Old 05-09-2009, 12:33 PM   #1
Dartholomew
Member#: 208771
2009 WRX
Default Which LEDs for interior conversion?
OK, I've done a search and narrowed it down to two reputable vendors - fastwrx and yourledshop.
But can anyone with experience using both provide a comparison of their respective products? Basically, I'm looking for reliable, clean white, significantly-brighter-than-stock LED conversions for all my internal and license plate lights on my '09 WRX. I'm assuming the LEDs will be have just like the incandescent bulbs (they'll fade/dim slowly on door close, etc.)?
Yourledshop has the right price and package, but I'm willing to pay more for the fastwrx multi-emitter solution if it's significantly brighter (and won't melt anything).
Any thoughts?
Dartholomew is offline   Reply With Quote
Old 05-10-2009, 03:08 PM   #2
danmezz
Member#: 126339
2003 WRX Wagon
I went with a different vendor than the ones above but here is a thread that may help...
http://forums.nasioc.com/forums/show....php?t=1676847
I actually bought these and am happy with the results. They look and perform quite similar to the ones others are using. These particular festoons also dim properly in the dome light
http://www.dealextreme.com/details.dx/sku.13043
http://www.dealextreme.com/details.dx/sku.13435
If I had to do it again though, I'd probably go for a brighter dome light somehow
danmezz is offline   Reply With Quote
Old 05-11-2009, 11:29 AM   #3
Dartholomew
Member#: 208771
2009 WRX
Thanks Dan. Didn't think to check DX. Fastwrx still looks like the best option for me, but I'm a bit hesitant to pull the trigger without knowing a more about brightness/reliability.
Old 05-11-2009, 07:32 PM   #4
danmezz
Member#: 126339
2003 WRX Wagon
yea, I can't say about Fastwrx.com's quality but do like the looks of the their multi-led panel for the dome light. It looks at least 2x as bright as the festoon I used. If Fastwrx led's are made in Japan, the quality's probably fine though.
On a side note just for info... the bulbs I referenced earlier are plenty bright for the map lights (almost too bright) and brighter than stock in the trunk (at least in a wagon).
LED Dash Light conversion legacy99black Electrical & Lighting 3 09-04-2010 02:12 AM
LED Neon interior center or map light for 06 2.5i???? jphillis89 Private 'Wanted' Classifieds 1 12-19-2008 12:16 AM
White or Red Leds for brake lamps, which will be brighter? 2slofouru Electrical & Lighting 18 02-05-2007 07:52 PM
Which model year crossmember for AWD conversion??? Aspen Normally Aspirated Powertrain 5 11-11-2000 10:57 AM
Which model year gas tank to use for AWD conversion??? Aspen Normally Aspirated Powertrain 2 11-10-2000 01:52 PM
