![]() Brakes & Suspension Forum sponsored by The Tire Rack |
#1 |
Member#: 180514
E. Canada
Vehicle:2004 Sti White |
My lateral links on my 02 wrx was bent and i bought 04 sti lateral links from a member.
Is it possible to use my stock sway bar and "C" type endlinls on the rear lats ? It looks like the endlink will align with the 04 rear lat, but it doesn't have 2 side supports like 02 wrx ones. Would it be ok to bolt it that way ? 02 wrx lateral links : ![]() 04 STI lateral links : ![]()
#2 |
Member#: 101816
NESIC
Vehicle:06 WRX TR SGM |
I think the 2 sided supports on the wrx links has more to do with how thin the metal is. If you look at the sti ones the the support is substantially thicker than the wrx ones. I'm currently running 05+ aluminum sti links on my wrx rotated so the supports point down with a 25mm sway designed for the stock lat links and kartboy endlinks and everything fit together and seems to work fine. The only issue was on the drivers side the bar and the support were lined up right on top of each other so we were forced to put the endlink inside/inside or outside/outside I forget which.... I can snap some photos if you want.
#3 |
Member#: 180514
E. Canada
thank trainable, I would definately wanna see some shots of your setup.
#4 |
Member#: 101816
NESIC
There you go. |
| Thread Tools | |
| Display Modes | |
| FS: Stock 03 WRX Springs and Struts & Stock Rear Sway Bar + End Links | romesnow | Suspension/Brakes/Handling | 8 | 10-01-2009 01:51 PM |
| FS 02 wrx stock sway bar | seanathanq83 | TXIC Private Classifieds | 0 | 08-25-2009 12:38 AM |
| NY: Stock sway bars, end links, '06 WRX exhaust | Donzo | Suspension/Brakes/Handling | 16 | 05-29-2009 07:44 PM |
| WTB: Aftermarket sway bars, end links, lateral links. Need wrx front, Sti rear | bugisti | Private 'Wanted' Classifieds | 1 | 02-06-2009 10:25 AM |
| Rear Sway Bar/end Links 04 Wrx Wagon | ivrep | Private 'For Sale' Classifieds | 4 | 01-04-2006 10:44 PM |
