Welcome to the North American Subaru Impreza Owners Club Tuesday May 5, 2015
Old 05-07-2009, 11:29 PM   #1
rogue
call me Apples
Super Moderator
Member#: 7977
100% Abuse
PWN3D Sunroof won't close (will open) Pretty positive it's the relay.
Busted out the multimeter, ripped the ceiling apart, checked all the wires... all connections are good, but the damn thing won't close. It WILL open just fine. I can hear the motor churning away trying to open more.
I'm thus pretty sure it's the relay that's to blame. Unhooked and reseated all connections and it still won't close.
Any way to get one of these other than hoping the local Subaru parts department can hook me up? Probably not.
2001 RS coupe.
rogue is offline   Reply With Quote
Old 05-08-2009, 10:55 AM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
Have you checked to see if the switch is working ok in the close position? That would be my first suspect.
Old 05-08-2009, 11:07 AM   #3
rogue
call me Apples
Super Moderator
Member#: 7977
100% Abuse
Yup, used the multimeter.
Old 08-17-2009, 10:42 AM   #4
18rabbit
Member#: 220626
1997 328i
I have a similar problem..need some advice
18rabbit is offline   Reply With Quote
Old 08-17-2009, 11:29 AM   #5
rogue
call me Apples
Super Moderator
Member#: 7977
100% Abuse
Mine was the sunroof relay. $100 from Subaru, no aftermarket parts available that I could find. It's a small black plastic piece, about the size of a golf ball, with a wire connector hooked up to it. It sits right up in the ceiling next to the overhead light, behind the roof felt.
For now, pull the little plastic tab off the ceiling just next to the overhead light, and you'll see a plastic gear with a hex hole in the center. Use the big allen wrench found in your trunk and turn that manually (or use your own allen wrench from a tool kit) and the sunroof will close manually.
Old 08-17-2009, 04:22 PM   #6
18rabbit
Member#: 220626
1997 328i
Great thanks!
Old 08-21-2009, 11:05 AM   #7
18rabbit
Member#: 220626
1997 328i
Ok I located this and have the allen wrench in there. I have the battery disconnected and turn one way the rear sunroof opens when I turn the other way the sunroof closes but I cant get the dame moonroof vent to close any Ideas???
Hood won't close all the way? HAL1 General Community 15 12-15-2005 01:22 AM
2004-05WRX Sunroof open/close question pat3 Newbies & FAQs 12 09-03-2004 11:49 AM
my hood won't close ychan Service & Maintenance 11 02-18-2003 08:47 AM
DOHC heads on a 2.2L I am pretty positive they fit but... MPREZYA Normally Aspirated Powertrain 2 11-28-2000 06:30 PM
Sunroof won't open, but will close ecfitzgerald Interior & Exterior Modification 3 10-23-2000 05:40 PM
