Old 04-20-2002, 08:29 AM   #1
CarbonWRX
Member#: 17114
Default 200hp....
can you make 200 hp @ the wheels on a 2002 wrx with out upgrading the turbo?
exhuast,boost controler,intake,Uni-Chip,and up-pipe...or what else would be needed to reach the 200 hp?
CarbonWRX is offline   Reply With Quote
Old 04-20-2002, 08:46 AM   #2
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
you can get there with a unichip, no problem. On the cheap, though, go for a Scoobysport exhaust (if your goal is 200hp, DO NOT go for a 3" exhaust), cold air intake (do research on which ones cause problems), uppipe, and underdrive pulleys and you'll be at or above 200hp at the wheels.
nhluhr is offline   Reply With Quote
Old 04-20-2002, 09:03 AM   #3
jmott
Member#: 6713
2007 Prius
brown
Default Re: 200hp....
full exauhst and a unichip should get you over 200hp
jmott is offline   Reply With Quote
Old 04-21-2002, 06:18 AM   #4
CarbonWRX
Member#: 17114
thank you all..but what would be the best parts to to reach this 200hp?
Old 04-21-2002, 06:20 AM   #5
ellisnc
Member#: 4229
2003 S2000
Did someone say track day
they just told you, or do you want to know what the "best" exhaust is?
ellisnc is offline   Reply With Quote
Old 04-21-2002, 07:27 AM   #6
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
maybe you missed the part where i spelled it out for you:
Scoobysport Exhaust.
don't shop around. just buy that one. no questions asked. if you don't want to spend days and days researching which exhaust would be best for you and you just want a recommendation based on quality, application needs, etc, just trust me on this one. Scoobysport.
All the other stuff won't matter what brands (except maybe the intake) so just get whatever you can.
Of course the "best" uppipe is the Vishnu. There's no doubt about that. The "best" underdrive pulleys are ones which don't underdrive too drastically or that include a seperate alternator pulley (vishnu or GFB are good ones).
Old 04-21-2002, 07:42 AM   #7
CarbonWRX
Member#: 17114
then scoopysport exhuast it will be if sounds mean because i am new with V4 cars i always had v8 cars...but i really appreciate it guys.
Old 04-21-2002, 10:34 AM   #8
WRX_02_227
Member#: 12434
2002 WRX #332
2011 BMW 135i
Why not 3 inch? I have the BPM TT and I think the performance gain is pretty good, the looks and sound are great too.
WRX_02_227 is offline   Reply With Quote
Old 04-21-2002, 11:00 AM   #9
WrxSPD
Member#: 12886
Maybe what nhluhr is saying is that since 200 whp is CarbonWRX's
goal and no more mod there after. The 2.5 inch will give him a little
more low end torgue.
Of couse for someone that is going to go stage 1, 2 and beyond then
better starts with a 3 inch to make use of the turbo, injectors, fuel
pump/fuel rail upgrade, then unichip remap. You looking at 300 over
over whp here.
nhluhr am I on thr right track, since I am also aiming for a little over
200 whp
WrxSPD is offline   Reply With Quote
Old 04-21-2002, 11:08 AM   #10
BullsWRX
Member#: 12097
2003 Ford Mustang GT
Dark Shadow Grey
I was putting down:
197.7hp @6500 (dyno'd at cobb for a baserun)
203.9TQ @3500 "
with just a MBC @ 16psi & 93 octane gas on an otherwise stock car.
Just food for thought. Are you guys sure that just an exhaust will open up that much horse power without any tuning?
BullsWRX is offline   Reply With Quote
Old 04-21-2002, 11:12 AM   #11
jmott
Member#: 6713
2007 Prius
brown
do you have any data to support this assertion?
I have a bit that suggests it is not true.
Old 04-21-2002, 06:48 PM   #12
Penguinking
Member#: 9422
2002 silver
wrx R.I.P.
i was just thinking, the vishnu kit only comes with an underdrive pulley. the GFB kit comes with a pulley and an alternater pulley. is it possible to add the alternator pulley from the GFB and add it onto a car which has the vishnu underdrive on it? wouldn't that smooth things out a bit, or would the belts not make it possible to do
Penguinking is offline   Reply With Quote
Old 04-21-2002, 07:07 PM   #13
mlambert
Member#: 13831
it should be noted that cars with turbo's dont benefit down low (ie get more low end torque) from smaller diameter pipes like NA or supercharged cars do. Thats not to say there isnt a 'perfect' pipe for a desired power goal tho.
If you are not planning on doing any engine mods (creating more power) you need to focus on 'freeing up' the power that the stock motor already makes (removing restrictions).
Basically any aftermarket turbo-back will free up alot of power on the WRX and the scoobysport is a great choice.
mlambert is offline   Reply With Quote
Old 04-21-2002, 07:12 PM   #14
William LaPalme
Member#: 11396
2002 impreza
blue
i am new to V4 cars
This is shocking,! who here has a V4, that may be your problem buddy!! Someone stole your enjine and replaced it with a V4!!! Do you know the make of this enjine, I believe Yugo may have had a V4 turbo for a while, could that be it?!
William LaPalme is offline   Reply With Quote
Old 04-21-2002, 09:58 PM   #15
mr2guru
Member#: 10334
91 RX7 LSx swap
'09 CC 3.6 4motion
Hmmm, It's a V4. It is, really! Just a 180deg. V4
mr2guru is offline   Reply With Quote
Old 04-22-2002, 11:37 AM   #16
TypeC
Member#: 9794
02 2.5LWRX-Retired
335i w/twins
if your goal is 200hp, DO NOT go for a 3" exhaust...
sorry, but a 3" exhaust (or open dp for that matter) will make MORE low end than a 2.5". This isn't NA.
don't shop around. just buy that one. no questions asked..... Of course the "best" uppipe is the Vishnu. There's no doubt about that.
yes there is. As stated MANY times before, there is NO "best" uppipe. They all do the same thing and make the same power. As long as they seal (which they all do now), that's all that matters. You have choices in finishes and thickness, but you can't see the part anyway so it doesn't matter. Don't say it's the best without proof that it is.
also, who says scoobysport is the answer. He doesn't even need exhaust to make 200whp, much less that brand. The brand is just a matter of preference. The DP type is what matters.
TypeC is offline   Reply With Quote
Old 04-22-2002, 06:04 PM   #17
Penguinking
Member#: 9422
2002 silver
wrx R.I.P.
an exhaust won't give you that much hp for the money. by far, the best mod with the best price/hp ratio is a new uppipe. get that, and a downpipe, and a chip, and you're golden. that should put you in the range of just under 200whp or so. the rest of the exhaust can come later when you're doing the bigger upgrades, or you just want that cool sound
How can I make my car put all the HP to the wheels? ImprezaRS05 Normally Aspirated Powertrain 42 02-08-2006 08:20 AM
1995 vr-4 with close to 400 hp to the wheel sjtangb21 Private Vehicle 'For Sale' Classifieds 6 08-26-2005 02:06 AM
What was your HP to the Wheels at Dyno? BigElm Tri-State Area Forum 33 07-31-2002 01:52 PM
Goal of 200 HP at the wheels is realistic ? Mr. Rogers Normally Aspirated with bolt-on Forced Induction Powertrain 16 05-15-2002 07:15 AM
loss of Hp to the wheels??? Need my AWD Normally Aspirated Powertrain 16 03-29-2001 07:32 AM
