Old 05-09-2009, 09:43 PM   #1
02blkwagn19
Member#: 146496
02 WRX Wagon 2.1L
Built not bought. #0003
Default Blowing Horn/Hazard fuse???
Hey guys i have a 02 wrx, and within the last week i just kinda realized my horn stopped working, so i changed out the fuse and it blew as soon as i hit the horn, but the hazards worked until i hit the horn. Tried throwing a 30 in there and blew that too.
I have done searches on this and seems to have been only one or two threads on this but they are of no help. I have a set of defi's in the clock pod and threw a sti cluster in the car, but i pulled both of them to check for grounded wires and couldnt find anything. the defi's were installed like almost 2 years ago and the st cluster about 1 year ago.
so i cant for the life of me figure this out, so if any of you guys have any knowledge of this please give me some ideas! until then i will be searching for grounded wires else where.
thanks guys
02blkwagn19 is offline   Reply With Quote
Old 05-10-2009, 12:54 AM   #2
b00st3d
Member#: 9891
2015 RC-F
Ultra White
had a similar problem with my 05 sti. it turns out one of the horn wires behind the front bumper rubbed against the bumper beam through the shielding and was grounding out everytime i hit the horn.
b00st3d is offline   Reply With Quote
Old 05-10-2009, 11:07 AM   #3
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
I agree with B00st3d, look for the trouble in the wiring near the horns. Since the fuse blew when trying to use the horn the trouble is after the horn relay, supplying power to the horns.
Never use a larger fuse to replace a smaller one. You may end up with more trouble than you bargained for.
Old 05-10-2009, 04:08 PM   #4
02blkwagn19
Member#: 146496
02 WRX Wagon 2.1L
right on i will check that out, thanks for the input guys
Old 05-25-2009, 05:09 AM   #5
02blkwagn19
Member#: 146496
02 WRX Wagon 2.1L
just an update, found the issue. A wire going to one of the horns was pinched between my fmic and part of the frame. So weaseled the wire out and "wal-la" no more blowing fuses.
hope this helps anyone who might run into the same problem.
Old 05-25-2009, 10:53 AM   #6
Cougar4
Member#: 53443
Winestone
Glad to hear you found the trouble and thanks for the update. If you haven't sealed the damaged insulation with some electrical tape or something similar you should do that. Over time, moisture will leech into the wire and damage it.
Old 08-19-2009, 02:49 PM   #7
mrmoe13
Member#: 193265
i have an 07 sti and had same problem . Thanks for info guys easy fix when you no where to look..
mrmoe13 is offline   Reply With Quote
Old 11-15-2009, 07:47 PM   #8
sti_is_my_new_love
Member#: 187715
12 wrx
same issure with my 06 sti. thanx big help
sti_is_my_new_love is offline   Reply With Quote
Old 10-10-2012, 08:38 AM   #9
geo301
Member#: 293561
2005 Wrx Vf39ing
Helped me out too!
thanks guys
geo301 is offline   Reply With Quote
Keep blowing turn signal & hazard fuse Decon Electrical & Lighting 13 01-26-2010 12:14 AM
TRouble Shooting.. Horn + HAzards GTIzzle07 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 06-23-2009 01:41 PM
Keep blowing Horn & Hazard fuse Se7enSTI Electrical & Lighting 5 09-05-2006 05:53 AM
Honk horn, pop fuse... nastiaz04 Electrical & Lighting 4 07-10-2006 06:22 PM
horn/hazards trippin a fuse? rex02 Electrical & Lighting 0 08-12-2003 12:00 AM
