View Poll Results: Are you Happy with your Raw Performance Block?
Yes! I couldn't be happier. 36 56.25%
Yes! I did have some issues, but all in all I have really enjoyed the motor. 7 10.94%
No! I have had more issues than it is worth. 21 32.81%
Voters: 64. You may not vote on this poll
Old 05-14-2009, 05:22 PM   #51
jordanretro1223
Member#: 143039
2007 STI
Satin White Pearl
Is the cross drilled crank an option on any block Ron sells?
Or does it only come with specific blocks, like the signature series? So the street won't have the cross drilled...
I think I'll get on the site and do some research.
jordanretro1223 is offline   Reply With Quote
Old 05-14-2009, 08:40 PM   #52
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
I'm not even sure if he still offers the crossdrilled cranks, they could be from the old axis stage 1-5 motors. From what I was told, and correct me if im wrong, the site says just a modified ej257 crankshaft. Does anyone know for sure which blocks come with the crossdrilled crank still?
D Money is offline   Reply With Quote
Old 05-14-2009, 10:20 PM   #53
mannslayer
Member#: 94978
what i can't understand is why ron would sponsor a show car and not a road race / time attack car so he can actually put his motors to the test while getting some good r&d data at the same time. perhaps he does and i am just not aware of it?
either way, i've never had a built engine, but from everything i've read over the years of being on this forum, ron would probably be my first choice.
mannslayer is offline   Reply With Quote
Old 05-15-2009, 01:59 AM   #54
jordanretro1223
Member#: 143039
2007 STI
Satin White Pearl
D Money's car will be tracked. Give the guy a break people....
Old 05-15-2009, 10:30 AM   #55
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
Yeah me either. Probably because the car is getting built to be a race car this time around, but at the same time it can still hardpark on the cover of modified magazine as well.
haha don't worry about that kid. I punk'd his friend or something and he's still butthurt.
Old 05-15-2009, 01:37 PM   #56
4ST-AIR
Member#: 148681
TBD Looking for STI
Back in the Game!
The cross drilling is the modification (along with being balanced)
The Track & The Signature Series do.
4ST-AIR is offline   Reply With Quote
Old 05-15-2009, 01:46 PM   #57
Stames_wiltz
Member#: 143264
2006 WRX TR
Obsidian Black Pearl
Here are 2 pm's I received that I will leave their identity alone. Just thought they would be worth sharing.
Anonymous #1 "Listen, I agree with most of what has been said in this thread about Ron's customer service. He is very good in that regard. I had a stage 3 Axis (not RAW) block, and so did a few others that I personally know very well. All of us had the same block and the same issues. Ron's biggest downfall with this particular stage 3 block was the use of loose rod bearing clearances and a "double cross drilled crank". This equals plummeting oil pressure as rpm increases. I have a video of the pressure drop and so do others. People who voted negatively are not posting because they really like Ron (as do I), but he has a problem admitting his mistakes on builds. He did eventually did own up to the problems and he made things right but never accepted full responsibility. I would buy parts from him or give him specs to build a motor to, but I would not ask him to give me his own specs/interpretation of what he thought I needed for my desired hp level.
Cliff's notes: Ron is a good guy and good resource but do NOT buy a cross drilled crank from him unless it was done at the factory by Subaru!"
Anonymous #2 "My RAW1 built motor blew up after 5k miles. Ron built it but it is not one of his standard builds. He said some things that really scared me during the build-up. Most notably he said that the crank wouldn't spin in the block when he first dropped it in, but he tried again and it was OK so it must have been a hard chunk of assembly lube. Why the hell would he say that unless he was concerned about it? So I was always scared about spinning a bearing and I saved all my used oil filters. A few days before it blew up I cut open the first and last filters and there were metal shavings in all of them. Two days before it let go I really started freaking out because I cut open a filter from an STI motor that had a known bearing problem and that filter had less metal in it than mine. I got a blackstone oil test kit but the motor let go before I could get enough miles on the oil to pull a sample.
The motor should be out this week and we'll be sending it back to Ron. I will post about this once we know what killed it. For all I know it might have dropped a valve, but everything points to a bearing problem. It sounded like silverware in a garbage disposal when it let go. The crank was not cross-drilled FWIW."
Stames_wiltz is offline   Reply With Quote
Old 05-15-2009, 02:49 PM   #58
madmax718
Member#: 172501
From an advertising standpoint it makes more sense to put your name on a show car. Even if the car doesn't move, its still brand impression, and it reaches a lot more people than on a track only car which sits inside except on track days.
I dont have a garbage disposal so I cant comment on what that sounds like. I've bent a cam before, it also wouldnt spin freely. Cranks are picky- I recall chevy cranks being stored upright so that they dont sag!
madmax718 is offline   Reply With Quote
Old 05-15-2009, 04:18 PM   #59
jordanretro1223
Member#: 143039
2007 STI
Satin White Pearl
Pretty interesting stuff.
I personally see no need to get anything past the street series for anything I'll be needing down the road. I will never track the car and probably never drag it either.
That being said, if I did go track series, I'd request the STI crank to be left untouched. It's common knowledge that the STI crank and rods are VERY strong and well put together components. I've never seen anyone with failures on those parts (failure because of those parts only of course).
Definitely interesting stuff in here. Good thread Stames.
Old 05-15-2009, 04:50 PM   #60
unclemat
Member#: 114530
2005 LGT 6MT wagon
I heard from Ron that these folks insisted on these bearing clearances (there was few of them) and Ron made it to their spec, warning them of the consequences/limitations.
Ron is a good guy and takes care of their customers.
unclemat is offline   Reply With Quote
Old 05-15-2009, 05:21 PM   #61
4ST-AIR
Member#: 148681
TBD Looking for STI
Back in the Game!
Once again listening to Ron pays off.
Old 05-15-2009, 08:04 PM   #62
mannslayer
Member#: 94978
Old 05-16-2009, 01:00 AM   #63
NightriderWRX
Member#: 69407
2004 Subaru WRX STi
Java Black Pearl
Almost 20k on my block never had issues.
NightriderWRX is offline   Reply With Quote
Old 05-17-2009, 11:31 AM   #64
Stames_wiltz
Member#: 143264
2006 WRX TR
that is good to hear. I should have the new block in a few weeks.
Old 05-18-2009, 05:31 PM   #65
PPhilthy
Member#: 102948
2006 STI
Originally Posted by 4ST-AIR View Post
My oil pressure I would say is a little lower than a normal 2.5Ltr. I run the Rotella 15W40 like Ron requests you do and I rev to 7500RPM's all day long. At 7K in 3rd I hit about 65psi (oil pressure) I idle at 900RPM's and about 16-18 psi.
I use nothing but Motul 15W/50 and have Ron's Signature Short block, at idle I'm around 370-400KPA (53-58PSI) and as soon as I hit the gas either cruising or full tilt I'm at 600-630KPA (87-91PSI)... It's been like this since first start up and I have ~5k miles on the motor now...
PPhilthy is offline   Reply With Quote
Old 05-20-2009, 01:17 PM   #66
Stames_wiltz
Member#: 143264
2006 WRX TR
I am planning on the rotella until about 2,ooo miles. Then I will go with Redline full synthetic.
Old 05-21-2009, 01:47 AM   #67
car_cursed
Member#: 85327
1964 Miata
Hairdresser Red
stames you should ask ron if he still uses his machinist here in slc, west valley actually, saves you shipping him the heads and him shipping them here
car_cursed is offline   Reply With Quote
Old 05-21-2009, 03:23 PM   #68
doug*E*fresh
Member#: 116794
02 wrx
sedona red
Everything on my car was built or installed by raw never had a single issue. If there ever is an issue he takes care of things 100 percent. They are up front with their guarantees and they'll stand by their word. He even picked my car up when it blew the OEM motor. He worked with me alot to get me back on the road. My car is there right now. As people have said above if you listen to his rules you wont have a single problem.
doug*E*fresh is offline   Reply With Quote
Old 05-22-2009, 10:09 AM   #69
4ST-AIR
Member#: 148681
TBD Looking for STI
Back in the Game!
Might want to talk to Ron about that before you go that route.
Old 05-22-2009, 10:14 AM   #70
OppositeLock
Member#: 54060
Now: 16 FXT/04v8 207
Then:JRTuned fastest td04
Just curious, what is his usual recommendation for break in oil and how long before he deems it o.k. to switch to syn? Thanks for any info.
OppositeLock is offline   Reply With Quote
Old 05-22-2009, 10:29 AM   #71
4ST-AIR
Member#: 148681
TBD Looking for STI
Back in the Game!
That you would have to run by Ron. He never mentioned running Synthetic in any of my conversations.
I personally change oil every 800-1000 miles. I also used a lighter oil for break in then at 300 miles I went with the Rotella. It gets well into the -40* with windchill in winter here and I run Mobil 10W40 during the winter months.
Also I broke my engine in with a 4K rev limiter on it for 1800 miles.
Old 05-22-2009, 10:54 AM   #72
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
I had one in my 02 WRX till I got hit head on Ran Rotella 15W40.
I have a built motor now, not an Axis/Raw, but I figure I should still take his advice, so I run Rotella 15W40.
I dont remember who, but I have seen 2 other big name builders recommend that same oil.
BTW I wanted to point out that my new motor not being a Ron motor, has NOTHING to do with the quality of the Ron motor I had, It was very quiet for a forged motor, and Ron's customer service was top notch. I just got a better deal from a local builder who gave me a "friend" price.
Defiant Autospeed is offline   Reply With Quote
Old 05-22-2009, 12:19 PM   #73
Stames_wiltz
Member#: 143264
2006 WRX TR
I already stopped into this guys house to drop off my heads. He is still shipping the heads to Ron and Ron is going to put the longblock together.
Old 05-22-2009, 04:24 PM   #74
4ST-AIR
Member#: 148681
TBD Looking for STI
Back in the Game!
Mines a little chatty but I like that way. The piston slap is nothing compared to what I thought it was going to be.
Old 05-30-2009, 08:41 PM   #75
Stames_wiltz
Member#: 143264
2006 WRX TR
Ron called me and gave me the flow differences on my heads. I had the local Guy that does headwork for Ron do the "R&R" service. They re-seated/machined the valves, sunk them and did a multi-angle valve job. Cleaned them up etc... Now I don't know exactly what pressure they flow these at but Ron did give me a comparison.
Stock heads intake flow... 215
My heads now flow... 231
Stock heads exhaust side flow... 175
Mine now flow... 192.6
a 33.6 gain in flow without porting is freaking amazing. Ron was saying that he was surprised at the gains with pretty much just a valve job. He said if I wanted to there is a way to convert it by multiplying my #'s by 1.06 and I would get something. But I didn't really understand so I will leave it as it is. But with the conversion he said I picked up 60 CFM. My motor should be all put together and shipped this thursday. I am getting pretty excited.
Axis/Raw Performance customers....... boogerwrx Built Motor Discussion 738 05-20-2015 03:54 PM
21500 miles on an Axis / RAW Performance motor TurboQueef Built Motor Discussion 29 11-03-2010 10:13 PM
FS: Axis/RAW performance longblock P&P heads builtgt35rsti Engine/Power/Exhaust 27 05-24-2009 04:12 PM
Axis/Raw performance??? adofly General Community 19 05-08-2009 07:00 PM
How do you view your own old posts? myko011 General Forum Archive 2 03-19-2001 10:51 PM
