Old 05-09-2009, 10:45 PM   #1
nikesb1111
Member#: 206369
1993 impreza
blue
Default ej18 problems
My 93 L just bogs down when i hit the gas. I had a SRI on it but i just put the stock setup back on thinking it night be that but it didnt work. Anyone know what could be causing this?
nikesb1111 is offline   Reply With Quote
Old 05-10-2009, 09:17 AM   #2
nikesb1111
Member#: 206369
1993 impreza
blue
anyone?
Old 05-10-2009, 09:24 AM   #3
cmiovino
Member#: 134005
2004 WRX Premium
Did you try resetting the ECU?
IE Disconnecting the battery and waiting a few minutes. Then start the car and it shouldn't bog. Let it idle for about ten minutes and you should be good to go. If this works, I'd put the SRI back on and try the same thing.
Old 05-10-2009, 10:35 AM   #4
nikesb1111
Member#: 206369
1993 impreza
blue
ok thank you
Old 05-10-2009, 11:01 AM   #5
nikesb1111
Member#: 206369
1993 impreza
blue
Ok its running pretty good now. I put the SRI back on and im not sure if i want to keep it on or not. It seems like it takes longer to rev and it backfires more.
Old 05-10-2009, 11:04 AM   #6
cmiovino
Member#: 134005
2004 WRX Premium
Anytime you go between the two, you need to reset the ECU so the computer can adjust to the new intake.
I'd either stick with stock or use the airbox and the pipe from the SRI to combine the two into a hybrid. This eliminates the accordion tubing from the stock intake.
Old 05-10-2009, 07:28 PM   #7
nikesb1111
Member#: 206369
1993 impreza
blue
The tube i was using was for a 2.5 and i had to kind of rig the vaccuum lines and i didnt really like that. Also the tube was too short to reach the airbox. Im using the stock tube with the open element filter and its great.
ej18 problems mxpunk Normally Aspirated Powertrain 2 07-06-2008 12:04 AM
EJ18 Water Pump Replacement Problems Offroader99 Normally Aspirated Powertrain 11 05-28-2008 03:05 PM
EJ18 exhaust problem flatline11596 Newbies & FAQs 3 10-21-2006 02:06 AM
EJ18 starting/cooling problems Pawl Normally Aspirated Powertrain 5 02-22-2006 10:12 PM
JDM EJ18 Swap... problems... Unsung Boxer Subaru Conversions 2 04-02-2004 08:44 PM
