Old 05-08-2009, 04:28 PM   #1
supernick77
Member#: 145122
1999 99 lgt, 86 brat
black, lt blue
Default will it fit? sti v4 and 02 wrx parts
i have a wrx engine with a bad piston like some of you might have read. i found a v4 sti block with good pistons but the crank needs polished. my 02 wrx crank and rods are perfect. can i put my crank and rods with his pistons and block. and will the rest of my top end bolt on correctly? both are 2.0 i have my fingers crossed help me out. thanx
supernick77 is offline   Reply With Quote
Old 05-08-2009, 07:29 PM   #2
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
not without machining .. he thrust bearing is different
Old 05-09-2009, 08:06 PM   #3
supernick77
Member#: 145122
black, lt blue
what kind of rod bearings should i get for it? is there anything special about the sti crank shaft? is it interchangable with any others?
06 STi and 02 WRX parts - going stock sale acolsubie Engine/Power/Exhaust 4 05-07-2008 09:48 PM
stock sti and 02 wrx parts kinada423 Engine/Power/Exhaust 0 01-24-2008 01:02 AM
06 STi and 02 WRX parts (stock & aftermarket) Einherjar MAIC Private Classifieds 48 05-28-2007 11:45 PM
('93-'01) will it fit? STi V8 spoiler newgensti Impreza Forum 3 06-04-2006 04:15 PM
FS: 04 USDM STi and 02 WRX Parts bullseye17 Private 'For Sale' Classifieds 39 03-07-2004 01:04 AM
Message Board Statistics All times are GMT -4. The time now is 01:38 AM.
