Old 04-20-2002, 01:19 PM   #1
Scuby Snacks
Member#: 17730
Default Vishnu chip with TXS harness
Does anyone know if the TurboXS harness for their unichip will work on the Vishnu unichip?
Scuby Snacks is offline   Reply With Quote
Old 04-20-2002, 01:48 PM   #2
FreeBMW
Member#: 10927
2008 BMW 135i
Fire Orange / gutted
Default it can be done
its been done...you have to do a little rewiring on the plug-n-play harness because TXS & Vishnu use differant methods (Throttle pos & load).
Last I heard TXS had a set of direction or at least a pinout that they were sharing.
I have a Vishnu unichip & it ONLY needs 4 or so wires connected & its not hard to return the car to stock.
FreeBMW is offline   Reply With Quote
Old 04-20-2002, 02:28 PM   #3
snookem
Member#: 11438
Also the turboxs harness has a safety built into it if ever the unichip wants to fry the ecu.
Something to think about????
snookem is offline   Reply With Quote
Old 04-20-2002, 06:17 PM   #4
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
call Mark at TurboXS. He apparently is the one that can tell you how to do this modification.
nhluhr is offline   Reply With Quote
Old 04-20-2002, 11:56 PM   #5
STi_Pete
Member#: 14576
2002 WRX Sedan
If you call Vishnu I believe I heard that they have a harness to plug into the TXS to convert the wiring from TPS to MAP
STi_Pete is offline   Reply With Quote
Old 04-21-2002, 07:32 AM   #6
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
i'm pretty sure that's not true, as i've been in contact with Joel at Vishnu and he hasn't mentioned ANYTHING like that. unless... it's a brand new item!
Old 04-21-2002, 09:31 AM   #7
NotoriousWRX
Member#: 9026
Honestly, if you're convinced that the Vishnu Unichip is the way to go, then don't even bother worrying about splicing a few wires. With some care and inginuity, it can be done and undone without a trace, so that should be the least of your considerations.
NotoriousWRX is offline   Reply With Quote
Old 04-21-2002, 09:46 AM   #8
WRBLUEWAGON
Member#: 10745
2006 VW SUV
Ya Alex, Come to the light!!!
Eric
WRBLUEWAGON is offline   Reply With Quote
Old 04-21-2002, 09:57 AM   #9
cronic
Member#: 9749
hey nice numbers guys! i cant wait to get my chip back in to see how it feels with the uppipe. Alex what pullies do u have?
Dave
cronic is offline   Reply With Quote
Old 04-21-2002, 12:32 PM   #10
NotoriousWRX
Member#: 9026
Dave
Suby Sports lightened pullies.
Old 04-24-2002, 08:34 PM   #11
bugelrex
Member#: 14255
MBP
I'm interested in how one can hookup the unichip without trace. Anymore details on this? I'm concerned I may have trouble reselling the car with the ECU hacked. Even I would have second thoughts about buying a used car with a tampered ECU....
Thanks
bugelrex is offline   Reply With Quote
Old 04-24-2002, 09:56 PM   #12
Jon [in CT]
Member#: 2992
02 WRX Sedan
Thanks
I'm curious, too. The Vishnu Unichip install requires that you cut the MAF signal wire. What kind of "care and inginuity" will not leave a trace after you've done that?
Jon [in CT] is offline   Reply With Quote
Old 04-24-2002, 11:56 PM   #13
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
Perhaps not a trace, but at least not a easily found trace... use male/female spade plugs on each end of the wire you cut and when you remove the the unichip, you can just plug them back together.
Old 04-25-2002, 12:57 AM   #14
Penguinking
Member#: 9422
2002 silver
wrx R.I.P.
um...when they look at the ecu and notice that some of the wires are connected with male/female plugs, im pretty sure they'll think someone just MIGHT have cut the wires at one point
Penguinking is offline   Reply With Quote
Old 04-25-2002, 08:08 AM   #15
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
get real... how often do you think the guys at Subaru service tear up the carpet, unbolt the ECU housing, and peel back the plastic insulation to see if anybody has had a unichip installed?
Old 04-25-2002, 08:54 AM   #16
Jon [in CT]
Member#: 2992
02 WRX Sedan
The diagnosis procedure for nearly every CEL trouble code usually begins by assessing whether there is a problem in the wiring between the ECU and a sensor. If you take your car in for service because your check engine light is on, you should expect that a Subaru technician will be inspecting your ECU's wiring.
Old 04-25-2002, 07:31 PM   #17
Penguinking
Member#: 9422
2002 silver
wrx R.I.P.
yup yup...thats why i'm a bit worried since i've already got my vishnu unichip installed. but i havn't had any serious engine trouble yet (4000mi so far and only one cel from the stage zero) and i don't intend on selling my car for a long time, so i guess i'll be alright.
what do you think the subaru tech's will do if they see you've cut into the ecu?
hehe...maybe they'll be impressed by your wiring skills
Vishnu Xede With Sti Harness $650 / possible trade for intercooler subfuzion Private 'For Sale' Classifieds 0 01-01-2006 10:15 PM
Vishnu Unichip Stage 0 with TXS V3 Harness wrk king Private 'For Sale' Classifieds 2 08-20-2003 08:29 AM
TXS harness compatible with vishnu chip? wrxxed Engine Management & Tuning 9 12-15-2002 11:13 AM
Using Turbo XS ECU harness for Vishnu Chip TheShadowWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 12-12-2002 06:25 PM
whats up with the vishnu chips? spike Engine Management & Tuning 1 11-10-2002 01:45 PM
