Old 04-20-2002, 08:12 PM   #1
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
Default Stock US wire diagram has some errors
Be careful if you are following the Subabru Factory wiring diagram - it has several points were it is not the same as whats in my car !
alfriedesq is offline   Reply With Quote
Old 04-21-2002, 12:53 AM   #2
Austin
Member#: 7089
2016 STi
Examples?
Austin is offline   Reply With Quote
Old 04-21-2002, 01:01 AM   #3
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
P - EN - 27
item - TVG sRH ignal - it says plug B84 - - it is reallky in plug B135
same with TVG LH signal - lists wrong plug - its in B135
Old 04-21-2002, 01:06 AM   #4
DJIMPREZA
Member#: 1199
1994 Supra+1K, 22b
alike, 07STI
does they match with our ECM diagram???
DJIMPREZA is offline   Reply With Quote
Old 04-21-2002, 01:57 AM   #5
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
NO - very strange the EXPORT diagram for other countires has it correct - - just be carful to double check on the cars before you cut !
Old 04-21-2002, 02:15 PM   #6
Jon [in CT]
Member#: 2992
02 WRX Sedan
Are you sure you're not confusing the TGV angle sensors (connected to B135) with the TGV actuators (connected to B84)? Can you post an image of the foreign diagram?
Jon [in CT] is offline   Reply With Quote
Stock EGT Wiring Diagram 02slvr_wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 03-07-2007 02:09 AM
Stock Radio Wiring Diagram Jayspeed Electrical & Lighting 2 09-14-2003 05:01 AM
stock computer wire diagram U Newbies & FAQs 3 11-26-2002 12:10 AM
BG stock headlight wiring diagram needed monovich Legacy Forum 6 09-09-2002 07:16 PM
Stock Harness Wiring Diagram Nick Car Audio, Video & Security 2 07-18-2000 10:57 AM
