Welcome to the North American Subaru Impreza Owners Club Sunday March 29, 2015
Old 05-07-2009, 12:11 AM   #1
WcW
Member#: 209963
Default Flipped Rear Bottom Link?
Looking at the rear suspension on a my96 it looks as if the lower links could be unbolted and rotated 180* which would bring the sway bar link to the top.
It appears to me that you could then use conventional performance endlinks or double heim joints. Has anybody done this? The plastic dog bones offend me and I want some degree of adjustability on the stock bar.
WcW is offline   Reply With Quote
Old 05-07-2009, 07:03 AM   #2
Storm
Member#: 5218
96L Most Over-
Developed Beater
Should be able to....but you might have to also swap L-R sides to keep the alignment of the flange in check. Also, check the travel of the swaybar blade at full compression. You don't want it to jam up into the trunk floor.
Jay
Old 05-07-2009, 02:21 PM   #3
WcW
Member#: 209963
I'm gonna try it, I'll post my results.
Old 05-07-2009, 03:43 PM   #4
SOHCEJ25
Member#: 135013
'98 Forester
I was going to do that so I could run the STI rear links on my STI rear bar ... But my through bolt is so rusted in I couldnt !! Looks very possible though .!!
SOHCEJ25 is offline   Reply With Quote
f/s socal cusco rear sway bar, oem sti rear latteral links,oem sti end links team trucha racing Suspension/Brakes/Handling 13 04-15-2009 05:14 AM
Kamanari rear bottom dam mikaust Mid Atlantic Impreza Club -- MAIC 0 09-22-2005 07:32 PM
flipped rear sway bar victims paperchasin Brakes, Steering & Suspension 12 11-09-2004 04:16 PM
How do you un-flip a flipped rear sway bar? drdome99 Brakes, Steering & Suspension 4 09-19-2004 12:47 PM
OEM USDM STi rear sway bar, sway links, rear lateral links BIGSKYWRX Private 'Wanted' Classifieds 7 01-15-2004 10:00 PM
