Old 05-09-2009, 01:53 AM   #1
jdeastty
Member#: 150039
New photos of car page 5
In Car Video of Hot lap page 5
5/30-31 Redline TimeAttack Update from Willow Springs - page 5
New Dyno graph 27.5 psi Mustang dyno - setting up Motec "PID"
Page 5
Photos of New Girodisk, Thx Martin Photos page 5
Dynotechnik and Derek Eastty LTD's 04 STI Time Attack Car (Running Modified class)
We are just finishing the final touches on the 04 STI make over with the New AMS Rotated HTA3586 Turbo kit, Motec M800, Cosworth intake, etc.... parts list below. We still need to do a few tweaks to the set up (spring in waste gate a little to soft, as you will see below on the Dyno HP/boost graph, boost drops off on the upper end). I think we can get a little more mid power and about 20 more HP on the top carrying it all the way out by getting it to hold boost to 8200 RPM. Engine is a built Cosworth - Billet crank with all the goodies.
Complete Parts list:
Engine/ECU/Turbo/fuel system
1. Motec M800 w/all the goodies- Dynotechnik (Guy Grantham) Built and installed the Jumper harness for the Motec. All stock dash features work properly (Nice job Guy)
2. AMS New Rotated V-Band HTA 3586 w/1.03 ex AR - ss Tial Turbo Kit (turbo has been modified even further, extrude honed and a view other little touches) This kit is the Bomb guy's, it goes on so easy and all parts fitment is top shelf. (Thx Eric and all the guy's at the shop for a great product)
3. AMR Inter cooler
4. Custom Fab intake piping and Tial BOV
5. Injectors - Injector Dynamics
6. Surge tank/swirl pot w/twin Bosch 044 pumps #8 forward/#6 return (running a 100 PSI at full tilt boogie)
7. Weldon Regulator
8. Roger Clark Intake 100mm trumpet and air cleaner
9. T1 Catch can (thx Tony)
10. Custom exhaust -3.0 AMS down pipe (Comes with kit) Joined to 3.5 all the way out to a 3.5 S.S. light weight Burns muffler
11. ARC road race Oil pan w/remote filter and Setrab engine oil cooler (system holds 9 quarts)
12. Cosworth's New Intake Manifold (This is key to the overall equation)
13. Cusco Header
14. Cosworth 2.5 Long Block Billet crank
15. AR Fab Balancer (sorry typo)
16. Fluidyne Radiator
17. HKS Twin Power Ign. amp.
18. Odyssey 925 battery in trunk (15lbs)
Drive train/Chassis/Suspension
1. Setrab Oil coolers - Power steering, tranny, rear diff (Tilton pump)
2. Tilton Carbon Clutch
3. Torque Line Carbon prop shaft (drive Shaft)( Pure sex this thing is)
4. Drive shaft shop level 5 rear axles and front replacement bars
5. Ikeya Sequential Shifter w/gear indicator
6. Stasis 370mm front 4 pot brake kit/ Giro Disk rear replacement rotors (just being released) Race pads and Street pads
7. Cusco Front Sway Bar
8. Cusco Rear Sway Bar (Adjustable)
9. Cusco Front Strut Bar
10. Cusco Rear Carbon Fiber Strut Bar
11. DMS 50mm Tarmac Coil Over (custom spring spec)
12. GT – Spec 3 Piece Sub Frame Replacement Brace
13. PDE Caster/Camber Plates
14, Cusco Rear camber plates
15. Beatrush Front compliance kit (caster blocks)
16. STI Spherical Ball Trailing Links
17. STI Spherical Ball Lateral Links
18. STI Group N Bushings throughout Chassis
19. Solid mount rear bush/rear end cross member
20. Rev-Lab Quick Steering Rack
21. Custom Roll Cage painted PPG WR Blue by Gus
22. Advan RS 18 x 8.5 Wheels
23. Toyo R888 245/40-18 sneekers/Nitto NT 01 245/45-18
Interior
1. DEFI EGT Gauge
2. DEFI Boost Gauge
3. DEFI Gauge Controller
4. Custom Gauge Pod
5. Custom Center Console
6. 11 LB Fire Suppression System
7. PDE Billet Pedal Set w/Custom Brake Pedal for Proper Heal Toe Spacing
8. Sparco EVO Competition Seats
9. Sparco Steering Wheel Adaptor Hub
10. Stack ST8600 Steering Wheel w/Display System
11. Team Tech 6Pt. Harnesses
12. Oops! “I Pooped Myself” Resistant Cushions
Exterior and Aerodynamics
1. PPG Factory Pack WR Blue -Gus Agha at Austex Paint & Body (Complete Repaint, small oops)
2. APR Performance Carbon Fiber GT3 Mirrors
3. APR Performance Carbon Fiber Custom GTC-300 Wing
4. APR Performance Carbon Fiber Rear Custom Diffuser/quick mount Zues button
5. APR Radiator plate
6. Charge Speed Version 2 Side Skirts
7. Charge Speed Version 2 Rear Bumper
8. Cusco Front Bumper w/Aerodynamic Under Tray/extended carbon splitter
9. Seibon Carbon Fiber Reverse Hood Scoop
Car weight w/5 gallons gas 2975 lbs
We have 4 Tunes/maps in the car at the moment:
M1 - 19 psi pump gas 450 hp/Trq 351
M2 - 21 psi race gas 511 hp/Trq 413
M3 - 27 psi race gas 581 hp/trq 479
M4 - 30 psi race gas 646 hp/trq 541
Note: Race gas is VP Q16 from Edge Race fuels (Thx Kieth)
Here are the dyno Charts/videos/ and Pics of the Build/Make over:
pump gas:
race gas 30 psi
All 4 runs overlayed in order as above w/boost reference
Video of 646 WHP
Video Pump gas 450 whp
Video 21 psi race gas
Video 26 psi race gas
Thx to:
Dynotechnik - Guy Grantham - http://www.dynotechnik.com/
AMS - Eric and Staff - http://amsperformance.com/
T1 - Tony - http://www.t1raceparts.com/
Stasis Engineering - Beau Kelly - http://stasisengineering.com/
Girodisk - Martin Meade - http://www.girodisc.com/
APR Performance - Johnny Lee - http://www.aprperformance.com/
Macellaro's Performance Tuning - Chris Macellaro
Henderson Performance - Cory (Dyno services)
Last edited by jdeastty; 08-07-2009 at 01:47 AM. Reason: Complete parts list added
jdeastty is offline   Reply With Quote
Old 05-09-2009, 01:55 AM   #2
jdeastty
Member#: 150039
Photos of build:
Wiring as it started:
Wiring after clean up:
Turbo install pics:
Old 05-09-2009, 01:56 AM   #3
jdeastty
Member#: 150039
Under side of car Misc.
Old 05-09-2009, 01:58 AM   #4
jdeastty
Member#: 150039
potting of throttle body:
Building Motec Jumper harness:
Cosworth Intake and ITC Piping:
Misc pics of car:
Old 05-09-2009, 04:07 AM   #5
evan_impreza
Member#: 115276
04 PSM WRX -sold:(
98 RS- WRX swap complete!
beautiful build man! insane.
evan_impreza is offline   Reply With Quote
Old 05-09-2009, 04:16 AM   #6
polishlanman
Member#: 210883
2009 Mazdaspeed3
White Pearl
That's incredible. I wonder how comfortable a drive it is
polishlanman is offline   Reply With Quote
Old 05-09-2009, 05:20 AM   #7
STimo
Member#: 110273
450 whp 30R STI
[email protected]
Very nice setup! Congrats!
STimo is offline   Reply With Quote
Old 05-09-2009, 09:58 AM   #8
tyce
Member#: 15099
2002 EJ257 WRX
Matte Grey
And I'm in love... Amazing build, congrats!
tyce is offline   Reply With Quote
Old 05-09-2009, 10:15 AM   #9
bigolrig
Member#: 185347
2002 EVO3 bugeye wag
EG33 Swapped 2 dr RS
Mother of God.
bigolrig is offline   Reply With Quote
Old 05-09-2009, 10:19 AM   #10
carnz-pj-410
Member#: 110994
2004 Impreza WRX STi
thats a badass setup, more pics!
carnz-pj-410 is offline   Reply With Quote
Old 05-09-2009, 10:54 AM   #11
taossti
Member#: 145445
05 Time Attack STi
It rides nice. The DMS 50mm struts work great!
Guy
taossti is offline   Reply With Quote
Old 05-09-2009, 11:09 AM   #12
1fly05sti
Member#: 151009
05 STI OBP
under construction
great build keep it up!
1fly05sti is offline   Reply With Quote
Old 05-09-2009, 11:33 AM   #13
SW00P_G
Member#: 5591
EJ257 Gt35r
Great to see some awesome numbers with the new manifold. I like the pump gas power curve!! Awesome build also!!!
SW00P_G is offline   Reply With Quote
Old 05-09-2009, 12:13 PM   #14
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
www.surgelinetuning.com
Indeed that is a very nice build. Cosworth engine, and manifold.. Nice.
645whp out of a HTA 35R is some significant power. Wow.
What throttle body is that?
Jeff Sponaugle
sponaugle is offline   Reply With Quote
Old 05-09-2009, 12:20 PM   #15
dunk
Member#: 15359
Redline will allow cages with the main hoop backstays having bends in them?
-Duncan
dunk is offline   Reply With Quote
Old 05-09-2009, 12:25 PM   #16
thisiscainyo
Member#: 202726
2004 Forester XT
Stage 2 Silver 5-Speed
awesome
thisiscainyo is offline   Reply With Quote
Old 05-09-2009, 12:35 PM   #17
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Aspen White / Silver
-Duncan
Yeah i always though that was a serious NO NO when doing cages.
Token-Negro is offline   Reply With Quote
Old 05-09-2009, 12:37 PM   #18
ACLerok
Member#: 27915
2004 Subaru WRX STi
zoinks!
ACLerok is offline   Reply With Quote
Old 05-09-2009, 12:39 PM   #19
dunk
Member#: 15359
It's a no go with SCCA and NASA, but I don't know how Redline deals with that stuff.
-Duncan
Old 05-09-2009, 01:44 PM   #20
jdeastty
Member#: 150039
-Duncan
Hey guys, good point. The main hoop has no more than 4 bends and the back stays are the next size up for the weight of the car(under 3000). The original reason the rear stays were done this way is for use of the rear seats, it is a glorified street car for goodness sake . The cage is also completely stitch to the chassis down the roof line, A, B, and C pillars.
Thx again all comments welcome.
Old 05-09-2009, 02:07 PM   #21
jdeastty
Member#: 150039
Fuel System:
Engine Bay with Weldon Regulator:
Old 05-09-2009, 02:52 PM   #22
jdeastty
Member#: 150039
Jeff Sponaugle
You noticed! It's a TB from a Nissan. 71mm and DBW!
Thanks Jeff.
Old 05-09-2009, 02:56 PM   #23
codesoccer
Member#: 179573
2002 MBP Bugeye
Flip Flop Tuned on corn
that is one nice "glorified street car"!!! dunno if i'd like the lag though...trap times?
codesoccer is offline   Reply With Quote
Old 05-09-2009, 03:14 PM   #24
Illusive
Member#: 90436
2005 STI
Obsidian black pearl
holy ****! thats an awesome build.
Illusive is offline   Reply With Quote
Old 05-09-2009, 03:21 PM   #25
godforbid67
Member#: 137168
06 Built SGM WRX
35r, PPG, 280's, PSS9.
Best sounding suby I have ever heard damn. So raw.
What size cams??
Chris
godforbid67 is offline   Reply With Quote
WTB: 04 STi 6 speed tranny morgue Private 'Wanted' Classifieds 0 06-04-2010 09:06 AM
ECS tuned 02 wrx 2.0 vf48 316 whp 283 trq. Squillo Proven Power Bragging 6 04-07-2010 12:40 PM
646 WHP/541 TRQ 04 STI/Dynotechnik/AMS/Cosworth taossti Texas Impreza Club Forum -- TXIC 50 05-11-2009 07:09 PM
04 STI Short block JE pistons cosworth bearings SPUN ROD apoopoo999 Engine/Power/Exhaust 6 03-10-2008 10:49 PM
04 STi, DP, Typhoon, Plugs, 17.8 psi peak, 324 wlb-ft, 303 whp Subaru Gwinnett South East Region Forum 11 06-03-2005 05:44 PM
