South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 05-06-2009, 10:58 PM   #1
romesnow
Member#: 126543
2004 Sti
Default Are 06 wrx Struts the same as 03?
I got a pretty good deal on some newer struts with tein springs. But i just want to make sure if there is any difference in the struts from 03 to 06. Like are the hubs or anything different? Any help would be good. Thanks.
romesnow is offline   Reply With Quote
Old 05-06-2009, 11:03 PM   #2
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
The struts themselves are different, but if you have the correct tophats for that year strut, you'll be fine. This is to say:
2002-2003 struts must be used with 2002-2003 tophats or a spacer if you use 2004-2007 tophats.
2004-2007 struts must be used with 2004-2007 tophats.
If the 2006 struts come assembled with 2006 tophats, you're good to go. The Impreza body is the same from 2002-2007.
EDIT: Spacers - http://www.turninconcepts.com/produc...roducts_id=234
But you don't need them in your case.
Old 05-06-2009, 11:08 PM   #3
romesnow
Member#: 126543
2004 Sti
Awesome thanks a lot for the help!
Old 05-07-2009, 12:58 AM   #4
Evil Imports
Member#: 14732
+ 13 B8
as long as the 06 struts are wrx, If they are STI the front will be different and will not bolt up
Evil Imports is offline   Reply With Quote
Is stock 06 wrx swaybars the same as stock STI swaybars? kitganzon Brakes, Steering & Suspension 4 05-04-2008 02:36 PM
Is the 06 wrx axleback the same as the 06 fxt? 2slofouru Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 11-19-2006 09:46 PM
Are 03/04 STI/WRX Springs the same as 05/06? vspdave Brakes, Steering & Suspension 4 10-16-2005 01:27 PM
Are 04 WRX doors the same as 02? JC_595 Subaru Conversions 3 05-15-2004 02:17 PM
Are '02 WRX fans the same as '04 TS Fans?! Peter.Lombardi Subaru Conversions 0 05-11-2004 01:27 PM
