Old 05-08-2009, 07:59 AM   #1
drunkon2canz
Member#: 177770
2008 WRX Hatch
Dark grey
Default Do i really need F/R sway bars...
If i purchase springs..I searched the forum but it didn't say or maybe im not looking in the right spot.. Does anyone know... Im buying springs mainly for looks if that helps...
drunkon2canz is offline   Reply With Quote
Old 05-08-2009, 08:09 AM   #2
Y_I_K_E_S
Member#: 159449
2005 WRX STi
"Ali"
Honestly, if you're going mainly for looks, I wouldn't bother.
Y_I_K_E_S is offline   Reply With Quote
Old 05-08-2009, 08:24 AM   #3
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
You mean do you need to upgrade, or do you need them at all? The answer to both is no. They are nice to have though.
garface is offline   Reply With Quote
Old 05-08-2009, 08:27 AM   #4
ThreeEleven
Member#: 157894
2007 WRB WRX
EJ257
You already have sways (if you didn't know that) You don't HAVE to, but getting sway bars that are larger in diameter than stock will greatly increase your handling and responsiveness. When upgrading sways, you should upgrade your endlinks as well. Ungraded sway mounts are also recommended but not ABSOLUTELY needed.
To answer your question, no you don't need to upgrade for the springs to work. That's what it sounded like you were asking.
A good read:
http://forums.nasioc.com/forums/showthread.php?t=171928
ThreeEleven is offline   Reply With Quote
Old 05-08-2009, 09:24 AM   #5
ScoobyDreamer
Member#: 199502
2011 2.5i
^^ Completely off topic....but ThreeEleven = Best name ever on here Love them
ScoobyDreamer is offline   Reply With Quote
Old 05-08-2009, 09:27 AM   #6
Slack
Member#: 17548
How will you be using your car? Mostly everyday commute? Auto-x? Track days? We can't answer your question without this information.
Slack is offline   Reply With Quote
Old 05-08-2009, 10:20 AM   #7
drunkon2canz
Member#: 177770
2008 WRX Hatch
Dark grey
Its everyday commute... i mean there are times where i do take corners at about 65-70 and the car sticks to the road fine, even though the tires are garbage (RE92)... But thats something i don't do everyday... No auto-x but i was planning on taking my car to the Tracks this summer since i've never done it before, but thats just a straight road.
Old 05-08-2009, 10:53 AM   #8
hatchd
Member#: 201307
2002 wrx
wrb
They're not that expensive and if you really like to drive the cars then I would definitely upgrade the sway bars. It makes a vast difference on the car if you do upgrade.
But, if you're going for looks only no need to do it at all. They are not needed by any means just to lower the car.
hatchd is offline   Reply With Quote
Old 05-08-2009, 11:41 AM   #9
leecea
Member#: 37359
2003 WRX
... i was planning on taking my car to the Tracks this summer since i've never done it before, but thats just a straight road.
Not all tracks are straight. Anyway, sounds like sways will be a waste of money for you. Save money for better tires instead.
leecea is offline   Reply With Quote
Old 05-08-2009, 12:57 PM   #10
GreenMarine
Member#: 36080
If you are getting springs then the FIRST thing you'll need after you purchase them are new struts to properly take advantage of the spring rates and length of the new springs. Swaybars will definitely help with cornering (go with as large as possible in the front = GREAT turn in, and a medium to large one in the rear = keeps the rear planted) but they will not handle everything... Your stock struts will probably work fine for a while, but they will wear out alot quicker with higher spring rate springs. Granted, getting larger swaybars should help the stock struts from wearing out as much by controlling the spring movement slightly but really that is kinda a "side affect"... Start planning ahead for struts... Koni Yellows are AWESOME... Ohlins are expensive but also AWESOME...
Hope that helps out alittle
~ Chris
GreenMarine is offline   Reply With Quote
Old 05-08-2009, 02:02 PM   #11
leecea
Member#: 37359
2003 WRX
Edited away!
Do you really like your front sway bar? phyzical Transmission (AT/MT) & Driveline 3 07-31-2005 01:06 PM
Do i really need both front and rear sway bars? titanium wrx Brakes, Steering & Suspension 4 05-29-2004 08:41 PM
Do you really need new links for sway bars? wolfman Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 10-09-2002 01:58 AM
Do I need a front sway bar? Tim Prudence Technical Forum Archive 11 05-22-2000 10:32 AM
My first autocross. I really need that 18mm sway bar! Snoopy General Forum Archive 17 05-09-2000 09:35 PM
