Old 05-08-2009, 07:13 PM   #1
blackburn_wrx_2005
Member#: 106306
2003 WRX
yellow
Default v6 STi Cluster
okay, i am talking to someone about buying a v6 jdm cluster for my '03 wrx. the only thing i have found on wiring in clusters is for v7 and it appears to be a PITA! so would the v6 be a plug and play in my suby or does it fall under this soldering wiring madness too???
blackburn_wrx_2005 is offline   Reply With Quote
Old 05-09-2009, 10:44 PM   #2
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
will the v6 even fit into the interior of the 02/03?
jdubya301 is offline   Reply With Quote
Old 05-10-2009, 04:17 PM   #3
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
1. it's not designed to fit your dash
2. connecters are different so they won't fit the cluster
3. wiring?
Hyper is offline   Reply With Quote
Old 05-11-2009, 03:53 PM   #4
JavaBot
Member#: 156723
05 crp foresterX
rip 2.0i/2.5rs
I believe you have to clip a tab and snip some pins? GL you might want to research a bit...
JavaBot is offline   Reply With Quote
Old 05-11-2009, 04:01 PM   #5
blackburn_wrx_2005
Member#: 106306
2003 WRX
yellow
yea, thanks all for the input . i have to go with the v7 but just for the cluster it consists of cutting 1 wire and hooking up the rest. if i want the OAT working, now thats another story and something i probably wont look into at least for a while.
Old 05-11-2009, 04:04 PM   #6
JavaBot
Member#: 156723
05 crp foresterX
rip 2.0i/2.5rs
Find a pinout diagram I bet you can find it and make everything work. Or find someone else who has made it work and use their soldering/splicing techniques. GL
Old 05-11-2009, 04:12 PM   #7
blackburn_wrx_2005
Member#: 106306
2003 WRX
yellow
well the seller has everything from the v6 to the v8 clusters, so its no big deal. just the v6 was cheaper and thats the one i started on. 25 bucks more and i get the v7. no problem. i have a write up on the v7 also, describing everything to do for just a normal wire-up or if you want to incorporate the use of the OAT sensor.
Old 05-11-2009, 04:34 PM   #8
JavaBot
Member#: 156723
05 crp foresterX
rip 2.0i/2.5rs
Cool, GL post some pix!
V6 STi cluster, double cup holder, Ver 6 TMIC, STi RA heads RA Limited 1993 - 2001 Impreza Specific Parts 10 05-15-2009 06:13 AM
FS: V6 STI Cluster Drakar 1993 - 2001 Impreza Specific Parts 6 09-26-2008 10:32 PM
wtb v6 sti cluster Rdwrc Private 'Wanted' Classifieds 1 11-13-2006 10:53 PM
FS: V6 gauge cluster & 04 sti misc. stuff RR02wrx Interior/Dressup/Audio & Security 9 10-03-2006 09:07 PM
V6 Sti Guage cluster JDM Importers Private 'For Sale' Classifieds 1 09-19-2005 08:52 PM
