Old 05-10-2009, 10:29 PM   #1
wildsti
Member#: 49270
Default 245/45/17 on a 09 WRX wagon
Hi,
I have a 09 wrx
Planing to buy some falken azenis for the track,
Falken recommended a 8.5 width for the 235/40/17
and a 8 width for the 245/45/17
I find a little weird that they recommend a wider wheel for a smaller tire?
Will I have any rubbing issue with 245 or should I stick to 235?
I have stock supension (for now)
Thanks
wildsti is offline   Reply With Quote
Old 05-11-2009, 12:28 AM   #2
mosc
Member#: 177401
2015 STi White
Sidewall plays a large role in determining what rim goes with what tire. 50, 45, and 40 sidewall all have different rim width requirements as you shift from a "regular" tire into a "low profile" tire. 40 sidewall requires a rim nearly as wide as the tire itself where on the other extreme 50 sidewall is better off with a rim considerably narrower than the tire. The tires are designed differently to deal with different sidewall stiffness.
245/45/17 is quite tall and probably not what you want. Your stock tire is 25" tall and I suggest something that tall or less. Many people like 24.5" tires for shortening the gears a bit (the 5-speed is a little tall for road racing).
The 09 has pretty good clearance. Mattering on the offset of your rim, you should be able to fit 245/40/17 without much problem. Note that it's slightly shorter than stock which is again a good thing. Try to find a rim with an offset as close to +55 as you can find. 8.0" width will work for 245/40/17 but a little more rim width wouldn't hurt. However, if you have to sacrifice a lot of offset, you might get into rear fender rubbing problems.
Tire rack has the MT1 on closeout which is a 5x100 17x8.5" rim with +48 offset. Might want to check that out...
mosc is offline   Reply With Quote
Old 05-11-2009, 12:52 PM   #3
wildsti
Member#: 49270
Thing is the Azenis is available in:
225/45R17 recommended 7.5 wide (my stock size)
235/40R17 recommended 8.5 wide
245/45R17 recommended 8 wide
255/40R17 recommended 9 wide (this one height wise is the same as stock)
I would like to go with the widest possible without rubbing.
I was thinking of the Rota DPT
these sizes are available:
17x8 +48
17x9 +35
17x9 +42
Old 05-11-2009, 02:33 PM   #4
mosc
Member#: 177401
2015 STi White
225/45 or 235/40 on the 17x8 +48 won't rub. Most of the other combinations are in the grey area.
I don't know what the Rota DPT looks like or why you are sold on Azenis tires but there are plenty of tires in the world available in 245/40/17 and plenty of 8 or 8.5" rims in the +48 to +55 range. I suggest if you really want that extra 10mm of tire, you re-think your rim and tire selection based on that size. Note that you might even have trouble with 245 if your suspension has a lot of give (lowered).
255/40/17 isn't impossible to fit. You just need 8.5" of width (or more) and as much offset as you can muster. You'll still have to roll the rears as well. I squeezed 255/40/17 on my 04 STi with a +48 17x8.5" rim. I need to roll my rears though, they cut into my tire's sidewall when I hit bumps.
Old 05-11-2009, 10:03 PM   #5
UFOpilot
Member#: 189525
2007 WRX Wagon
Invisible Plain
Dude. You can put a 17x9 +42 on an '07 wagon, the '09 hatches have a bit more room to play with.
UFOpilot is offline   Reply With Quote
Old 05-12-2009, 08:40 AM   #6
dantastic
Member#: 66815
2005 WRX Wag -SOLD:(
CGM STX #125
Originally Posted by wildsti View Post
Hi,
I have a 09 wrx
I'm surprised that no one stopped him here. RT-615 are old news. If you want cheap sticky tires, at least get the Kumho XS; Dunlop Star Spec, Bridgestone RE-11 if you can afford them.
dantastic is offline   Reply With Quote
Old 05-12-2009, 10:46 AM   #7
Sebastian Damian
Member#: 200813
05 STI (Sold)
WRB (whp 290) (ftlb 358)
235 /40/ 18 on pink springs and struts 05 STI will they rub ??
Sebastian Damian is offline   Reply With Quote
Old 05-12-2009, 10:48 AM   #8
mosc
Member#: 177401
2015 STi White
not enough info
Old 05-12-2009, 10:49 AM   #9
Sebastian Damian
Member#: 200813
05 STI (Sold)
prodrive pff7's goodyear eagle F1
Old 05-12-2009, 10:50 AM   #10
mosc
Member#: 177401
2015 STi White
what's the rim?
Old 05-12-2009, 10:52 AM   #11
Sebastian Damian
Member#: 200813
05 STI (Sold)
Prodrive pff7
Old 05-12-2009, 11:12 AM   #12
mosc
Member#: 177401
2015 STi White
what is the width and offset of the Prodrive pff7?
Old 05-12-2009, 11:20 AM   #13
Sebastian Damian
Member#: 200813
05 STI (Sold)
thats what i dont know
Old 05-12-2009, 11:32 AM   #14
Sebastian Damian
Member#: 200813
05 STI (Sold)
8.0 width +51mm offset 235/40/18 ??
Old 05-12-2009, 11:34 AM   #15
mosc
Member#: 177401
2015 STi White
On those springs I'd stick to 225/40 because the added height of 235/40 could cause problems. You could go 235/35 no problem but I doubt you want to sacrifice that much gear ratio for 10mm of tire width. 245/35 might be another option.
Old 05-12-2009, 11:40 AM   #16
Sebastian Damian
Member#: 200813
05 STI (Sold)
its too late i got the 234 40 i just hope they fit im worried about the front not fitting
Anybody run 235/45/17 on stock 09 wrx wheels? WRX_Convert Tire & Wheel 1 11-22-2009 09:53 PM
Suspension Effects of 245/40/17 on stock '06 WRX Wagon? zenphoenix Tire & Wheel 2 11-22-2009 01:11 AM
245/45-17 on an MY05 Wagon LoLoHax Tire & Wheel 1 09-19-2008 07:54 PM
Advice: 235/45/17 or 245/45/17 on '05 STi palpullero Tire & Wheel 22 03-08-2006 02:05 PM
245/45/17 on 17 by 7.5 CE28 jdmej20 Interior & Exterior Modification 16 12-26-2004 12:21 AM
