Old 05-10-2009, 06:34 PM   #1
1995REX
Member#: 201655
2001 TT Legacy GT-B
Default Who is making 300-350HP with a EJ20G
Just wondering who is making around 300-350 HP with there EJ20G and what your set up is. I'm sitting at 255 AWHP and would like to be at 300-350 AWHP. If you have a reliable daily driven number in this range please let me know what your combo is so I can try and get there to thanks for your help on this.
1995REX is offline   Reply With Quote
Old 05-10-2009, 07:23 PM   #2
suberdave
Member#: 101865
88 GL-10 STi
i am running 293AWHP 277AWTQ, almost in your range. just need a little more...
1996 EJ20G
Full standalone ViPEC ECU
780cc injectors
FMIC
Stock TDO5h 16g
Blitz boost controler @ 17PSI
05 Ign coil mod
APS BOV vented
Full 3" TBE
lots of tuneing...
been running it this way for about 8 months. i have been running the engine for over 4 years,
-=Suberdave=-
www.suberdave.com
suberdave is offline   Reply With Quote
Old 05-10-2009, 08:28 PM   #3
Eatoniashoprat
Member#: 143416
1971 Super Beetle
EJ20g Platinum Grey
1996 EJ20G
780cc injectors
FMIC
Stock TDO5h 16g
05 Ign coil mod
APS BOV vented
Full 3" TBE
lots of tuneing...
-=Suberdave=-
www.suberdave.com
I'm just curious about your injectors from witchhunter, did you have to adjust latencies or anything? I realize its the same injector but just wondering if response was affected, or if it was a bolt in affair with injector scaling? I can see myself doing the same thing in the near future. Thanks
Eatoniashoprat is offline   Reply With Quote
Old 05-11-2009, 12:40 AM   #4
suberdave
Member#: 101865
88 GL-10 STi
i had a long talk with the Gordon at Witch Hunter about injector latencies. all the latencie is, is the time it takes the injector to energize to full open. it will change with voltage but not with modification. the injector still uses the same coil...
i just scaled my fuel map down by about 30% and put it back on the dyno to check it out...
the injectors are a bolt in job, other than you must have the phase one to phase two injector callors.
-=Suberdave=-
www.suberdave.com
Old 05-11-2009, 09:25 AM   #5
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
my recipe would follow dave's
rebuild the td05 with a big 16 wheel
big injectors
standalone
FMIC
coil conversion
Old 05-12-2009, 12:23 AM   #6
semaj
I'm sorry for apologizing
Moderatour
Member#: 113533
2006 Pathfinder
Off Road
Jaxx, are there no bigger TMICs worth upgrading over stock? I prefer TMIC to FMIC if possible.
semaj is offline   Reply With Quote
Old 05-12-2009, 09:50 AM   #7
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
sorta there is the ARC but its mega expensive ..
the G manifold is different than all the other ej20s .. th throttle is a good 3" closer to the firewal'
Old 05-12-2009, 10:47 AM   #8
sniper512
Member#: 189923
1993 JDM WRX
You can do a custom TMIC from a USDM WRX, but I am not sure if it would be good to 300whp. I do know mine doesn't heatsoak on hard runs yet at 15psi on Robs Tune and some bolt ons.
sniper512 is offline   Reply With Quote
Old 05-24-2009, 03:52 AM   #9
jdmwrx94
Member#: 211619
94 jdm wrx
red
big injectors
standalone
FMIC
coil conversion
im curious, does the coil convertion actually improoves the engine in any ways?, taugh it was just a replacement thing when u need new ones.
jdmwrx94 is offline   Reply With Quote
Old 05-24-2009, 10:16 AM   #10
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
well it improves the likely hood that the coil is working .. the old ones are .. well .. old and fail unpredictably
Old 05-24-2009, 12:37 PM   #11
JDMFLCL
Member#: 180513
Baby Baby C'mon!
Looka Bomba! 99 JDM GM8
don't the ej20g internals become somewhat iffy @ around 350whp especially with the cast pistons in the wrx model?
JDMFLCL is offline   Reply With Quote
Old 05-26-2009, 02:36 PM   #12
luka
Member#: 194742
1993 Impreza WRX JDM
I was always under the impression that the G series had forged internals + oil squirters? hence the impressive numbers on stock internals...
luka is offline   Reply With Quote
Old 08-16-2009, 11:31 PM   #13
1995REX
Member#: 201655
2001 TT Legacy GT-B
hey just trying to bring this back to life as im am finaly heading back to the US and going to order some parts. Here is my current list of mods:
1995 EJ20G
ARC TMIC
Apexi intake
Megan racing TBE no cats
Greddy profec II boost controller set at .9 bar low 1.1 bar high
What is the ECU that everyone recomends? Would a VF22 be enough turbo to support 300-350AWHP? If not suggestions please. What injectors should i look at? If you have a favorite for any reason let me know. I will be installing a Walbro fuel pump soon. Any more advice is good and with the turbo i just want a drop in turbo or one that requires very little moding to install. thanks again for your help
Old 08-16-2009, 11:50 PM   #14
Pierrot
Member#: 180417
Maybe its a good idea to put what dyno people are using?
Pierrot is offline   Reply With Quote
Old 08-18-2009, 02:18 PM   #15
kay95
Member#: 45494
95 impreza L awd
green
What do you think they put in the current WRX? The 20Gs got thermal flow pistons like the 2.2t. They are denser and stronger than high pressure cast pistons though still not a forged unit but beefy in its own right.
kay95 is online now   Reply With Quote
Old 09-03-2009, 03:35 AM   #16
maddhatteroo7
Member#: 78840
Hey Robert,
Check out this link about the different VF's:
http://forums.nasioc.com/forums/show....php?t=1141476
With the VF22 it's more likely to net around 270ish with some support like larger than 565cc injectors, fuel pump, TMIC (not sure how the arc is since I'm used to state side stuff.) Always could run some meth and that will surely help. I had a friend who made just over 300whp with meth, TD05 20G on a 04 WRX 2.0L and tuning of course. Overall...it's possible but if you were going over 300whp I'd probably go for something other than a VF series. Definently speak with whoever your tuner will be and he should know
maddhatteroo7 is offline   Reply With Quote
Old 09-03-2009, 06:10 PM   #17
1995REX
Member#: 201655
2001 TT Legacy GT-B
Thanks,
Well heres how its going to look now for mods,
Rob's tune
550 STi injectors
Walbro
TD-05 stock
Apexi intake
ARC TMIC
Greddy PRofec B spec II EBC (Low 12PSI High 16-18ish not sure discussing with Rob)
Megan racing TBE (Catless)
Possibly Meth been heavely considering it
I will hit the Dyno before installing my Tuned ECU, 550's, Walbro and meth? Next day I will do my install except for meth. How far do you need to drive to fully reap the benifets of a tune does it need so many miles to 100% register or anything? Then i will re-Dyno to see what my gains where and post those. And then I will toss the idea for meth around again and my turbo choice as well.
anyone making 300+ HP with the stock axleback? prometheum Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 01-09-2010 12:48 AM
Ok, so who is making a Houston to Dallas run this weekend? Vahnatai Texas Impreza Club Forum -- TXIC 12 09-30-2007 11:04 PM
Who is making 93 gas from 91 and race gas for daily driving??? BBBsti LTD Southern California Impreza Club Forum -- SCIC 4 05-12-2007 02:33 AM
Who is making their yearly church visit tommorrow? BGPunk2001 Off-Topic 28 04-07-2007 09:33 PM
Who is making the 2.5 engine ??? alfriedesq STi Forum Archive 41 01-28-2003 02:10 PM
