Old 05-07-2009, 12:05 AM   #1
mc2
Member#: 59992
1997 Legacy L EJ22
Default How to confirm if it's the rear main...?
Is there anyway to confirm if it's my rear main seal leaking or not?
I just changed it out, but i'm still getting leaks, i'm worried that it's leaking again now...
What else can leak down onto the exhaust/y-pipe?
If the rear main is leaking will it also drip down the front of the front cross member? i'm not getting any oil there, but it seems like it should drip down there if the rear main is leaking..
mc2 is offline   Reply With Quote
Old 05-07-2009, 12:23 AM   #2
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
There's also an access plate on the back of the engine up and to the right of the rear main that loves to leak.
Old 05-07-2009, 12:25 AM   #3
WcW
Member#: 209963
Things that leak onto the exhaust Y:
Rear main/inspection plate
Tranny front.
CV boots.
Both valve gaskets, due to the cross member.
If you replaced the rear main before then you know the symptoms. Take off the clutch inspection plate and look for oil coming down behind the flywheel. If it's the tranny front seal then the fluid will be running down from the bell housing. Removing the top inspection plate will also let you see tell-tale oil thrown by the flywheel. Check the valve cover breather hoses too.
WcW is offline   Reply With Quote
Old 05-07-2009, 12:51 AM   #4
mc2
Member#: 59992
1997 Legacy L EJ22
I changed the oil separator plate as well. I think i did everything right, but now i'm questioning it..
I know my passenger side camshaft support o-ring is also leaking, but the amount of oil coming down seems more than would come out of there.
Actually it's a 4EAT and i'm pretty sure it's not ATF
It sounding more and more like I must not have done the rear main well... The valve gaskets look very dry..
Old 05-07-2009, 01:37 AM   #5
WcW
Member#: 209963
so sorry.
Old 05-07-2009, 02:21 AM   #6
mc2
Member#: 59992
1997 Legacy L EJ22
But doesn't it make sense that the rear main would drip down the front side of the cross member?
Old 05-07-2009, 02:55 AM   #7
mc2
Member#: 59992
1997 Legacy L EJ22
So i just idled the car in the garage for 20 minutes, not a drop... Turned it off let it sit for 10 minutes, nothing.
Checked the PCV valve and associated hoses, all are clear and working...doesn't make any sense. That's the only thing that I could think of that would cause it leak only after/when driving..
Old 05-07-2009, 02:57 AM   #8
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Your oil pressure at idle is trivial compared to at even moderate RPM. I currently have a leak from the oil pump that only happens above 3500RPM.
Old 05-07-2009, 03:26 AM   #9
mc2
Member#: 59992
1997 Legacy L EJ22
hmm.. yeah i guess so..
argh. i hate it. after i changed the rear main all my front seals started leaking too! i don't know what it is. I changed the PCV valve at the same time... My mechanic said i might have a dud... i put the old one back, but both seemed to be working fine anyway..
Old 05-08-2009, 01:28 AM   #10
WcW
Member#: 209963
If you want to check the venting function of your PCV bend down next to the oil cap and gently loosen it. There should be a slight vacuum in that part of the crank case audible when the oil filler is just cracked open. Lack of vacuum indicates leaks or a gooed valve or huge blowby. If there is excessive vacuum or the engine stalls then the valve is stuck open. Also check the valve cover breathers for function if you have a cam seal leak. The PCV system on the EJ series uses a low vacuum value and there might be some benefit in replacing the stock screw in valve with an external valve.
Old 05-08-2009, 03:47 AM   #11
mc2
Member#: 59992
1997 Legacy L EJ22
Thanks I will check it out. How do i check the valve cover breather?
Old 05-08-2009, 01:52 PM   #12
WcW
Member#: 209963
with the engine stopped and the oil cap off you should be able to blow through the tube into the engine on both sides and there should be no resistance to blowing air through the collector.
Here's another way to check the PCV valve. At idle pull off the pcv hose from the valve. It should instantly seal, no whistle, then put your finger over the opening, on a clean working valve it should click, then click again when you take your finger off, the engine may stumble momentarily. If it doesn't click both ways then you need to remove it and soak it with cleaner. When it is clean it will rattle when you shake it. If it is clean and still fails this test you need to replace it. The pcv system is a major contributor to idle air and cleaning the system can make the car idle funny for a little while.
Old 05-08-2009, 05:43 PM   #13
mc2
Member#: 59992
1997 Legacy L EJ22
The PCV valve seems to be working fine. It's sealed when the hose is off. It also rattles when i shake it.
I'm guessing thats not my problem...
Old 05-08-2009, 09:50 PM   #14
euro_tech
Member#: 206785
1999 legacy outback
clean everything off and watch it while it runs. source of oil should become apparent.
euro_tech is offline   Reply With Quote
Old 05-09-2009, 02:29 AM   #15
mc2
Member#: 59992
1997 Legacy L EJ22
when it's idling it doesn't leak a single drop... I let it idle for 20 minutes the other day, nothing.
Old 05-09-2009, 07:10 PM   #16
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Even though it is illegal in most states I suggest buying a few cans of engine cleaner and using it at one of those self operated car washes. Get your entire engine bay sparkling clean and drive for a few days then check again.
Old 05-11-2009, 02:44 AM   #17
mc2
Member#: 59992
1997 Legacy L EJ22
Well i'm sure it's the rear main now. I changed the RH camshaft support o-ring where I was getting a lot of oil out of. That was the only place left where i can get oil down on the jack plate and dripping down the front diff onto the y-pipe.
damn it. i don't know how i did that wrong the first time...
Old 05-11-2009, 11:31 AM   #18
Aegean93L
Member#: 103162
04 RS Sedan
I bet you pressed it in too far (the rear main seal). If you tap it in all the way, until it stops, it will leak. It is supposed to be flush with the inside edge of the 45* bevel on the block.
Aegean93L is offline   Reply With Quote
Old 05-11-2009, 01:32 PM   #19
mc2
Member#: 59992
1997 Legacy L EJ22
Actually i think it was flush with the top of the chamfer, not the lower edge of the chamfer. if anything i'm guessing i didn't press it in far enough and it didnt seat correctly.
how to tell if i have rear lsd yeos Transmission (AT/MT) & Driveline 4 02-23-2009 02:25 AM
How to tell if it's a factory short-throw shifter? ALB03WRXwagon Newbies & FAQs 11 07-12-2008 12:42 AM
Borla Header Question - how to confirm fit if seller does not know info kero Normally Aspirated Powertrain 11 06-30-2008 11:43 PM
How to tell if car/engine/turbo is running the way it's supposed to? wrexsta Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 02-18-2003 07:16 PM
How to tell if it's a MY00 RS? poopysnaps Newbies & FAQs 14 09-05-2001 11:14 PM
