Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 05-09-2009, 06:34 PM   #1
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
Default car not starting after crash
ok.. well i know the fuel pump gets cut off when the airbags deploy... so i just routed a wire straight to the battery... so not the FP works...
it cranks strong.... it gets fuel.... but it doesnt start...
does it cut out the spark as well? anyone wanna give me some input?
i have a 94 EJ20G...
azn0boi04 is offline   Reply With Quote
Old 05-10-2009, 02:07 AM   #2
suberdave
Member#: 101865
88 GL-10 STi
i dont think that an EJ20G has any cut for the fuel or spark when the car gets in an crash...
everything should be just as it was. if you are getting fuel you need to check your spark. if you have fuel and spark you may have something else going on. try if all is well the engine may be flooded. try holding it WOT and see what happens.
if i remember correctly you said when you wecked it the core support did not contact the engine. so if that is the case. all should be well...
-=Suberdave=-
suberdave is offline   Reply With Quote
Old 05-11-2009, 10:21 PM   #3
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
well.. my FP wasnt working when i turned it on... but the FP works now.. and yes i tried WOT..
maybe a lil starter fluid? idk... ill try that... and ill take out the plugs to see if its flooded.
i took a better look and the only part that broke on the motor. is the timing belt cover... and it does not look like anything else moved/ broke...nothing is contacting the belts..
Old 05-12-2009, 01:00 AM   #4
WoodsWagon
Member#: 180769
lots of junkers
I've heard of the composite cam pullies shattering in crashes. If the t-belt covers are broken, take them off and look over the timing and pullies.
WoodsWagon is offline   Reply With Quote
Old 05-12-2009, 03:12 PM   #5
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
yeah i looked at the belts... (slightly)... i didnt see any MAJOR damage... the cam pullies werent touched. i dont think anyting is broken... cuz i wasnt hit too hard... the body took most of the damage... but... i can try to take off the belt cover and take a good look.
Old 03-14-2010, 07:55 AM   #6
Buggn' Out
Member#: 173971
02 /05 WRX
Aspen White, facelifted
i know this is an old post but what did you find out about your engine problem? I may be in the same boat...
Buggn' Out is offline   Reply With Quote
Old 03-14-2010, 08:00 AM   #7
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
he he .. yeah i think it was a fuse... after that your good..
its the fuse box under the dash.. look for the one with the Yellow cap over it.. i think thats the one.. or there another one with "IGN" something like that,,
Old 03-15-2010, 12:29 AM   #8
Buggn' Out
Member#: 173971
02 /05 WRX
so you just had a blown ignition fuse? mine will start after a few craks but it wont stay running....it sounds like it's idling on 2 or 3 cylinders then it just dies. I do remember after the crash that my gas light was on after the next couple days without running the car. The 1st couple times i tried to start the car i later realized that one of my intercooler couplers was torn wide open....maybe i flooded the motor?
Fuel Pump not starting after crash Rugnz Electrical & Lighting 9 11-10-2006 06:41 PM
Car not starting after new tranny? RS-Flyboy Transmission (AT/MT) & Driveline 1 07-07-2005 04:57 PM
Car not starting after work? pieces Normally Aspirated Powertrain 5 10-08-2004 12:23 PM
car will not start after installing CAI? Solomon Legacy Forum 25 07-30-2003 11:38 AM
Car not starting well after sitting for a day... heat? New battery? remarcable Normally Aspirated Powertrain 17 07-13-2001 06:34 AM
