Old 05-09-2009, 12:36 AM   #1
nikiter
Member#: 190942
2006 Impreza WRX
JDM STi 6 Speed
Default Do you change oil every time after track?
Do you guys change your engine oil after every event?
I just got into lapping and ran 2 events on the same oil.
Motul 8100 5W30
I do take my car to its limits thats for sure. It sees alot 5500RPM at the track.
nikiter is offline   Reply With Quote
Old 05-09-2009, 06:11 AM   #2
lemon19mmm
Member#: 144545
GG Wagon
Self-conflict?
No, I used to run about 2000 street miles + one 2 days event for one oil change. After I got another daily car, I change the oil every other event now.
Just make sure to check the oil level, atleast once a week.
lemon19mmm is offline   Reply With Quote
Old 05-09-2009, 07:56 AM   #3
MasterKwan
Member#: 98961
2003 WRX
I change the oil every 2 track days. I check it every session and when I put gas in the car. 5w-30's not good for track days. Check your owners manual for severe service. I just put in 15w-50 this last change.
Old 05-09-2009, 07:59 AM   #4
dunk
Member#: 15359
I also change my oil every two events. I use 50 weight in the summer and 40 for Feb and Mar.
I change the tranny fluid once a year.
-Duncan
dunk is offline   Reply With Quote
Old 05-09-2009, 09:31 AM   #5
nikiter
Member#: 190942
2006 Impreza WRX
JDM STi 6 Speed
5w30 is not good? I just go with what manufacturer recoments.
I know a lot of guys in canada run 5w40 oil
Old 05-09-2009, 10:13 AM   #6
kalescustom
Member#: 147598
95 Impreza 2dr
Yeah, Motul recommends 5w-40 in the 8100 for all turbo'ed subies. Its great stuff. I would switch from the 5w-30.
kalescustom is offline   Reply With Quote
Old 05-09-2009, 11:16 AM   #7
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
Start getting oil analysis, I use BlackStone Labs, that way you can start making a decision to change the oil based on real data.
As you are changing the oil take a sample and send it off, this will give you your first baseline. The report will tell you a lot about the condition of your oil but one data sample is not much help. Track the time on the oil and what you did on it and you will start seeing a pattern in the oil quality based on that.
For example my oil contains the same amount of wear materials after 400 track miles as a street driven car over 3000 miles. After 600 miles the wear materials shoot up and the total base number, TBN, is very low and Blackstone recommends an oil change asap. TBN is a rating of the acid fighting additives left in the oil. For my peace of mind I change my oil after 400 track miles (I run 16 quarts of oil in my dry sump so I have way more oil than stock)
This no only gives you a better idea of how long you should run your oil but if things change in the engine you will see it in the report.
mick_the_ginge is offline   Reply With Quote
Old 05-09-2009, 11:19 AM   #8
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oh, before I had a dry sump and before I did oil analysis and before the car became a 100% pure track car I used to change my oil before a track day and then straight after it
Old 05-09-2009, 12:17 PM   #9
nikiter
Member#: 190942
2006 Impreza WRX
JDM STi 6 Speed
I guess its a good way to see but seriosly thats waaay too much for me to do. Busy with work an all.
But i see you're really......REALLY...into this.
Old 05-09-2009, 07:07 PM   #10
kcook
Member#: 78074
2005 STi
I change my oil a few days before my track weekend (2 day event). I use Castrol 5w-30 Full Synthetic and use 5 quarts. The manual says 4.8, but I've never had a prob :knock on wood:
kcook is offline   Reply With Quote
Old 05-10-2009, 08:11 AM   #11
growling_boxer
Member#: 165744
2000 LGT
2007 STi
taking an oil sample doesn't make the oil change take any longer. you just have to take the sample to the post office at some point. that will end up being less work than changing your oil more frequently just to be safe.
growling_boxer is offline   Reply With Quote
Old 05-10-2009, 10:12 AM   #12
PhantomPilot
Member#: 202275
Chapter/Region: PRSIC
2003 Impreza WRX
Sedona Red
Motul 8100 5W30
I change the oil before running any event, as well as the brake fluid (Motul only) and re-torque the chasi.
PhantomPilot is offline   Reply With Quote
Old 05-10-2009, 10:26 AM   #13
STi-MAN
Member#: 70252
05 STI
blue
I change my oil before every event.
STi-MAN is offline   Reply With Quote
Old 05-10-2009, 10:32 AM   #14
nikiter
Member#: 190942
2006 Impreza WRX
JDM STi 6 Speed
Would Motul 8100 5W40 be better for everyday driving/ weekend racing then Motul 8100 5W30?
As its thinner.
5W30 is probably better in colder temperatures then summer driving.
Old 05-11-2009, 08:31 AM   #15
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
I usally change my oil before every one. If the previous event was all in the wet, I might not change it before the next event.
Old 05-11-2009, 11:04 AM   #16
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
If your oil temps get as high as mine you should change it before every event. Your street use won't be as hard on the oil as your track event so race with the fresh oil and go to 7 eleven on the burned up stuff.
Element Tuning is offline   Reply With Quote
Old 05-11-2009, 11:17 AM   #17
growling_boxer
Member#: 165744
2000 LGT
2007 STi
out of curiosity, why wouldn't you change the oil after the event? then you would be using fresh oil on the street without ever getting it to the really high temps, so it would still be in good shape for your tack day. that has been the approach I have used unless I have already had the oil in my car for a little while.
Old 05-11-2009, 12:17 PM   #18
spazegun2213
Member#: 91208
the '13 Ktm Duke
I go, 3-5 events on oil before i change it. Then again My ls6 holds ~9.5 quarts of oil, I have an oil cooler and thats at most 20 running hours.
spazegun2213 is offline   Reply With Quote
Old 05-11-2009, 12:27 PM   #19
STi-MAN
Member#: 70252
05 STI
blue
^wowser..
Old 05-11-2009, 12:33 PM   #20
spazegun2213
Member#: 91208
the '13 Ktm Duke
Originally Posted by STi-MAN View Post
^wowser..
why wowser? M1 starts breaking down at 300 degrees, and I see 270 tops, so why is that so weird? its common knowledge that 3000 miles is a myth and many oils can go 4+ before a change is needed. I figure 20 running hours is WAY less than 4000 miles and with the amount of oil i have i doubt I'm doing any damage to the motor.
Old 05-11-2009, 12:34 PM   #21
STi-MAN
Member#: 70252
05 STI
blue
i should have explained my wowser..
i meant wowser, 9.5 qrts.
I'll be putting in my oil cooler soon.. car will prob take a extra 2 qrts im thinking.
Old 05-11-2009, 12:43 PM   #22
spazegun2213
Member#: 91208
the '13 Ktm Duke
oh ok, lol sorry about that. Most people say way to the length of time i go.
Yea, I have ~10ft of -6 hose, and an oil cooler that holds 1-1.5 quarts...
Old 05-11-2009, 08:30 PM   #23
nikiter
Member#: 190942
2006 Impreza WRX
JDM STi 6 Speed
Any recommendations on oil coller for '06 wrx?
Old 05-11-2009, 09:12 PM   #24
growling_boxer
Member#: 165744
2000 LGT
2007 STi
i've been told by multiple racers to use the biggest one you can fit with the largest tubing you can connect.
Old 05-11-2009, 09:16 PM   #25
dunk
Member#: 15359
The tubing size is critical. Don't use anything smaller than -10 (5/8th" ID)
-Duncan
changing oil before or after track day? dingsand Service & Maintenance 5 04-24-2003 01:42 PM
How often do you change engine oil with synthetic oil? malelee21 Service & Maintenance 53 04-14-2002 10:33 AM
Newby question, how often do you change your oil? SteveGood Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 09-21-2001 02:53 PM
How do you change gear oil? 2yLiTe Interior & Exterior Modification 4 11-01-2000 09:41 PM
