Old 05-07-2009, 12:41 AM   #1
Mike26
Member#: 50341
98 2.5rs
Wr Blue
Default Sti block to NA
I recently bought a 98 impreza rs with a blown shortblock. I have access to a rebuildable sti block. Does anybody have any info on using the sti block and converting to NA. I would be reusing the 2.5 NA heads. From what I read in the service manual, the bore and stroke is the same. Could I just swap new NA pistons. I am looking at JE pistons. Would there be any benefits from using this block, with Sti rods, Stock Sti Crank, and the JE pistons. I am pretty sure it could handle more abuse. I know I have to check and make sure the rod length is the same. I saw they have two different rod lenghts for the Sti shortblock.
Mike26 is offline   Reply With Quote
WTB: EJ25 Short Block for NA '01 RS chanomatik AKIC Private Classifieds 4 02-25-2010 08:58 PM
version 8 STi spec c block to a ver 8 sti block essejwrx Built Motor Discussion 10 11-07-2006 01:29 AM
2.5 STI block v 2.5 na blacktalon606 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 04-20-2006 11:54 AM
Could you NA an STI block to get a lot of power rs inname stiatheart Subaru Conversions 18 09-28-2004 03:59 PM
When is the Sti coming to NA Forge Motorsport Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 11-30-2002 12:03 AM
