Old 05-08-2009, 01:14 PM   #1
xcdhridr
Member#: 58865
2004 WRX
99ESP - Drew =)
Default Whiteline 27-29mm Front bar question
It's been too long since I installed it. when installed, which hole is which? Is the front (front of car) hole the 27mm one?
Thanks
xcdhridr is offline   Reply With Quote
Old 05-08-2009, 01:53 PM   #2
chazly413
Member#: 151079
2005 2.5RS RBP
too many friction losses
chazly413 is offline   Reply With Quote
Old 05-08-2009, 02:21 PM   #3
xcdhridr
Member#: 58865
2004 WRX
99ESP - Drew =)
Originally Posted by chazly413 View Post
Thanks, but not much help. The holes are the whiteline ar both very close to the same distance apart so it's really not easy to tell....
Old 05-08-2009, 02:42 PM   #4
flukewrx
Member#: 75081
2003 WRX
How is that picture not helpful? The farthest hole out on the bar is the lowest setting on an adjustable bar. The closer the hole is to the main section of the bar the higher the setting.
flukewrx is offline   Reply With Quote
Old 05-08-2009, 04:27 PM   #5
xcdhridr
Member#: 58865
2004 WRX
99ESP - Drew =)
the holes aren't oriented like that on an adjustable front sway bar
Old 05-08-2009, 05:34 PM   #6
viper74656
Member#: 84758
'04 WRB WRX
When the bar is installed, the hole towards the front of the car is the stiffer, and visa versa.
Put another way, the hole closer to the main body of the bar is the soft setting (I think I'm orientating this right?)
viper74656 is offline   Reply With Quote
Old 05-08-2009, 07:04 PM   #7
BIGSKYWRX
Member#: 7958
09 GH B+
^ that's correct front hole stiff, rear softer- here's a pic I posted a couple of years ago same question (mine is in the "soft"- rear position)
http://forums.nasioc.com/forums/show...68&postcount=8
Old 05-08-2009, 07:06 PM   #8
STi-MAN
Member#: 70252
05 STI
blue
the hole shortening the distance from the bar itself will always be stiffer.
STi-MAN is offline   Reply With Quote
whiteline 27-29mm front sway bar STi-MAN SCIC Private Classifieds 4 06-22-2009 12:36 PM
I'm on tein flex with a 27-29mm front bar whats a good size for the rear? scobaru Brakes, Steering & Suspension 3 04-10-2007 04:49 PM
Whiteline 27-29mm Front swb and 24-26mm Rear swb plus endlinks maxim05 Suspension/Brakes/Handling 11 04-10-2007 06:33 AM
Whiteline 27-29mm Front Sways and Everything Cusco!!! RaceComp Engineering MAIC Vendor Classifieds 37 10-23-2006 03:24 PM
Whiteline 27-29mm adj bar. STi-MAN Car Part Reviews 2 03-05-2006 02:20 PM
