-2009, 01:46 PM   #1
dunk
Member#: 15359
Default Exotic Brake Cooling Ideas
I'm bouncing around the idea of planning a 2gph water injection nozzle in each brake duct. I've found some examples of this done with success on racecars in the past, however have seen very little current data. I'm willing to be the lab rat here.
Any thoughts from NASIOC?
-Duncan
dunk is offline   Reply With Quote
Old 05-06-2009, 01:56 PM   #2
STi-MAN
Member#: 70252
05 STI
blue
you need more cooling?
STi-MAN is offline   Reply With Quote
Old 05-06-2009, 02:15 PM   #3
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
I say go for it!!
Are you planning to trigger flow demand based off of current from a brake line pressure sensor? It could be variable and progressive.
How did you come up with 2GPH flowrate per brake (assuming just the fronts)?
Old 05-06-2009, 02:17 PM   #4
Frank A
Member#: 49979
11 dgm wrx hatch
08 black TA STI
did you already consider a fan? Someone suggested that those "electric turbochargers" use model jet airplane engines. I looked into them and you can get over 850 scfm from medium-large units that fit in a 3" tube. They don't build pressure very well and bigger units require too much power to justify as a supplemental turbocharger, but that should be more air than typically flows in brake duct hose at >70 mph. Could do some math...
Frank
Frank A is offline   Reply With Quote
Old 05-06-2009, 02:31 PM   #5
FunkRider
Member#: 195055
I've never done a water cooled brake system but I would imagine you'll only see a worth while benefit from injecting water into the rotor hat area or inject into an airstream the feeds into the rotor hat area.
FunkRider is offline   Reply With Quote
Old 05-06-2009, 02:32 PM   #6
STi-MAN
Member#: 70252
05 STI
blue
Frank
he already has a fan on there.. hahah thats why i asked if he needs more cooling.
Old 05-06-2009, 02:34 PM   #7
rexspeedworthy
Member#: 26965
2011 WRX
DarkGray
When you are not racing, you can adjust the nozzles to spray your tires with soap water, and do AWD burnouts without fear of breaking your shizz.
rexspeedworthy is offline   Reply With Quote
Old 05-06-2009, 02:49 PM   #8
generalee69
Member#: 106470
2004 STI ICSCC #9
www.ClintonRacing.com
My only theoretical concern would be if the mist/air temp is too cold, you might do some warping damaging due to the rapid change in temp. I'm thinking going from glowing red rotors to spraying them down with a garden hose as an extreme example...
generalee69 is offline   Reply With Quote
Old 05-06-2009, 03:07 PM   #9
dunk
Member#: 15359
I did the basic math and at rotor temps over a 1000 degrees the water will be steam long before it touches the rotor face.
-Duncan
Old 05-06-2009, 03:09 PM   #10
dunk
Member#: 15359
Originally Posted by Homemade WRX View Post
I say go for it!!
I picked 2gph out of a hat. It seemed a reasonable size based on the flowrate and tank sizes needed to sustain 45 minutes of operation. I'm going to dig through the Trackmate data and see how many minutes of braking I do per x driving time. I'll use Summit Main for a data point since it's the worse out of all the tracks I drive.
I was going to use a simple on/off using the brake switch to keep the cost and complexity down.
-Duncan
Old 05-06-2009, 03:11 PM   #11
dunk
Member#: 15359
Wouldn't hurt. My rotor temps are still hotter than I'd like. Before the next track day at a minimum I'm going to .
Remove the fans from the primary ducts (restriction at speed)
Hook them back up to the lower RCE ducts (currently not hooked to hose)
This shold give me both a low and high speed system.
Doing the water injection would be cheap using parts from Mcmaster and I just thought it would be interesting to compare how well it works.
-Duncan
Old 05-06-2009, 03:49 PM   #12
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Hey Dunk,
I did some research on this a while ago. You need the nozzles to be fairly close to the beginning of the ductwork as opposed to right next to the rotors.
-Clint
Old 05-06-2009, 05:45 PM   #13
dunk
Member#: 15359
Originally Posted by Turn in Concepts View Post
Hey Dunk,
-Clint
Clint,
Return my call when you get a chance.
-Duncan
Old 05-06-2009, 07:31 PM   #14
Mr_Snips
Member#: 152117
2012 Ford F150 ECO
Well, they do this alot in the big semi truck racing down under. But i know for awhile (maybe they still do) WRC cars had watercooled calipers as in water flowed through them.
There was some talk awhile ago and some people brought about the hypothesis of steam forming under the pads and causing loss of braking power.
Mr_Snips is offline   Reply With Quote
Old 05-06-2009, 08:42 PM   #15
drdabbles
Member#: 110229
2004 WRX STi
Java Black
Quick temp fluctuations have different effects on different materials. Also, different brake compounds work more effectively at different temperatures. So, finding a pad that can handle quick thermal cycling and do its job effectively.
Good luck and let us know how it works.
drdabbles is offline   Reply With Quote
Old 05-06-2009, 08:56 PM   #16
misterwaterfallin
Member#: 101091
this.
needs to happen
misterwaterfallin is offline   Reply With Quote
Old 05-06-2009, 08:58 PM   #17
Token-Negro
Member#: 81659
2010 Fozzy XT
Ice Silver Metallic
Why not go to the 4" fans with the 3" reducer?
Token-Negro is offline   Reply With Quote
Old 05-06-2009, 09:09 PM   #18
dunk
Member#: 15359
You're no fun.
I don't have the room to package it all in front of the brake duct inlet. I'm debating putting the 3" fan parallel to the main duct, with a y junction into the main pipe. This would probably involve the least fabrication.
-Duncan
Old 05-06-2009, 09:42 PM   #19
wallyman424
Member#: 60357
#17 NASA ST2 Z06
my wang > your wang.
Duncan, why are you having so many brake cooling problems? How much does your car weigh? How big are your rotors? What pads do you use?
I figure our cars can't be too far off on weight and top speed, and I have no problems with brake fade.
wallyman424 is offline   Reply With Quote
Old 05-06-2009, 09:55 PM   #20
Chris_Lee
Member#: 110667
2006 WRX
Hey Dunk,
-Clint
This would make sense. Applying some sort of cooling fluid directly to the surfaces of the caliper or rotor could cause the metal to expand and contract to fast and to much This could cause the metal to crack. This is a really good idea though. You've got to post some pics when you work out the details. I wonder if there is way to use a flexible bladder?
Chris_Lee is offline   Reply With Quote
Old 05-06-2009, 10:03 PM   #21
Mr_Snips
Member#: 152117
2012 Ford F150 ECO
why not just have a small nozzle spray something like C02 on it?
Old 05-06-2009, 10:33 PM   #22
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
GD Race Car in progress
Problem is subarus are very front heavy so the front brakes do most of the work. I've gone through countless brake setups up front, including several sets of rotors, a couple different calipers, and a ton of pads. I still have my stock rear rotors and calipers (5 years old) and they are completely fine.
boost junkie is offline   Reply With Quote
Old 05-06-2009, 10:42 PM   #23
dunk
Member#: 15359
As Dan said, Subaru's are tough on brakes.
Car weights 3250 - race weight
Rotors are 13.3x1.26.
58% of the weight is on the front of the car.
It's not a fade issues as the brakes hold up fine. I'm just going through front rotors a lot quicker than I'd like. VIR is not so bad, but Summit Main kills them.
-Duncan
Old 05-06-2009, 10:43 PM   #24
dunk
Member#: 15359
I've had the same set of race pads in the rear for about 6 events now. I've never replaced the rear rotors.
I'm on the fourth front caliper setup.
-Duncan
Old 05-07-2009, 12:10 AM   #25
Frank A
Member#: 49979
11 dgm wrx hatch
08 black TA STI
I want to see the water injection too, buuut, have you considered switching to one of the newer ceramic-based pads like the Ferodo DS2.11's? I understand the ceramic-based stuff is gentler on rotors. Since you say the rotor temps aren't too high, you may have room to switch to a softer pad. How hot is "not too hot"?
If you're running stoptech's you could switch to the 355mm rotor, assuming you use 18" wheels...
Frank
Cool it!! -Lets see your brake cooling duct set-ups. thewerxracing Brakes, Steering & Suspension 2 04-09-2013 10:11 PM
Brake Cooling Scoops.. idea stolen from Porsche sil0nt Brakes, Steering & Suspension 4 09-17-2010 11:28 PM
cool idea...not cool to land on someones patio twinbrd Off-Topic 30 03-31-2004 12:46 AM
A new idea for brake cooling BIGSKYWRX Brakes, Steering & Suspension 7 05-05-2003 04:29 PM
Brake cooling idea? Fatty Jones Brakes, Steering & Suspension 17 04-24-2003 05:46 PM
Message Board Statistics All times are GMT -4. The time now is 02:40 AM.
