Old 05-09-2009, 11:45 PM   #1
Badmunky
Member#: 143391
2007 WRX TR
R.I.P Paul! :(
Default Air pump removal + fail? 07 WRX.
Ok so today another member of misubie.com tuned my car for me (Thanks 06limited) and we decided to unhook all the parts for the air pump and turn off all the CELs as part of the tune. This was in prep for me removing the air pump system later on.
But we ran in to a problem.
After we unhooked every thing the MAP sensor read wrong?
It was then reading about 8psi below what the car was making. It also read more vac then normal by the same amount.
We hooked every thing back up and every thing went back to normal.
Has any one ells had this happen to them?
Do you have a fix?
Later.
Badmunky is offline   Reply With Quote
Old 05-09-2009, 11:55 PM   #2
Badmunky
Member#: 143391
2007 WRX TR
R.I.P Paul! :(
Title was supposed to read "Air pump removal = Fail? 07 WRX." Can a mod fix please?
Thanks.
Old 05-10-2009, 10:36 AM   #3
JO'S TR
Member#: 127012
2006 WRX 18g+Meth
6spd WRB
you have to leave the big air pump valve under the IC pluged in. It has the atmosspheric pressure sensor in it
JO'S TR is offline   Reply With Quote
Old 05-10-2009, 02:45 PM   #4
Badmunky
Member#: 143391
2007 WRX TR
R.I.P Paul! :(
Is there a way around that?
I want to remove all the parts of the system not just some of them.
In the 06 this was not a problem.
Where is the atmospheric pressure sensor in the 06?
Old 05-10-2009, 02:57 PM   #5
sch3838
Member#: 154636
http://www.iwsti.com/forums/how-inst...p-removal.html
no you have to leave the atmospheric pressure sensor in. you also need to buy block off plates. passenger side is pain in the ass i ended up just cutting the pipe off with dremmel.
sch3838 is offline   Reply With Quote
Old 05-11-2009, 01:08 AM   #6
Badmunky
Member#: 143391
2007 WRX TR
R.I.P Paul! :(
Im going to have a large part of the motor pulled apart soon for other mods.
Figured it was a good time to remove the air pump system.
I am going to order the block off plates as well as a few other things I will need soon.
Thanks for the info man!
Old 05-11-2009, 02:02 PM   #7
Ysidro
Member#: 197418
07 WRX Ltd
The Mighty Evo;Fun CRZ
Its the one thats not under the intake manifold.
You can tell by looking at the harness. The one you want is the one with more than 2 wires.
goodluck.
Ysidro is offline   Reply With Quote
Old 05-13-2009, 04:17 PM   #8
Badmunky
Member#: 143391
2007 WRX TR
R.I.P Paul! :(
Ok from what I have found the sensor in the 06 WRX is in the ECU. In the 07 WRX it is in the valve with the larger harness hooked to it.
Now I just need to find a way to remove it from the valve.
Option 2 is to use an 06 ECU, but I'm not sure that will work yet.
Later.
Old 05-13-2009, 04:45 PM   #9
j.r
Member#: 201800
2007 STI
gt30r
Do you have to buy block off plates to remove the air pump?
j.r is offline   Reply With Quote
Old 05-13-2009, 07:35 PM   #10
Badmunky
Member#: 143391
2007 WRX TR
R.I.P Paul! :(
No. But you do need to cap the hose from the pump.
You do need them if you wish to remove the hole system valves and all.
Later.
Old 05-24-2012, 03:13 AM   #11
Yuantrouble
Member#: 145354
2006 WRX TR
Where can I get some of these plates?
Yuantrouble is offline   Reply With Quote
Old 05-24-2012, 06:14 AM   #12
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
Search on google, kstech sells them and many others.
Old 06-10-2012, 11:36 PM   #13
Badmunky
Member#: 143391
2007 WRX TR
R.I.P Paul! :(
I did end up removing everything from the car. And I used the Kstech plate on the passengers side, and I taped the hole for the tube in the head and installed a bolt in it on the drivers side as both of the bolts that hold the tube to the head snapped off in the head when I tried to remove them. There WEAK bolts as it took nothing to brake them.
I cut the ATM sensor of the top of the valve and then sealed the bottom where the wires for the valve come out and mounted it to the bracket that holds the fuel lines on the left strut tower.
Been like that now for a long time with no problems.
Old 04-29-2013, 08:05 PM   #14
Skankyfrankie
Member#: 354906
07 WRX
did you also remove all the fuses and relays or leave them? I am doing a 07 wrx this weekend so just trying to gather the important stuff.
Skankyfrankie is offline   Reply With Quote
Air Pump removal for 07 STI sean18337 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 18 04-21-2016 01:54 PM
06 WRX Air Pump Removal - is it safe?? Banish Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1077 02-18-2016 07:22 AM
WTB: Secondary air pump baro sensor 07 WRX ronzogonzo Private 'Wanted' Classifieds 0 11-25-2009 05:37 PM
I need instructions for 07 STI Air pump removal sean18337 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 04-26-2007 10:23 PM
