Texas Impreza Club
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC > TXIC Vendor Classifieds
Closed Thread
Old 05-08-2009, 12:18 PM   #1
awdtuning.com
Vendor Sales Rating: (59)
Member#: 183645
2007 STi & 09 SpecB
www.awdtuning.com
Subaru Stars GrimmSpeed 3 Port Boost Control Solenoid- In Stock!
I've been using GrimmSpeed's 3-Port Boost Solenoid for some time now and have found their solenoid provides rapid boost response while maintaining the ability to make acute adjustments via turbo dynamics. While many other boost control solenoids react to adjustments too fast which can make them difficult to control with as much finesse as the stock bleed system. This solenoid can make micro-adjustments at the edge of target boost not only providing better spool, but overall more control. Additionally, the solenoid is plug n' play so you do not have to splice into the wiring harness for it's installation.
GrimmSpeed introduces the most complete and easy to use 3-Port Electronic Boost Solenoid available on the market. Their aftermarket boost controller allows you to raise the OEM boost levels in a quick and efficient manner. If you try to raise the boost on the weak OEM boost solenoid it will start to become unpredictable and unable to maintain proper and safe boost levels. Using GrimmSpeed's solenoid you are able to spool your turbo quicker and maintain a rock solid boost level. They have made the solenoid to withstand 120psi, way more than any Subaru will see
Revolutionizing the Subaru boost solenoid market, GrimmSpeed has created model specific install brackets that allow you to directly fit our Boost Solenoid into your Subaru for a factory fit. No more Zip-tying! They give you the factory fitment you have been waiting for.
Staying with the OEM fitment theme, GrimmSpeed's Boost Solenoid uses a Subaru style wiring harness so you can simply unplug your OEM solenoid and plug ours in. No more cutting the oem wiring and crimping wires together!
Also new to the Subaru boost solenoid market, they have used ultra low-profile hose fittings to keep the unit as small and clean as possible. The hose fittings are nickel plated brass so you don't have to worry about them snapping off like the plastic hose fittings!
Features:
  • Direct plug and play into oem wiring.
    MAC Valve has completely custom made the valve for us(only MAC valve on the market to be custom made for automotive tuning use).
  • Users can use AN fittings with the solenoid.
  • Mounting bracket so its a direct bolt on into factory location.
  • Low-profile brass hose fittings(small in size so its compact, no chance of breaking fittings like the plastic ones our competitors use).
  • Specifically designed by GrimmSpeed to work safely with the factory Subaru ECU (requires tuning) and to reliably handle the vibrations and temperatures of your engine bay!
  • The only direct “bolt in” design for all Subaru models. Direct bolt in mounting bracket and hardware included! (specify which model before ordering)
  • Includes plug and play harness, no wire splicing required and easy to return to stock.
  • Allows you to raise the factory boost levels with adding more response and more control.
  • Allows you to get full boost sooner.
  • Faster response and greater flow than any other valve out there. (by more than 10%!)
  • Nickel plated brass fittings. (unlike the competitors failure prone plastic fittings)
This BCS will handle all your boost control needs no matter what your power goals are.
*This will require a new tune, but it's real easy for your tuner to tune.
3 bracket variations fit all Turbo Subaru models!
Solenoid and Bracket attached to 05+ LGT and 08+ WRX OEM bracket
Solenoid and Bracket attached to 08+ STi OEM Bracket
awdtuning.com is offline
Old 05-08-2009, 12:34 PM   #2
wrx_02
Member Sales Rating: (5)
Member#: 188471
Far superior product when compared to others on the market. I have one they are great!
wrx_02 is offline
Old 05-13-2009, 11:01 AM   #3
txjunglist
Member Sales Rating: (2)
Member#: 11926
2011 Outback Limited
Dark Grey
nice looking peice.
txjunglist is offline
Old 05-14-2009, 12:16 AM   #4
kirbwrx
Member Sales Rating: (25)
Member#: 110450
2007 Spec.b Refugee
284hp 320tq Cobb Tuned
i love mine
kirbwrx is offline
Old 05-14-2009, 11:06 AM   #5
YourMother'sLover
Member Sales Rating: (33)
Member#: 76565
CLXX Stricta Parata
Neci!
Bump for an awesome product!
YourMother'sLover is offline
Old 07-13-2009, 01:49 PM   #6
awdtuning.com
Member#: 183645
2007 STi & 09 SpecB
www.awdtuning.com
we have several BCSs in stock right now
Closed Thread
Unbeatable Pricing on New Grimmspeed 3 Port Boost Control Solenoids! maperformance Accessories & Misc 385 06-15-2010 11:03 AM
FS: Grimmspeed 3 Port Boost Control Solenoid, New lickwid Engine/Power/Exhaust 3 01-18-2010 12:18 PM
FS: Grimmspeed 3-Port boost Control Solenoid Ditchthefury Engine/Power/Exhaust 12 05-10-2009 02:10 PM
GrimmSpeed 3 Port Boost Control Solenoid Group Buy! awdtuning.com Vendor 'Group Buy' Classifieds 479 04-24-2009 11:46 AM
New Grimmspeed 3 Port Boost Control Solenoids In Stock / Free Shipping! maperformance Accessories & Misc 7 02-27-2009 02:50 PM
